/ The guy that put the engine internals together says "The rings are not seated yet end the smoking is normal. Just give it a couple hours of work"
#41
Oh OK Well when the Ford is finally dialed in It will be a pleasure to use.Previous Tractor repair shop. Discovered the loose bolts and the gear was one tooth off when I took it apart
Ah, enough to make a mess but not get overly excited about.The muffler is just sat up there at this point since I have not put the hood on yet. Black ink like oil runs out of the junction between the muffler and the manifold. It runs down the motor and the fan blows it back on the valve cover and gas tank. It has smoke coming out of the muffler before the manifold is even warm.The amount of oil is hard to estimate. The oil level is at the full mark and has not gone down after 45 minutes of run time at 1000rpms to 1400rpms
Thanks
The manual one is an actual oil pressure gage with a short copper tube running to it. The electric one has a sender. I have a separate Low Oil Pressure alarm sender to a obnoxious buzzer. I put the manual one on for initial start up and to check make sure the electric one was reading right. .......Am I paranoid about burning the new motor up? Maybe...lolAh, enough to make a mess but not get overly excited about.
” He put clevite on everything.” If he was pretty generous with it, that would account for some smoke.
” The pressure coincides with the 2 oil pressure gages. one electric one i installed on the dash and the manual one on the side of the motor.” Both off the same sending unit? How do we know that one’s accurate?
Thanks! It seems like a beast with those big 4wd front tires. The power steering is smooth as silk....like it is not even touching the ground. The best part is no electronics.Oh OK Well when the Ford is finally dialed in It will be a pleasure to use.
Old Fords are wonderful machines I Dare say equal to John Deere.or Kubota..![]()
The picture of the block is interesting. That does NOT look like a bore/hone done by a machine shop. That looks like no boring was done but instead just a clean-up with 400 grit sandpaper. Each bore looks different (odd) and the left one still has a vertical mark that wasn't cleaned up.-I do not remember an obvious cross hatching on the piston walls. I attached a picture and it looks like no to me.
There were ridges and water damage. The shop said they did not need sleeves since 040 cleaned them up. Is all I knowThe picture of the block is interesting. That does NOT look like a bore/hone done by a machine shop. That looks like no boring was done but instead just a clean-up with 400 grit sandpaper. Each bore looks different (odd) and the left one still has a vertical mark that wasn't cleaned up.
I will....ThanksIf and when you do remove the top cover to access the PTO, you should also reseal the 3pt piston and examine the 3pt cylinder bore.
I will get the invoices. and i don't have any pics before the head was on thanksThat block does not appear to be surfaced, by a real surfacing stone grinding or a fly cutter.
The before rebuild shows a LOT of piston to wall clearance so the bores and or pistons were worn.
The one cylinder shows a vertical scratch that should not be there with a fresh re bore.
I hope somebody isn't using word salad to make a 400 grit hone job sound like boring .040" over after using a ridge reamer to remove pistons and a heavy hone job.
Are there any pictures of the fresh engine with new pistons and rings without the head on it yet?
How about a parts and labor bill showing new .040 over pistons and matching ring set etc.
Sorry, just a bit unsettled looking a bit closer at the pictures provided
dannysengineportal.com
Nope. Not at all normal. Should have at least 30 to 40 psi. Never should have oil running out of the exhaust. I have built more than a few and never had this happen. 40 over is a lot in my book. Not saying this is the problem but that is a lot to bore.The engine only has about 30 or 45 minutes of runtime on it right now and that is basically been slow and fast idle. It is boiling black oil out of the exhaust manifold that runs down the engine. He said since it is Florida that it is not necessary to put a thermostat in it. I noticed that it never warmed up more than 110 or 120°. I put the thermostat in it and let it warm up to normal operating temperatures. When it warms up to normal temperatures the low oil pressure alarm goes off when the idle goes below 1000 RPMs. This coincides with a manual oil pressure gauge that I put on the side of the engine. We trailered it over to his shop and he said that the oil pressure is normal that it should be about 10 psi per 1000 RPMs. So at 1000 RPMs an oil pressure of 10 psi would be OK. He suggested using Lucas oil treatment and thicker oil. It currently has 15 W 40 oil in it. In his defense he ran the tractor around the property for a short time while riding the brakes to put some stress on the engine and it did seem like it was smoking less. The oil pressure issue remains the same. So my question is what is a good oil pressure at an idle on a brand new engine. I understand that a new engine will smoke when it is first started. How much is too much how long before it should stop or go down to the minimum. I am certainly not an engine rebuilder but I have done everything on this tractor except for actually assembling the internals of the engine. I feel a little bit uncomfortable about putting a big bush hog on it and running it for a couple hours without checking with someone else to see how they feel. What do you think. Thanks for your time and attention. OK
Sorry I should have included that information from the beginning.
