Massive storm clean up
/ Massive storm clean up
Probably one of your employees on your tractor heading to the next field. Jon
That’s one of them there expensive Deeres
/ Massive storm clean up #223
Still churning through logs. The end of the log piles is in sight, but then the brush starts.
As you can see on the right, one of about 20 large brush piles. NO. I can’t burn them. lol
Here’s my “logging road” I made to get logs up the steep hill and to a staging area where I cut them to length. I been cutting them 11’ for my 12’ dump bed.
Astonishing mess to clean up. Goes on for 1000 yards.
Saws holding up very well. Sharpened quite a few times as one can imagine.
Return trip empty back to the Customers farm. Damn farmers always slow you down, right?
Here’s what I need to finish off the brush.
Can't tell for sure but it looks like that farmer has a do-all with a rolling basket behind it, greatest tool ever for leveling a tilled field IMO. Looks like you have got this project to the 4th quarter with a lot of hard work.
Yes, I know him. He and I farm land that is contiguous??? I think that’s the word….
/ Massive storm clean up #225
Looks more like a chisel plow with rolling baskets to break up the clods to me, but hard to say at the distance.
/ Massive storm clean up #226
Could be, I couldn't tell for sure, for some reason you rarely see a chisel plow down in these parts, but they seem to be more prevelant in other parts of the country.
Rented a CAT D-3 LPG to push piles into ravine in the woods.
Logs have all been hauled.
Next I will be shuttling piles from a distance to the ravine.
It has worked very well. Wouldn’t mind one size bigger for weight, but it got the job done.
Now onto “shuttling” brush.
/ Massive storm clean up #232
I remember seeing you were looking for a new grapple. Is it your plan to use the tractor and grapple to shuttle the brush?
Are you allowed to burn? In Virginny, we make piles close to where we are working and burn there. We usually dig a shallow wide ditch and keep the pile small, feeding it all day long.
I thought I remember a mention in this and other threads that many of your customers are "fussy" about such things as burning.
/ Massive storm clean up #233
That's about the weight of the Komatsu I have been using. It's low ground pressure also. It seems like the LGP units do spin the tracks quite a bit. Maybe they don't have as high of grousers?
I tried my forks and HLA log grapple for a few hours yesterday and they worked very well. I think I can skip the brush grapple altogether. These HLA log grapples are fantastic for cleaning up downed trees from logs to brush. I will keep going this way until the ground gets too steep, then I may have to switch to a skid loader on tracks. Hopefully the tractor and log grapple can do all of it.
Yep no burning the brush. I am shuttling it to a ravine in the woods where it is being stored while it breaks down. Customer doesn't want any burning or chipping anymore.
Here’s some pics of me in the Challenger shuttling brush from piles further away to the ravine in the woods.
I had to cut a few trees down to access the ravine. Notice all the trees fallen in the background (and my broken mirror) ?
Here’s my view of the ravine from the ridge up above. The groundskeepers have already planted several new Loblolly Pines as you can see near the old stumps.
The owners of this estate own 2 tree farms, 1 in Florida and 1 in Georgia. Several thousand acres of Loblolly down there.
Grapple works pretty well. Doesn’t drop too much on the drive down.
One more dumping down at the ravine.
/ Massive storm clean up #237
I was using a new holland that’s a little bigger than my D3 before I had the D3. I think the D3 is about 9 tons and the new holland was 11 tons so actually a decent amount bigger. The D3 with the regular tracks definitely seems to bite the ground better.
The D3 had all the power & comfort, but more weight would been better.
It worked out fine. I was surprised how gentle it was on the ground.
Visibility was lacking.
/ Massive storm clean up #239
My D5 is very much lacking comfort compared to my D3 but it pushes way more. I can actually finish grade smoother with the 5 and that was the plan for the D3.
/ Massive storm clean up #240
They do make a difference.
2005 International 9200 Semi Truck (A66285)
2005 International...
2018 DODGE RAM 2500 (A65643)
2018 DODGE RAM...
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
(4) Texas Built Stand Alone Livestock Panels (A66408)
(4) Texas Built...
250 Gallon John Deere Sprayer (A65579)
250 Gallon John...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
