/ Harbor Freight Tools that don't suck #15,862
If u don’t have a BIG oxy torch.. they have them in a hand held YELLOW BOTTLE..
NOT THE BLUE BOTTLE..
AFAIK, as long as you are using the same High Heat turbo type nozzle, Propane and the new MAPP Pro gas heat the same.
/ Harbor Freight Tools that don't suck #15,864
MAPP gas burns at a higher temperature compared to propane, providing more heat and making it suitable for tasks requiring intense heat, like welding. Propane, on the other hand, is used in a wider range of applications, from heating to cooking, due to its lower burning temperature.
/ Harbor Freight Tools that don't suck #15,865
Real MAPP hasn't been made for a while but was a decent amount hotter than propane. From what I see, MAP Pro is only a bit hotter than propane and may not be worth the extra cost. It's more than double the price at Walmart.
Good video Andy posted, I may need one of those TS8000 tips. :)
/ Harbor Freight Tools that don't suck #15,866
True MAPP, yes.. That 'Mapp Pro' (Ultra Gas) they make now is pretty much the same as regular propane. Buy the best turbo torch and use propane unless you have a Oxy/Acetylene setup
/ Harbor Freight Tools that don't suck #15,867
I was just using a propane torch. I sold my acetylene torch about 5 years ago as I hadn’t needed it in the previous 10 years. Kind of wish I still had it now.
Anyway, the cheater bar got it off today. I repositioned the mower so I could put more weight on it. Snapped a Pittsburgh breaker bar (the long skinny one they sell, so I guess that Harbor Freight tool sucks) but my old trusty SK came through without a hitch.
/ Harbor Freight Tools that don't suck #15,868
Saw a display ProTIG165 for $204.98 at HF today. No tig end, no ground clamp, just the machine itself. It said it offer HF, and I think it had a foot peddle available? Didn't get it, and dont "need" it, but, I did look at it a couple times, and think pretty hard about it.
/ Harbor Freight Tools that don't suck #15,869
When I upgraded my riding mower, my cheap HF mower jack wasn't capable of lifting it. I used a floor jack instead, because I was too cheap to buy the $209 one they sell. Recently, I bought a Jeep Cherokee and wanted to install an aftermarket bumper. Some health issues made me not want to wrestle 250lbs of steel, so I bought the new mower/ATV jack. 750 lb. Heavy Duty ATV/Mower High Lift Jack
Superb piece of equipment. Packaged beautifully, stout design, easy assembly - everything fit - and very good finish. Put a hitch stem in the receiver on the bumper, tied it off to stabilize it, and got to work. Some cutting and fitting required to install the bumper, and had it on and off four times. The jack was just the ticket, and saved me a lot of time and effort.
When I was done, I even jacked up the mower.
HF has really stepped up with their better lines of tools.
I bought it this spring after ditching my old HF lower quality one that I had for seven years. This mower jack is top drawer and I lift a JD 370 with ease and safety. Also use it as an intermediate work table
/ Harbor Freight Tools that don't suck #15,870
The 120 volt Titanium Flux 125 welder $99.99 TODAY 10/2 ONLY, in HF's email promotion.
In-store only. I wonder if they're closing them out.
/ Harbor Freight Tools that don't suck #15,871
I have one of these. It's okay for light repairs at the end of a cord like corral panels and gates. But it is no substitute for a good mig. Nice discount
/ Harbor Freight Tools that don't suck #15,872
I have big ancient stick welder, and a HF MIG-180 that cost $25 used. But I wanted a little welder that was simpler to pull out of storage and set up, for small tasks. So I almost bought that little 120v Titanium. But at the time, 2021, the order led to 'order now for delivery next June'. So I went to Amazon and bought the equivalent except its dual voltage.
After using this little Amazon one (Amico Mig-130A) I now appreciate that dual voltage opens up a lot more welding power in a small portable unit. At 120 volts, welding is limited by the 20 amp breaker you likely have in your shop. The advertised specs need a 30 amp breaker and nobody has that.
There are now many units on Amazon comparable to the Amico I bought. Just read reviews and include the $20 3 year warranty advertised alongside the welder.
I suspect HF will supersede this little flux welder with a similar dual voltage unit, to catch up with the new competition.
/ Harbor Freight Tools that don't suck #15,873
Better get the Amazon, made in China stuff while you can because the port strike is gonna put a helluva dent in all the stuff from China that Amazon sells as in when it's gone, it's gone and if it comes back. it will increase in cost substantially if the port workers get what they are striking for.
Keep in mind it all comes here in containers and no containers are being offloaded and no containers in the ports presently are being shipped out either as there is no one to load them on trucks or rail cars. I understand why they are striking but I think their demands are unreasonable.
