Waterproof Solderless Heat Shrink Butt Terminal on sale
/ Waterproof Solderless Heat Shrink Butt Terminal on sale #41
That's what I said.
?? Your first post in this thread that I see was tonight at 7:07 pm? Mine was 3 weeks ago. But at any rate, if we agree, that's called a consensus...
And yes, most common use electrical solder used to be 60/40 tin/lead. These days it's mostly lead-free, and that's mostly tin. No, it's not the same as silver solder (usually silver/copper/zinc, in order of most to least composition percentage). Also, "heat and melt" shrink solder connectors are very unlikely to use legit electrical solder - more likely to use some sort of bismuth alloy "low-melt" solder.
/ Waterproof Solderless Heat Shrink Butt Terminal on sale #42
I have a somewhat related question on the subject of low-voltage wire connecting:
What do you all do for T-joints (like you might find on trailer wiring)?
I'm happy to solder joints, but how do you seal them after? Even putting 2 of the wires inline makes it hard to get a good seal with heat shrink.
/ Waterproof Solderless Heat Shrink Butt Terminal on sale #43
Liquid tape.
/ Waterproof Solderless Heat Shrink Butt Terminal on sale #44
Adhesive lined heat shrink.
/ Waterproof Solderless Heat Shrink Butt Terminal on sale #45
Instead of the end with the two wires coming out directly side by side, I separate them a bit and while the heat shrink is still warm and melted slightly, squeeze the area in between the two wires with a pair of needlenose pliers. You don't squeeze the crap outta' them, just enough to make the tubing conform to each wire and stick together.
/ Waterproof Solderless Heat Shrink Butt Terminal on sale #46
Somewhat water resistant junction box/bus bars work great on larger trailer wiring. Crimp style split splices make me cringe. As mentioned earlier Marine style heat shrink has adhesive/ sealing properties on inside. Quite a few different options out there not requiring soldering.
2018 TAKEUCHI TL8 SKID STEER (A59914)
2018 TAKEUCHI TL8...
Gasoline Concrete Mixer, Honda 8.0 Engine  (A62679)
Gasoline Concrete...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
John Deere 6130R (A64126)
John Deere 6130R...
Mini Universal Concrete Bucket (A65640)
Mini Universal...
International 490 Disc (A65640)
International 490...
