Issues already? New mx5400 steering issue.
   / Issues already? New mx5400 steering issue.
Looking at the areas I bolded above, I don't think this is unusual. But I'd check to be sure your front tire pressure is high enough to reduce resistance, and be sure your RPMs are high enough to keep your hydro system working at its full capacity. A very heavy load in the air, and trying to turn the wheels while not moving, is pushing your hydro to it's limits.
Thanks. I’ll check that this morning before going any further.
   / Issues already? New mx5400 steering issue. #22
Multiple things to digest here.
First, steering doesnt sound normal. It is normal to be able to force the steering wheel to turn and make the wheel NOT move like if its in a rut of something....but my experience is that takes quite a bit of force from the operator. So sounds like something aint right.
I wouldnt balk at the dealer too much for overlooking a missing zerk. As to loose bolts....can you take a pic of just what bolts you tightened? I cannot think of very many bolts on my quick attach.....and the ones that are there are usually adjusting bolts for for the mechanism (with a spring too) and if you go messing with them you may make things worse.
Finally....where in the world on you 3PH do you have grease zerks?
Attached are pics of the zero fittings on the 3ph and bolts on the loader (the ones with the lock nuts). You can see one that’s still loose on the bottom.
Here’s a video. I swear the steering was a lot softer yesterday. Maybe I’m misremembering or temp is a factor.
thoughts?
   / Issues already? New mx5400 steering issue. #25
The pin retaining bolts on the loader aren't supposed to be "tight", that's why they have nylon locking nuts on them. The pins need to be able to have some movement, nuts only need to be on enough to get the nylon nut to work.
As for the top and side link, they typically have grease on the threads from the factory and don't really require greasing right away, all it does is make a mess.
As for the steering, almost sounds like the orbital valve has an internal leak.
Also make sure all the steering linkages to the valve aren't slipping, not sure if the MX is like the Grand L where the valve is up front and there is a shaft with multiple joints that runs to it from the steering wheel.
   / Issues already? New mx5400 steering issue. #26
Just saw the video, that looks normal, did you take a video of trying to turn it with the engine off?
   / Issues already? New mx5400 steering issue. #27
Video shows normal steering.
I agree with TMGT on the other two issues.
Sounds to me like you have a perfect working tractor and an overreaction to loose bolts and dry grease zerks. Glad I asked for pics. But everything perfectly normal. Now everything is still normal only you have bolts tighter than needed and a greasy mess on your toplink and sidelink
   / Issues already? New mx5400 steering issue. #28
Do you know where in the operations manual it explains how the steering should operate? I looked all over and couldn't find anything explaining what you just stated.
It don't but the WSM (Workshop Manual does, in detail). Of course you have to buy that and it ain't cheap.
   / Issues already? New mx5400 steering issue. #29
Everything described sounds like normal hydro steering to me. I was confused when I bought my (used) tractor too. As long as it steers well when moving, you're good.
   / Issues already? New mx5400 steering issue. #30
Am I the only one that find odd that the OP's tractor can't even steer to full lock with barely a full bucket of loose dirt on a packed surface? Is that really normal steering operation for Kubota tractors? I mean, if it was sitting on loose ground, I would give the benefit of the doubt but that's not the case.
The only time my tractor wouldn't steer with a bucket full of dirt (including the heap), was because left wheel was sitting on the bottom of a furrow and couldn't physically turn left or right, otherwise it will just turn easily, with the tractor not moving.
Also, with the amount of money you guys in the US pay for PDI, I would at least expect grease on all the fittings.
I feel the same way. Is the tractor really not supposed to be able to turn to full lock with a loaded bucket?
   / Issues already? New mx5400 steering issue. #32
I would expect it to be able to steer with a simple bucket fully loaded of dirt or something. Now, if you were maxing out the loader capacity, then yes, I wouldn't expect it to steer much but a simple bucket full of dirt is nothing for a tractor the size of the MX.
Yeah. Don’t know what qualifies as maxing out unfortunately. That load is easily lifted if that helps.