-Bored 040 over
-Machined Crank
-New Pistons all
-New Rods all (one was bent)
-New Rings
-New Injectors
-New Valves
-New Guides
-New Oil Pump
-New Cam Bearings
-Lifters looked perfect just cleaned
-Push rods checked and re-used
-New Idler timing Gear
-New Water Pump
-New Radiator
I dealt with the machine shop dropped and picked up. The machine shop got the Reliant rebuild kit and did the cam bearings, the rings were installed when I got the pistons in the boxes. They said everything was correct and ready for assembly. I have done mechanical work since I can remember and do pretty well on any project BUT, I wanted an experience builder to actually put it together. I have put engines together but I am NOT "The Engine Guy"
The guy that put the internals together came to my shop with his father and put it together. I had everything cleaned, labeled, and laid out on a table like a surgery before the doctor gets there. I watched them and waited on his every request (tools, bolts, supplies...etc). He seemed to know what he was doing. No big red flags on the build.
The cylinder bores look lousy from what I can see of the picture. Not honed or cross hatched in the least little bit.The engine only has about 30 or 45 minutes of runtime on it right now and that is basically been slow and fast idle. It is boiling black oil out of the exhaust manifold that runs down the engine. He said since it is Florida that it is not necessary to put a thermostat in it. I noticed that it never warmed up more than 110 or 120°. I put the thermostat in it and let it warm up to normal operating temperatures. When it warms up to normal temperatures the low oil pressure alarm goes off when the idle goes below 1000 RPMs. This coincides with a manual oil pressure gauge that I put on the side of the engine. We trailered it over to his shop and he said that the oil pressure is normal that it should be about 10 psi per 1000 RPMs. So at 1000 RPMs an oil pressure of 10 psi would be OK. He suggested using Lucas oil treatment and thicker oil. It currently has 15 W 40 oil in it. In his defense he ran the tractor around the property for a short time while riding the brakes to put some stress on the engine and it did seem like it was smoking less. The oil pressure issue remains the same. So my question is what is a good oil pressure at an idle on a brand new engine. I understand that a new engine will smoke when it is first started. How much is too much how long before it should stop or go down to the minimum. I am certainly not an engine rebuilder but I have done everything on this tractor except for actually assembling the internals of the engine. I feel a little bit uncomfortable about putting a big bush hog on it and running it for a couple hours without checking with someone else to see how they feel. What do you think. Thanks for your time and attention. OK
-Bored 040 over
-Machined Crank
-New Pistons all
-New Rings
-New Injectors
-New Valves
-New Guides
-New Oil Pump
-New Cam Bearings
-New Water Pump
-New Radiator
Something is not right here. Number one you need a thermostat so that all the internal parts work at the same temperature. The oil pressure is too low that indicates rod bearing, main bearing or Cam Bearing clearances or excessive. I recently rebuilt a 268 Ford engine and they had three different sets of main bearings and rod bearings for my engine I only had 20 lb of oil pressure at idle so I ended up putting the bigger oil pump in that was for the turbocharged 268. Now my oil pressure is 60 at idle when cold and 40 when hot.The engine only has about 30 or 45 minutes of runtime on it right now and that is basically been slow and fast idle. It is boiling black oil out of the exhaust manifold that runs down the engine. He said since it is Florida that it is not necessary to put a thermostat in it. I noticed that it never warmed up more than 110 or 120°. I put the thermostat in it and let it warm up to normal operating temperatures. When it warms up to normal temperatures the low oil pressure alarm goes off when the idle goes below 1000 RPMs. This coincides with a manual oil pressure gauge that I put on the side of the engine. We trailered it over to his shop and he said that the oil pressure is normal that it should be about 10 psi per 1000 RPMs. So at 1000 RPMs an oil pressure of 10 psi would be OK. He suggested using Lucas oil treatment and thicker oil. It currently has 15 W 40 oil in it. In his defense he ran the tractor around the property for a short time while riding the brakes to put some stress on the engine and it did seem like it was smoking less. The oil pressure issue remains the same. So my question is what is a good oil pressure at an idle on a brand new engine. I understand that a new engine will smoke when it is first started. How much is too much how long before it should stop or go down to the minimum. I am certainly not an engine rebuilder but I have done everything on this tractor except for actually assembling the internals of the engine. I feel a little bit uncomfortable about putting a big bush hog on it and running it for a couple hours without checking with someone else to see how they feel. What do you think. Thanks for your time and attention. OK
-Bored 040 over
-Machined Crank
-New Pistons all
-New Rings
-New Injectors
-New Valves
-New Guides
-New Oil Pump
-New Cam Bearings
-New Water Pump
-New Radiator
