Quaffer
Veteran Member
Map gas?If u don’t have a BIG oxy torch.. they have them in a hand held YELLOW BOTTLE..
NOT THE BLUE BOTTLE..
AFAIK, as long as you are using the same High Heat turbo type nozzle, Propane and the new MAPP Pro gas heat the same.If u don’t have a BIG oxy torch.. they have them in a hand held YELLOW BOTTLE..
MAPP gas burns at a higher temperature compared to propane, providing more heat and making it suitable for tasks requiring intense heat, like welding. Propane, on the other hand, is used in a wider range of applications, from heating to cooking, due to its lower burning temperature.AFAIK, as long as you are using the same High Heat turbo type nozzle, Propane and the new MAPP Pro gas heat the same.
True MAPP, yes.. That 'Mapp Pro' (Ultra Gas) they make now is pretty much the same as regular propane. Buy the best turbo torch and use propane unless you have a Oxy/Acetylene setupMAPP gas burns at a higher temperature compared to propane, providing more heat and making it suitable for tasks requiring intense heat, like welding. Propane, on the other hand, is used in a wider range of applications, from heating to cooking, due to its lower burning temperature.
I bought it this spring after ditching my old HF lower quality one that I had for seven years. This mower jack is top drawer and I lift a JD 370 with ease and safety. Also use it as an intermediate work tableWhen I upgraded my riding mower, my cheap HF mower jack wasn't capable of lifting it. I used a floor jack instead, because I was too cheap to buy the $209 one they sell. Recently, I bought a Jeep Cherokee and wanted to install an aftermarket bumper. Some health issues made me not want to wrestle 250lbs of steel, so I bought the new mower/ATV jack. 750 lb. Heavy Duty ATV/Mower High Lift Jack
Superb piece of equipment. Packaged beautifully, stout design, easy assembly - everything fit - and very good finish. Put a hitch stem in the receiver on the bumper, tied it off to stabilize it, and got to work. Some cutting and fitting required to install the bumper, and had it on and off four times. The jack was just the ticket, and saved me a lot of time and effort.
When I was done, I even jacked up the mower.
HF has really stepped up with their better lines of tools.
I have one of these. It's okay for light repairs at the end of a cord like corral panels and gates. But it is no substitute for a good mig. Nice discountThe 120 volt Titanium Flux 125 welder $99.99 TODAY 10/2 ONLY, in HF's email promotion.
In-store only. I wonder if they're closing them out.
I bought that tool last spring and am likewise satisfied with it.On bargain's at HF, I needed a set of substantial pop rivet puller tool as I'm pulling large diameter (1/4" and larger) pop rivets for a project I'm working on so I went to HF yesterday and perused the pop rivet tools. The toll I own presently don't provide enough mechanical leverage to pull the big rivets even using 2 hands..
So I cruised over to the pop rivet tools with the intent of buying the Doyle, compound leverage pop rivet tool for 30 bucks and lo and behold, hanging right next to the Doyle too is a Pittsburg 58612 pop river too with interchangeable nose pieces as well as compound leverage and the handles are substantially longer that the Doyle for 18 bucks with a 'lifetime warranty' as well.
Needless to say, the Pittsburg tool came home with me and when I got home, first thing I did was pull one of the largest rivets I'm using and it pulled and popped the rivet shank effortlessly. Comes with a nice assortment of rivets as well.
Very impressive tool and much cheaper than the Doyle.
Must be a new addition as It's not on the HF website at all, or at least was not yesterday.
Put together good as well with nylock nuts securing the arms and a nice aluminum casting carrying the nosepiece and a collection bottle for popped shanks.
The smaller pop rivet tools are ok for small rivets but lack the leverage for the big rivets. The Pittsburg tool pulls them all, steel or aluminum rivets.
Well worth under 20 bucks and lifetime warranty to boot.
That’s the one I have. It works well with heavy duty 1/4” rivets.This one? I bought some SS rivets recently and my little rivet gun is tough to use on these rivets. This looks like a good deal and I've wondered how well they work. Thanks.
Looks like there won't be a problem. WaPost:Better get the Amazon, made in China stuff while you can because the port strike is gonna put a helluva dent in all the stuff from China