   / Issues already? New mx5400 steering issue. #34
Except the broken zerk, your fit and finish issues are "normal". Back those lockouts off some leaving just a couple threads beyond the nylon. I'll check my mx4800, but if you can easily lift a load, you should be able to steer well. Do you have some rear weight on the tractor? It will perform better if you do. You cannot expect that tractor to lift a full pallet of bricks. Bricks are heavy. I have pallets of retaining wall block at 2200 lbs and it can lift it, but it is really hard on the equipment. I have pallets of paving stones that it simply won't get more than an inch off the ground and it feels like the axle might break! But at those weights, it will steer. I'd have the steering looked at most likely.
In normal operation, the steering only takes one finger. Its real light.
I'll see if I can load up some 3/8 gravel and replicate your issue. You video would have been better showing the tractor lift the load instead of starting with the bucket full. If would give us an idea of the weight.
Didn’t know about the bolts. I’ve set them back the way they came. Either way, my point with the back story was just to give context on why I’m paranoid. That’s all.
I’m not lifting a full pallet of bricks. The mx wouldn’t event be able to tilt that much less lift it. I’m splitting pallets into 3rds roughly 5-6 stacks high. It was light enough for the loader to lift up above the hood and tilt fully without issue. It didn’t seem like a heavy load. I basically loaded it until it felt bouncy and then took a full row of bricks off. Never came close to maxing out the hydraulics.
I have rim guard ballast in the rear tires. I also keep the box blade attached.
The bucket load is shown in the video. It’s crush n run if that helps. Roughly 3/4 full. No struggling lifting or tilting the bucket with that much in it. This was in the middle of me moving some to spread spots the trucks missed on my driveway.
I don’t know what to think. I’ve had other people who own the same tractor tell me this is absolutely not normal. Sounds like most are suggesting to get the dealer to take a look, so I’ll get them out here tomorrow
Thanks!
   / Issues already? New mx5400 steering issue. #36
I guess maybe have the steering checked out??? But I never try and turn knock to knock with a full load. Why? Not very productive at all. Start moving and turning at the same time.
   / Issues already? New mx5400 steering issue. #37
Have double checked all the hydraulic fluid levels? Hydraulic can go do some after delivery and use. Especially if you attached other attachments.
While your at it, double check all the fluids. Don't forget the front axle.
I noticed it when I couldn’t back up around a corner. It does it when moving at slow speeds as well and in the brush with no load. It's just easier to demonstrate with the tractor stopped.
   / Issues already? New mx5400 steering issue. #39
There might be a steering or low hyd fluid issue here but set that aside for a moment. Also, check your front 4WD axle since they all need SUDT added.
Now, even if the dealer did everything right by farmer terms, I think they fail to understand the Kubota buyer. They are smarter, better heeled, more demanding, less forgiving and often know more about the product than the dealer. They don't want second best and don't mind spending for what they want but want quality above all else.
So, the dealer that delivers a tractor with a broken zerk and no extra grease might be OK for a farmer buyer since they know the drill. But the Kubota buyer didn't really sign up for that and doesn't like it. A saw a dealer years back smirk and chuckle in front of a $40,000 upscale Kubota buyer because they asked a newbie question. I recall thinking how disrespectful that was and was embarrassed for the man.
Well, that dealer is out of business and the people that bought it jump through hoops for buyers, especially Kubota people. I ordered a $6 part that I kind of needed soon but was a week away. Without me asking, the dealer got it somehow and called the next day to say it was in. That's understanding Kubota people.
My new things come through with visible grease on the fittings and I know they left it that way on purpose.
So, the dealer that delivers a tractor with a broken jerk and no extra grease might be OK for a farmer buyer since they know the drill. But the Kubota buyer didn't really sign up for that and doesn't like it. A saw a dealer years back smirk and chuckle in front of a $40,000 upscale Kubota buyer because they asked a newbie question. I recall thinking how disrespectful that was and was embarrassed for the man.
Thanks for the suggestion. I’ll check the axle fluid as well. Agreed on other topics. This is my situation exactly. New owner. Had a large project this week and ended up buying kubota b/c I didn't want to be dealing with issues while trying to get the work done.
2018 Ford F-350 (A55973)
2018 Ford F-350...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A61307)
2023 Top Air ATV...
2019 Chevrolet Silverado 1500 RST 4x4 Crew Cab Pickup Truck (A59230)
2019 Chevrolet...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2016 CATERPILLAR...
Adams 5 T Fertilizer Spreader (A61307)
Adams 5 T...
