A timber frame cabin memoir
/ A timber frame cabin memoir #61
I’ve only seen those used to attach deck ledgers to inside floor joists, instead of ledger bolted to rim joist.
I would have used permacolumn brackets under the posts and be done with it.
I use Adobe Acrobat to open the PDF files of my drawings. Through trial and error over the past year I have learned to click on measurements. measuring tool then right click to change scale. I looked at few PDF type readers but most do not have the measurement function. It would be nice to have program that does that and doesn't default every time you close the program plus readings in fractional inches. Currently it (acrobat) does measure feet or inches in 10ths.
I asked the lead Amish guy if it was ok to be in the picture. He said they did not want to be in pictures. I honored their wishes. It was interesting watching them climb the bents and 30' to the concrete basement floor. Wednesday it was getting them up to speed. They started to notice some of the bents were not square and plumb so they spent a couple hours redoing temporary bracing until they were happy. Maybe the contractor, who these guys are subbed through, has a wonky level. He had tow 19 y.o. kids working for him and one was first day on job. Wed my contractor showed up with replacement telehandler. The Amish crew arrived with their driver and trailer. After tweaking bracing and getting things more true they got all the East side purlins on. Thu they did the West side purlins and got 1/6th of the tongue and groove roof sheathing on. They finished the T&G on Friday and got a couple rolls of Epilay Premium on. I got to use my used SIPS groover for the first time. Slow but not as stinky as I thought it would be. Electric Foam Scoop
The nail base panels only have OSB on one side. I would say it melts at about 1" in 1-2 seconds. They were going to try to screw one panel in but I didn't have the other side grooved out. A dimensional 2x10 is put into the edge groove. Anyway they tend to keep bankers hours and left around 2:30. they do have about an 1:15 drive one way. I'll put a few pictures up when I get them on computer. I was going to hire them to put the I-joists in and maybe sub floor but these guys are way too rich for my blood. So I order my I-joists next week and will be back there by Monday to see them fini$h up.
All nail base panels and perimeter board are done.
1.East side of purlins done.
2. West side purlins done and starting on T&G on East side.
3. All T&G done
4. What my nail base panels look like. I had bought a used SIPS scoop iron to carve out the perimeter that gets a dimensional 2x10
5. West side nail base done and much of East side done. This was the start of the final day 11/14/2023
/ A timber frame cabin memoir #64
Thats an amazing roof/insulation panel 8"? You will have a tight house when done - looking good!
They call it a 10" panel. R39 I think? You also run a bead of Great Stuff Pro foam in the joints. The plan is to have a wood stove in the living room but also have a propane furnace for backup. The panel is fastened with 12" screws (they provide) into the purlins. I talked to the area lumber yard and said there is little lead time for ordering I-joists. I will probably order them after the holidays. I'm looking forward to building again and not watching someone else.
/ A timber frame cabin memoir #66
Are those t&g prestained before going up? Just wondering. Had to finish someone's new t&g after it was up, and will never do it again. Using a brush was a mess. But not having spray equipment, do with what you have. Jon
No and no plans to stain them. My parents did that in the 70's on their dream home the whole family helped build. I remember Mom up on a scaffold staining with a brush.
/ A timber frame cabin memoir #68
Hi. Can anybody tell me how a timber framed building or extension, which is clad on the outside is constructed? What I mean is is it built as a single frame with the cladding on the outside and plasterboard on the inside? Or is it built like a conventional brick and block build with an inner wall a cavity then an outer wall? So two separate wood frames with a cavity between them. I hope this isn't too daft a question but it's something I haven't been able to find on the net. Thanks.
I can tell you how I built mine. Raised the frame, sheeted the entire frame with 1x6 tongue and groove knotty pine, (2x6 T&G for the roof/ceiling), then framed it out with 2x6's for wiring and insulation, then sheeted the outside with shiplap and finished it off with cedar clapboards. Basically built the house from the inside out. Today I'd use SIP's, (structural insulated panels) over the timber frame, but 30+ years ago they were still using Formaldehyde and my wife has allergies.
