Towing Mishap
/ Towing Mishap #1
potomska
I was towing my B2601 tractor on a new equipment trailer, returning from the dealership that installed a subframe and BH70. I was on a six lane highway, in the right lane along with other cars approaching a downhill exit onto another highway. We all moved into the exit lane, slowing to 25mph and maintaining distance from the cars ahead, as I reached the apex of the hill and the ramp ahead was full, the car 3 car lengths ahead of me stopped, and an out-of-state car moved across and into the rapidly closing space ahead of me. And stopped.
I could not stop my truck (tacoma v6) in the space and time available. The trailer brakes (tekonsha prodigyp2 boosted to 3) worked fine. The truck antilock brakes kicked in, and the truck rolled into the car at 4 or 5 mph. Front of the truck was crumpled to the doors; tractor and trailer had no damage. I was given a warning for following too close. Waiting to hear from insurance.
My first accident in 53 years of driving. I suppose that I could have pulled on the emergency brake, but I didn’t think of it. I wish that I had taken more photos, and the next truck may get a dash cam. What else could I have done?
/ Towing Mishap #2
ANY TIME you are hauling a heavy load, your window of following distance needs to be widened by a great deal.. Sounds to me that you didn't leave enough space (even considering the out of state driver cutting in)...
/ Towing Mishap #4
So sorry to hear this. Unfortunately there is no exception for idiot 4 wheelers when you are towing a load. GL with the insurance etc.
When hauling horses I always kept one hand near the brake actuator for panic stops.
/ Towing Mishap #6
I was towing my B2601 tractor on a new equipment trailer, returning from the dealership that installed a subframe and BH70. I was on a six lane highway, in the right lane along with other cars approaching a downhill exit onto another highway. We all moved into the exit lane, slowing to 25mph and maintaining distance from the cars ahead, as I reached the apex of the hill and the ramp ahead was full, the car 3 car lengths ahead of me stopped, and an out-of-state car moved across a solid line and into the rapidly closing space ahead of me. And stopped.
Sorry to hear of your dilemma. At least no one got hurt.
Having driven thousands of miles on Chicago and Indianapolis freeways/toll roads myself, there're no winners when someone cuts into your lane and slams on the brakes. Yes, get a dash camera. I'm looking at them as well. Just too many times of close calls, and its a better witness than you or me.
It doesn't matter what you do, if you leave space in front of you someone else will take it, which immediately puts you in the situation of not having enough space to stop with little time to correct it. There's no planning for that other than staying off the roads.
/ Towing Mishap #8
Ouch, activating the trailer breaks may have made the difference. That's a big load for a Tacoma to stop, it doesn't have the brakes for really trying to stop a load.
/ Towing Mishap #10
How heavy of a trailer were you using?
The B2601 is rated at a little under a ton. Add a bucket and backhoe and it will push it a little over a ton, but it shouldn't really need anything more than a little utility flatbed.
Trailer brakes may need adjusting for towing empty, as well as towing loaded.
Nothing beats a little vehicle weight when towing, although one also has to consider fuel efficiency in the modern world. The Tacoma V6 is supposed to be about 4,000 lbs to 4,500 lbs. The RAM 3.6 is supposed to be 500 to 1000 lbs heavier.
I generally like to give myself a little extra space when towing, as well as slowing on descents.
Pulling your E-Brake could throw you into a spin, and may be worse than relying on the ABS.
Oh, also look at the trailer balance. If you've added more rear end weight, you may have less tongue weight than expected. A little extra tongue weight may help with vehicle brakes. I tend to like my equalizer bars for most towing.
/ Towing Mishap #11
Sorry to hear of your accident.
Situations like that is why I have a dash cam. There's so many videos on line of a person in front of another getting hit and blaming it on the rear driver rear ending them when they're the one that cut them off.
/ Towing Mishap #12
The OP stated the trailer brakes worked fine.
Trailer brakes should be adjusted properly through the controller for the load, in an emergency your trailer brake controller should have a way for you do do an emergency stop of the trailer (max juice applied instead of the load adjusted amperage).
/ Towing Mishap #13
Most load controllers have that capability. But you have to do it manually. Not much time to do that in an emergency braking situation.
A properly adjusted controller will still lock up the brakes on the trailer if your standing on the brake pedal in the tow vehicle.
None-the-less, the OP stated the brakes worked fine. His biggest problem was the likely illegal lane change in front of him.
/ Towing Mishap #14
For the guy in front of you
/ Towing Mishap #15
I don’t see what good the emergency brake would have done. Looking at your truck I’d say you hit them at more than 4 or 5 mph. Bummer.
/ Towing Mishap #16
One might want to blame the accident on the vehicle cutting in front stopping short. However, the off ramp was full, and backing up to the place the OP was driving too quickly to stop. So there was no room for anybody to go.
Slow down when one sees a bunch of brake lights and slow or stopped cars, especially when towing.
I bet if you ask any semi truck driver, they'll have plenty of stories of people doing stupid things around their trucks.
/ Towing Mishap #17
Your picture looks a lot like a Michigan limited access highway but 'assured clear distance' is the same most anywhere. When I'm pulling my Goose Neck trailer loaded, I tend to avoid limited access highways and stick to secondary roads. Truck looks totaled to me. Time to deal with your insurance company, pay your deductible and move on.
/ Towing Mishap #18
Not really, Light duty trucks today are made from basically painted tinfoil.
One of those 'bend over and kiss your butt goodbye'.
/ Towing Mishap #20
My Garmin has one built in and the high capacity SD card can record for a month at a time if necessary but not with a fiddlers darn in an assured clear distance crash. ASD is ASD and there is no defense for that. Failure to stop in time rests solely on the driver of the vehicle behind the vehicle that got hit.
Why, in a chain reaction multi vehicle crash, the last one always gets screwed.
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