Right now, the only ports that are operating are the west coast ports and I suspect they will walk off in solidarity as well.
Like I said, better get it before it's gone.
/ Harbor Freight Tools that don't suck #15,874
On bargain's at HF, I needed a set of substantial pop rivet puller tool as I'm pulling large diameter (1/4" and larger) pop rivets for a project I'm working on so I went to HF yesterday and perused the pop rivet tools. The toll I own presently don't provide enough mechanical leverage to pull the big rivets even using 2 hands..
So I cruised over to the pop rivet tools with the intent of buying the Doyle, compound leverage pop rivet tool for 30 bucks and lo and behold, hanging right next to the Doyle too is a Pittsburg 58612 pop river too with interchangeable nose pieces as well as compound leverage and the handles are substantially longer that the Doyle for 18 bucks with a 'lifetime warranty' as well.
Needless to say, the Pittsburg tool came home with me and when I got home, first thing I did was pull one of the largest rivets I'm using and it pulled and popped the rivet shank effortlessly. Comes with a nice assortment of rivets as well.
Very impressive tool and much cheaper than the Doyle.
Must be a new addition as It's not on the HF website at all, or at least was not yesterday.
Put together good as well with nylock nuts securing the arms and a nice aluminum casting carrying the nosepiece and a collection bottle for popped shanks.
The smaller pop rivet tools are ok for small rivets but lack the leverage for the big rivets. The Pittsburg tool pulls them all, steel or aluminum rivets.
Well worth under 20 bucks and lifetime warranty to boot.
/ Harbor Freight Tools that don't suck #15,875
I bought that tool last spring and am likewise satisfied with it.
/ Harbor Freight Tools that don't suck #15,877
/ Harbor Freight Tools that don't suck #15,878
Interestingly, it didn't show up on my HF app at all but it showed up on my bench, after I bought it. Only thing I see is there are no replacement jaws available but for the price, I'll buy another one when the jaws wear smooth.
Either that or return it and get another one as it has a lifetime guarantee and I kept the store receipt as well.
Like I said, pulls 1/4" STEEL pop rivets, no issue, no strain. I bet the aluminum rivets are a piece of cake.
Not real trusting of the Pittsburg stuff as it's the low tier of HF tools but it appears to be quite robust. I usually buy Chief or Icon stuff.
So far so good and I set over 15 steel rivets yesterday with no issues at all and I have a ton to set today. It comes with an assortment of aluminum blind rivets but I have plenty as is.
the only downside I can see is, there is no place to store the nose wrench on the tool but I'll probably just use a metric box wrench anyway. Comes with 4 extra nose pieces plus the one in the gun for 5 total.
Looked and passed on the Doyle. Cost more, shorter handles and no replacement jaws either.
/ Harbor Freight Tools that don't suck #15,879
Looks like there won't be a problem. WaPost:
"Striking dockworkers reached a tentative agreement with port operators on Thursday for a 62 percent wage increase and have extended their contract through Jan. 15 to bargain over remaining issues.”
/ Harbor Freight Tools that don't suck #15,880
With the large rivets you can pop about anything together. I'm working on the front and rear bulkheads for our Generac propane fired house generator that the cabinet went south on (rusted out) and I was not about to buy another 20KW generator for 13 grand so I special ordered a new cabinet from Generac. The new cabinet is aluminum, not steel but the bulkheads are NLA and both were rusted out on the bottom edge so I fabbed up new bottoms on my press brake and I'm pop riveting the new bottoms to the existing tops. The metal is too thin to even braze let alone MIG so the pop rivets are the correct solution. I would have fabbed the entire bulkheads but the existing ones have threaded inserts in them that align with the aluminum cabinet. I figured 5 grand for a new cabinet was cheaper though I did have to wait for 2 months for Generac to make it for me.
The bulkheads are about done so all that is really left is reassembling everything and I took pictures of all the wiring and terminals and there is a bunch. Gonna pour a new concrete pad for it as well. The old pad cracked, this one won't. Putting concrete screen in the cement and I finally get to use the 3 point cement mixer I bought 20 years ago. I knew at some point I'd use it...lol
Winter is coming and we need the house standby as power goes south here in the winter, quite often.
For the life of me, I don't understand why Generac made them with steel cabinets instead of aluminum. Being out in the weather, they corrode. The Township has one by the Township hall and it's rusting away as well.
The diesel fired Generac I have to run the shop came with an aluminum enclosure, go figure.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2024 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A59905)
2024 KENWORTH T680...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
UNUSED RAYTREE RMDM70-70" HYD DISC MULCHER (A60432)
UNUSED RAYTREE...
2001 CATERPILLAR 140H VHP MOTORGRADER (A59823)
2001 CATERPILLAR...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
