Should I buy another compact tractor or something entirely different?
/ Should I buy another compact tractor or something entirely different? #1
Bill_B
Mahindra 2615
The ole 26 -HP Mahindra tractor has served me well for the past 15 or so years but it's time for something different.
Usage is 90% for snow and ice management from November to March. I have 1000' long steep driveway that goes downhill to a busy high speed road on a blind corner. There is a retaining wall on one side of thr driveway. I'd love to just go get a plow for my truck but that doesn't work for this application. I tried and it was a nightmare.
My biggest complaints with this current set up is:
No factory cab (90% of use is snow removal in the winter), under powered tractor and PTO (running a 70" blower), the ignition switch has to be replaced every few years, no rear hydro outputs, no quick detach bucket, low lift capacity, gas tank fill too high up, and I have a hard time getting the tractor to start when it is below 0F outside.
I really like this frame size but I feel like I need to stay above 35 HP. The more HP the better especially for the snowblower.
Me and my wife are really sick of backing up to snowblow!! I don't want to get a tractor and put a snowblower on the front because then I can't use my FEL to scrape and move snow around. I have been looking at cab tractors but the more I think about it we don't really use our tractor as a tractor. So why get another tractor? I considered a skid steer with a hydraulic blower. This would fit the bill well except that they ride rough as heck, the visibility sucks, and it is a pain to climb in and out of. So that is out. Then the other day I discoved the Bobcat Toolcat. OMG this would be perfect for my situation!! Well that is until I found out how much they cost. Holy crap!! $80k?? Are you kidding me!?! I love everything about this "mini-unimogs" but why do they have to cost so much? Then add to that the fact that they rust out within ten years. Is there anything else similar that is less expensive? What about an older Holder? Those seem pretty cool and I see the older ones show up for around $5k-$8k. For that price I could keep my tractor and use it for back up and for filling up the sander on the Holder.
Thoughts?
Thanks
/ Should I buy another compact tractor or something entirely different? #2
I traded a 35 hp Mahindra 3525 2wd for a 52hp Kubota Mx5200 4wd used for mowing. The difference in useable HP is more than I expected. The 4wd has traction where the 3525 would start slipping. The MX feels more stable on hills.
Can't speak to snowblowing, but it could be that a jump in HP and tractor frame size to something like a cab in a TYM T474 or T494 might be something worth considering.
/ Should I buy another compact tractor or something entirely different? #3
It’s hard to beat a tractor with a bucket on the front and snow blower on the back for some snow removal situations. Get rid of your tractor and snow blower for a new tractor with an cab and an inverted blower.
/ Should I buy another compact tractor or something entirely different? #4
I have no inverted blower experience, but I can say a cab makes a world of difference while blowing snow!
/ Should I buy another compact tractor or something entirely different? #5
Not sure how steep you are talking... but bigger machine (heavier) with a higher center of gravity is not always your friend on the steep slippery stuff. We have a 1/2 mile long drive that is steep & there are time even chained up it is not a fun time. Sound like a Tool Cat would be the ultimate for your situation... but I get the price thing.
/ Should I buy another compact tractor or something entirely different? #6
Would a reversable tractor(turn controls to face forward or backward) work for you? They cost more than a regular tractor, but not like a toolcat. See Goldini, Antonio Carrera, and Ferari tractors.
If you go for a regular tractor, get Ag rims as they provide the greatest amount of adjustment. You will be amazed at the difference in stability/feel of the tractor.
/ Should I buy another compact tractor or something entirely different? #7
My Goldilocks sized TYM T474 is 48.3Hp and is a beast of a snow removal machine. Just turned 418h with no issues.
/ Should I buy another compact tractor or something entirely different? #13
FWIW on steep terrain I would expect the same performance in a 10 HP jump if you add a cab. It’s a lot of weight, electricity, etc that takes HP. If your going from a 25 go unit moving to a cab I’d look at 40+ minimum if you want increased performance for snowblowing applications.
/ Should I buy another compact tractor or something entirely different? #14
/ Should I buy another compact tractor or something entirely different? #15
Here's my 40 hp New Holland with a M K Martin Rear Pull Snowblower. I love the rear pull.
/ Should I buy another compact tractor or something entirely different? #16
When we get snow here that amounts to anything I look out
the window yup there's snow out there wait a while it'll melt
Many years ago we have 14 inches of wet snow and I was
coming back from CA and hit the drive way at 40 mph and
got in the drive way aprox 300 ft and the car was 2 feet off
the grould looked kinda funny sitting on a pile of snow. In a
couple of days car was back on the ground snow almost
all gone
willy
/ Should I buy another compact tractor or something entirely different? #17
Reversible tractors never really caught on in North American, so they're pretty rare.
/ Should I buy another compact tractor or something entirely different? #18
I looked at the TYMs up in Turner. Going to go back up again this week. What town are you in?
Be sure to look at Kioti; I'm biased, but they're worth checking out.
Thanks for the comments guys.
Several people saying I should get a pull behind blower. I have explored this option in the past. Last year when I was snowblowing I always imagined "Okay how would this be with a pull type blower"
So I made a list of pros and cons.
Pros-
1. I don't have to drive backward when snowblowing. This is a BIG one. It is super annoying and painful after more than an hour out there.
Uh....thats about it I guess.
2. See number 1!
Cons-
1. I'd have to buy one and they are not cheap
2. I can't "snowblow my way out" This is a problem as far as I can see. I don't like wasting my time redoing my driveway and yard so when it snows I don't snow blow until it is done snowing and sleeting. This means that I am dealing with as much as 2 maybe even 3' of sometimes wet heavy snow. I often have to snowblow my way out of where the tractor is parked. Basically I am making my own path. Just as a test I have tried driving forward with the tractor through the snow and it doesn't go well. It is really hard going and sometimes it just won't go (even with loaded tires with chains)
3. Driving over snow packing it down before blowing it. I have accidentally drove over snow many times when blowing and that one area ends up being a pain to get cleared down to the bare ground. Especially if it is sticky snow. I don't know how this wouldn't be an issue with the pull blower
4. Pointing the blower where you want it to go vs dragging it. I can see this as being a problem. With a blower that is being pushed you can push it up against your garage door, up in a corner of you buildings, I can snowblow up to the edge of my mail box post. I don't see how that would work with a pull type.
5. Blowing back snowbanks. Later in the year I often lift up the blower and use it to blow back the snow banks. I could use the FEL I suppose but in my experience it doesn't do the trick. Half of the snow just ends up falling back down whereas with the blower it shoots it way back.
Comments from guys that have them and use them?
Maybe I should just install a nice back up camera system.
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
2025 30in. Pallet Forks and Frame Skid Steer Attachment (A61567)
2025 30in. Pallet...
Ratchet Straps (A61569)
Ratchet Straps...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59908)
2004 VOLVO VHD...
