Kioti Grapple Buyer beware!!!!
/ Kioti Grapple Buyer beware!!!! #41
I've had to do a bit of grinding on a couple of my SSQA attachments where the locking pins latch in the bottom of the attachment. (pins where to tight to latch down without a bit of grinding on the QA plate)
That's interesting. I would never have anticipated that with the SSQA standard.
I still don't understand why the standard SSQA grapple didn't fit your Bobcat tractor though. Can you elaborate on what didn't line up?
The top plate by the Locking pins was to big and would not the the plate sit flush, So i had to grind about a 1/2" out to get it to lock.
/ Kioti Grapple Buyer beware!!!! #43
As a note, A-36 mild steel (used by MTL Attachments) is 36KSI yield, AR400 is "Abrasion Resistant" material and 184KSI, so the resulting product is much stronger for less weight. Hardox 450 is even tougher. Be aware buying a grapple made with soft materials is likely fine for picking up brush, but will bend relatively easily under load.
A-36 on the table:
/ Kioti Grapple Buyer beware!!!! #44
FYI Kubota QA are 100% compatible with Bobcat SS so I'm able to buy either fitment and share attachments. That was one of the selling points for me on the Kubota.
/ Kioti Grapple Buyer beware!!!! #45
A-36 on the table:
I couldn't say what type of steel mine is made out of, but it must be enough as I have and use an MTL 72" XT Series root grapple on my skidsteer and I put some serious pressure on it and haven't bent it in over 2 years worth of use.
/ Kioti Grapple Buyer beware!!!! #46
It wasnt always that way. Kubota got smart. No one wants a proprietary quick 'tach. John deere for instance.
/ Kioti Grapple Buyer beware!!!! #47
And an adapter plate to go JD to SS is about twice the money as an adapter plate to go SS to JD.
/ Kioti Grapple Buyer beware!!!! #48
Just a word of caution, this thread is 2 + years old.
/ Kioti Grapple Buyer beware!!!! #49
A-36 on the table:
A-36 is used for many grapples. It is also used on MTL lowest cost grapples i.e the ones that cost 1100-1200 dollars including shipping. They do use thicker material though hence the weight. Their next class up uses high tensile strength grade 50 steel.
Those 1100-1200 grapples are tougher than you think, and have lots of happy customers that didn’t break the bank on a grapple. Yes, they are a little heavier, but not that much, and they are priced right for many people.
/ Kioti Grapple Buyer beware!!!! #50
That'd be me. My MTL grapple is one of the most used implements I have.
/ Kioti Grapple Buyer beware!!!! #52
You should be reaching out to the Kioti dealer that you purchased it from and have them file the warranty for you. Kioti Customer Service is not who you should be talking to. All warranty is handled by the dealer.
/ Kioti Grapple Buyer beware!!!! #53
You got one of the best values in grapples around. Its a well thought out and functional grapple.
If I was concerned about weight I would have bought the 48" rather than the 54. Those extra 3 inches on each end don't do squat.
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
BUYERS PREMIUM & PAYMENT TERMS (A59914)
BUYERS PREMIUM &...
2019 Kubota SVL95-2S (A64126)
2019 Kubota...
PREVIEW DATES AND TIMES (A65563)
PREVIEW DATES AND...
