Titan has sale on SSQA adapter
   / Titan has sale on SSQA adapter #1
m5040
CT
Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
   / Titan has sale on SSQA adapter #2
Is the 1430 plate the same as the 1445 plate which is 12 1/8 tall x 23" wide?
The only PT quick connects that interchange between machines are the 422/425.
the 1445 will be a lot larger then the 1430, the difficult part will be to determine if you could still make it work with little modification. Obviously anything is possible.
With the 1430 adaption, I just cleaned the paint, got the right angle, welded in place then added a heel brace from the plate to the adapter at the bottom where it is furthest away.
I used a much heavier adapter for my 1460.
None of this applies to farm tractors
I don't think anyone was offering
   / Titan has sale on SSQA adapter #8
Sure does. I could install an I-Match SSQA adapter on either of my M9000's and they are classified as farm utility tractors last time I checked at least. Both in the excess of 92 stub horsepower and not a compact by any means.
I can install an I-Match SSQA on either and limit myself to only I-Match attachments or I can (and have) installed a normal SSQA two pin quick attach and mount anything SSQA. Why most SSQA attachment's have the extra slots stamped in the mount plate... so you can mount anything including I-Match attachments.
Sure looks like a farm utility tractor to me... How about you???
   / Titan has sale on SSQA adapter #9
Or maybe this one... You decide... Not something to mow the lawn with or play with far as I can ascertain....lol
Your pictures are all showing rear mount equipment that looks to me like a farm application for hay.
This post is for a different type of machine that is low profile for uneven ground where the implements all mount in front of the operator and are hydraulically driven. They have their own style quick attach and as the 1st post alluded to, Titan has an easily converted adapter on sale. Not to be confused with a 3pth hitch application, but just a way to use the framework for an SSQA.
I have personally found it to be beneficial for use with Ryan rotating log grapples, tree sheers and tree pullers, forestry mulchers, Bobcat stump grinder and even fork lift forks. All equipment that if used on your Kubota tractors would be like trying to use normal scissors to cut paper with your left hand. I know this because I tried with my Kubota M5030 and M6040. Both tractors remained parked in the barn most of the year because of the superiority of the Power Trac design in my experience and application.
Forum members like Torvy that comment "Couldn't pay me to buy something from them." are unclear as to if they meant Titan or Power Trac, can go on facing forward in their farm tractors while operating implements directly behind them. At some point they will get too old to look back for hours when there is a alternative to use front implements. Keep an open mind, To each is own, and the job you need to do and how insistent you want to be to do it the old way, because that is the way we always did it.
Broom Attachment (A59228)
Broom Attachment...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
24in pin on excavator tooth bucket (A56438)
24in pin on...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A60460)
2019 Caterpillar...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