Some companies use SIPS. Legacy designs theirs to use standard 2x6 framing cheated out to show part of the lower beams. My rim board (1.5") will sit on the outside of the bent posts. The edge of that will sit the edge of my walls. The sheathing (osb) will go maybe 2" below the top of foundation and the board and batten siding right over that. It helped sell me on the structure as I didn't want to deal with SIPS. Many years ago a member in here had a home built by Clydesdale and I think they go the SIPS route. It's how I became interested in timber frames.
After the Amish crew left I was looking at the drawings and realized a fascia has to go on before the roof metal drip edge. Ooops. I had taken about 2 weeks off from the project due to weather and visiting my mom over Thanksgiving. She lives over 4.5 hours away and had not been up there since Spring. So last Tuesday I rented a towable man-lift for a week. A buddy calls me up before I arrive at job site asking if I need some help. Sure come on over. He was here for for about 24 hours. It was nice having a ground guy. It took at least a day+ to get each side done. All boards are rough sawn lumber. First it gets a 1x8" then below that a1x10" then over the top of the 1x8 it gets another 1x10. The lumber was about 16' long so too long and often too bowed to use as one piece. I would screw in some temporary wood block to help hold one end. The basket on a Haulotte 3522a is a bit small and I'm too overweight to have myself and friend in basket to hold boards. I had some wood screws from maybe Dad's stuff after he passed. They were phillips head and stripped out pretty easily when using to attach temporary holding blocks. Or they broke the phillips head bit in my little impact. Another issue I ran into was switching from Metabo to DeWalt brand collated nails. Something about the collation goop would cause issues between nail clips in my Milwaukee pneumatic nailer. They were cheaper but learned a lesson there. Also, moving the lift and getting it to level on such a sloped property took a little finesse. I had to move it 7 times for a 4 sided roof line. I could have avoided that with the 45' lift but it was $150 more for the week rental. I got the 3522 for $599 +tax which is in my town I still own a house in. It's the best rate I have found. The boards would sometimes be bowed from sitting for a year so a long bar clamp would take that bow out as I worked my way along nailing. I still haven't had time to order my floor I-joists and rim board but that will happen soon.
With the holidays I got sidetracked. One thing I have found out is 1.5" rim board x 14" is hard to find. The kit provider said I can get 1-1/8" rim board and scab 3/8" plywood on it. The lumber yard where I currently own a house (Sikeston) said they could get it awhiole back. Well everything was good until the guy called the order in and found out the 1.5" they carried was more like a LVL product and another 2$ per linear foot. Luckily I was chatting with the head cheese while his son was on the phone with the vendor placing an order. So they gave me back my check and will get 1-1/8" rim board from same place I ordered I joists from or Menards. My I-joists are ordered from a lumber yard in Mt View Mo. They also ordered a few short LVL's needed to frame around the stair opening and some single/dual hangers.
I've started on nailing down joists. A very slow process by myself having to cut about 2" of each one. So framing will be coming up and many windows I have are shown as 36"x48." I have not committed to a window brand yet but are all the manufacturers similar in rough opening? There's a lumber yard 50 miles away that carries some better brands and I plan to talk to them for feedback. I plan to install the windows at a later date when my old house has been sold. The current goal is walls sheeting then take a break to sell my current home.
/ A timber frame cabin memoir #73
I would suggest picking your window brand and sizes before you start your framing, as you need jacks, and headers and the opening a 1/2 " larger all around. Check to see if you need egress/exit windows too - I think 36x48 may qualify size wise, but you may want to go a bit taller like 36x52-54". Also for exterior doors/patio/sliders to match but most of those are standard sizes 6/0x6/8 - 3/0x6/8 etc.
