/ The guy that put the engine internals together says "The rings are not seated yet end the smoking is normal. Just give it a couple hours of work"
#41
Oh OK Well when the Ford is finally dialed in It will be a pleasure to use.Previous Tractor repair shop. Discovered the loose bolts and the gear was one tooth off when I took it apart
Ah, enough to make a mess but not get overly excited about.The muffler is just sat up there at this point since I have not put the hood on yet. Black ink like oil runs out of the junction between the muffler and the manifold. It runs down the motor and the fan blows it back on the valve cover and gas tank. It has smoke coming out of the muffler before the manifold is even warm.The amount of oil is hard to estimate. The oil level is at the full mark and has not gone down after 45 minutes of run time at 1000rpms to 1400rpms
Thanks
The manual one is an actual oil pressure gage with a short copper tube running to it. The electric one has a sender. I have a separate Low Oil Pressure alarm sender to a obnoxious buzzer. I put the manual one on for initial start up and to check make sure the electric one was reading right. .......Am I paranoid about burning the new motor up? Maybe...lolAh, enough to make a mess but not get overly excited about.
” He put clevite on everything.” If he was pretty generous with it, that would account for some smoke.
” The pressure coincides with the 2 oil pressure gages. one electric one i installed on the dash and the manual one on the side of the motor.” Both off the same sending unit? How do we know that one’s accurate?
Thanks! It seems like a beast with those big 4wd front tires. The power steering is smooth as silk....like it is not even touching the ground. The best part is no electronics.Oh OK Well when the Ford is finally dialed in It will be a pleasure to use.
Old Fords are wonderful machines I Dare say equal to John Deere.or Kubota..![]()
The picture of the block is interesting. That does NOT look like a bore/hone done by a machine shop. That looks like no boring was done but instead just a clean-up with 400 grit sandpaper. Each bore looks different (odd) and the left one still has a vertical mark that wasn't cleaned up.-I do not remember an obvious cross hatching on the piston walls. I attached a picture and it looks like no to me.
There were ridges and water damage. The shop said they did not need sleeves since 040 cleaned them up. Is all I knowThe picture of the block is interesting. That does NOT look like a bore/hone done by a machine shop. That looks like no boring was done but instead just a clean-up with 400 grit sandpaper. Each bore looks different (odd) and the left one still has a vertical mark that wasn't cleaned up.
I will....ThanksIf and when you do remove the top cover to access the PTO, you should also reseal the 3pt piston and examine the 3pt cylinder bore.
