equipment trailer wiring.
/ equipment trailer wiring. #41
I think there are a few folks here that understand what I trying to explain, and I guess it just flies over the heads of really smart people here.
I do understand. Not what specific wires you need to change but what you need to do to fix the problem. Cut the entire trailer plug off, ignore the colors of the wires and wire up a new plug that matches the outlet on your pickup. You may find things that need fixed while you're doing that (poor ground connections are likely, for example).
/ equipment trailer wiring. #42
Yes. This is what I have been saying too.
Cut the plug off. You only have 6 or maybe 7 wires.
Identify which one is ground....pretty easy.
Now one at a time, put 12v to the other wires and see what they do. Make a note and wire up a new 7-way
2014 BMW 435i Convertible Coupe (A64557)
2014 BMW 435i...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A67148)
2019 HINO 195 18FT...
2002 EZGO Electric Cart (A64557)
2002 EZGO Electric...
2025 10,000lbs. Two Post Auto Lift (A64194)
2025 10,000lbs...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