For windows you have all the big brands - Anderson, Pella etc., and if you are OK with white, and standard stock sizes, and build your own jambs etc. they can be cost effective . But if want non standard sizes, and color choices, extension jambs prices will climb very quickly.
There are good vinyl units out there - Simonton is regarded as a good product, and I used a local brand Matthews Bros based in Maine which made a very good quality 32x64 DH unit with grills and screens for $450 ea last year and the same spec in Anderson was $800.
/ A timber frame cabin memoir #74
While waiting if me I would cover the windows from the outside with clear heavy plastic film to prevent moisture penetration.
/ A timber frame cabin memoir #75
Typically, you cover/sheath and wrap the entire wall over the window openings, and only cut those openings when installing the windows.
Yes that's my plan. I can take a break and move towards selling my home over 100 miles away. Right now when I'm here I rent the neighbors cabin but the neighbor is coming back in April.
/ A timber frame cabin memoir #77
Caver - I saw a build recently on interior finish instead of extension jambs and trim, they drywalled extension jambs and corners, with a flat 1x sill piece. Made for a clean look and no other trim needed. May not be your style, but i can tell you it takes a lot of work and wood, painting and caulking to trim a window out - about 60-80 LF of 1x material or more.
/ A timber frame cabin memoir #78
You really need to know the windows first and find out the RO requirements. +1/2" on both sides and the top is common. You can, and I would argue should, add 1/2" on the bottom too and put a piece of beveled siding clapboard under the window before you make the window pan to encourage any water that gets in to go back out. Then a couple plastic shims under the window to allow the sill to drain. And finally don't seal the window to the housewrap on the bottom - sides and top only. You seal the window to the sill on the inside only and then fill gaps on the sides and top with low expanding foam (or possibly sealant - there are both schools of thought on this...)
/ A timber frame cabin memoir #79
If I'm buying windows off the shelf, like Home Depot or Lowes, I go to the store and measure the opening. They will have the exact measurements on the packaging too, but I want to put a tape on them first. Windows are either exact measurements, or they are half an inch less then what they say they are.
A 36 inch wide window could be exactly 36 inches wide, or it could be 35 1/2 inches wide. Whatever the exact width is, I frame the opening half in inch bigger. This gives me a quarter inch on each side to fit the window into the opening, and still have plenty of flange for sealing the window.
I personally like to caulk the seal, and then tape it with ZIP Tape. I also like to use Hardie Screws to attach the window. But that's just me, I really like Hardie Screws!!!
If you are having windows custom made, then just tell them what our openings are and they will order the windows half an inch smaller then your opening. Cost for custom made windows isn't much different then off the shelf.
I personally prefer metal window frames over plastic ones. The argument for plastic, or vinyl, is that it doesn't transfer outside temperatures like metal does. The argument against plastic is that they are ugly, bulky and they don't open as easily as metal windows do.
Be careful of the "extras" that some of the windows try to add on to sell for more money. They will be some kind of energy saving gimmick that you will never notice or see any benefit from. Buy windows based on what you like the look of, the way the window opens, and how many panes of glass you want. 2 pane is the standard, 3 pane will give you a higher R value and sound quality. I've only seen 4 pane once, and that was close to a major airport where the jet engines where very loud.
Anyone use Windsor windows? I like they are in the midwest and this window guy on YT seems to like them. Meeks lumber down in West Plains are a dealer. The place I got my I-joists from I think can get Andersen. I have to figure out all this double I-joists, hangers and fillers for my stair opening so working on that today, just decided to take a break. Still waiting on the roofer. He said he's busier than a cat covering up sh*t.
HD Round Bale Feeder (A66408)
HD Round Bale...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2025 Mini Excavator Rake Attachment (A64553)
2025 Mini...
2014 Ford Expedition SUV (A64557)
2014 Ford...
CHEVY DUALLY TRUCK BED (A65643)
CHEVY DUALLY TRUCK...
