Hay Ride Wagon Build
/ Hay Ride Wagon Build #21
As others have mentioned the wagons with the pivoting front axle should not be considered at all. What ever wagon is used should have tie rod steering.
Also something else to be aware off many of the older farm hay wagons do not have bearings in the wheel hubs they are just bushings. When woreout they can be a nightmare to recondition to be usable.
But here is a brand new running gear, in many areas you can find a lighter set (6 ton) for about half that,
This adjustable tongue is a very worth while option makes hitching up much easier,
you just backup to within 3 to 6 inches of your drawbar hitch hole unlatch and extend the tongue,
drop in the hitch pin then backup to latch the tongue in place and go.
On many of the newer running gear brakes are an option, if you are using a light tractor brakes and a manually operated controller would be nice, especially if your tractor does not engage 4wd when the brakes are applied.
/ Hay Ride Wagon Build #22
I wonder if you can find a old pickup truck, like a Chevy 1500 with leaf springs on it, and strip it down to the frame?
Thanks Lou! I did not know some of the older gear did not use bearings. Bushings would be more problematic. I may have to look at newer stuff and plan on doing some traveling. Shipping I would think is pretty expensive.
One thing I will have to determine is if I can get it on my 20‘ trailer. 6’10” inside the top rail.
I wonder if you can find an old pickup truck, like a Chevy 1500 with leaf springs on it, and strip it down to the frame?
I have candidates for that already but would rather have an actual running gear.
/ Hay Ride Wagon Build #25
On a new or newer one I would be tempted to just put it behind a pickup and go. But one nice thing about all the running gear that I have worked on the "poles" or reach are removable and you would have the rear V with the wheels and the front V with the wheels and the tongue can be folded up or one bolt removes it so it can be easily fit on most any trailer.
/ Hay Ride Wagon Build #26
My friend is Mennonite and has a houseful of people right now. Possibly I can get some pics Wed. I don't remember exactly what it looks like but it's pretty, functional and pleasant for people to get on with nicer clothes.
Your wagon frame looks good with the tongue arrangement so you can back it up. A regular hay wagon tongue is difficult to back up. My friend's wagon I think is an Oliver with small springs built in. Here are a few ideas off the internet.
/ Hay Ride Wagon Build #27
I have a farm wagon because I built one with brand new - ten ton - Horst running gear. As I remember - total cost was right around $1800. That was twelve years ago. I'm FINALLY getting pretty good a backing the thing up.
The two main beams - paired 2x12's. Also - 1" plywood - sandwiched between the paired 2x12's. Glued and screwed together. The cross members - 4x4 pressure treated timbers. I used steel gussets to tie the 4x4's to the main beams. The decking - 5/4 tongue and grove exterior grade plywood. The paint - a mix of all the leftover latex paint I had.
The deck is 8' by 12'. I had a local welding shop make the ten stake pockets.
Things I should add now. I've used this wagon - several times - to pull folks around the property. It can be a rough and bouncy ride. After the first time - one layer of bales completely across the bottom. A second layer form the side walls and forward end wall. A heavy rope across the wagon at each stake pocket( three ropes). For folks to hang on to and not get bounded out. I have a higher set of stakes and side boards for these "hay rides". The side boards are 2" lower than the two rows of side bales. This is really a fun ride. I pull them down to the far end of the property and we have a bonfire and weenie roast. This is a late fall or winter activity. When everything is damp or there is snow on the ground. Always concerned about wildfires.
Very nice build. Something similar would be perfect for my use. Thanks for sharing.
/ Hay Ride Wagon Build #29
I take the grandkids for hay rides on a little 4x8 tilt bed that I keep at the camp for firewood and shale hauling.
Low to the ground and holds plenty of little ones. Basically drive walking speed through the woods.
/ Hay Ride Wagon Build #30
I’m very similar. I use a 5x8 trailer filled with hay bales. Kids have a blast.
I look forward to that. Because mine are so young I need the adults to ride as well. We are having so much fun this morning with the kiddos. They are already asking me for tractor rides.
The funny thing is everyone wanted the kids to call me Pops and my new Grandson just started calling me Grandpa. So I guess I will be Grandpa from now on. :ROFLMAO:
/ Hay Ride Wagon Build #32
My Horst running gear is an exact duplicate of the AgriMaster gear that LouNY posted. Right down to the extendable hitch. For me - this extendable hitch is a real life saver. Hook up the wagon - go to where the pine trees are - disconnect and use the grapple to load the tree trunks on the wagon. I now have a wagon that no matter how much @#$% - I CAN NOT move it. Back up as close as possible - the extendable hitch comes into play and hook up is easy.
Using brand new gear - the build was very easy and a lot of fun. I got a schematic off a web site. I think I just entered - "farm wagon build".
The empty farm wagon is heavy enough that I'm not able to pull it around the yard. I use my ATV to do that.
Yes - my great grandkids enjoy riding around the property on the farm wagon. Without any type of suspension it can be a rather jolting ride. I go slow. Don't want to bounce anybody out onto the ground.
New Is likely what I will be doing as well. I look forward to years of them having fun with me on this place.
/ Hay Ride Wagon Build #35
They asked if we can ride in the tractor now. I said we need to do presents first so they just tore into them. :ROFLMAO: So freaking cute.
Great picture.
Christmas is very special with little ones around!
Merry Christmas.
Definitely one of favorite ones so far having these special youngsters here. Merry Christmas
/ Hay Ride Wagon Build #37
K5lwq
No chance for me to access neighbors parade wagon. It's buried in the back of a big barn and tarped. So, I'm looking forward to your progress.
Here are some over the top ideas
No problem sixdogs. Thanks for trying. I definitely will keep this thread updated.
/ Hay Ride Wagon Build #39
Nice build!
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
LMC Ag 3pt 300 Gal 54' Boom Sprayer (A64126)
LMC Ag 3pt 300 Gal...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
