Massive storm clean up
/ Massive storm clean up
If that is a rental, I would think the repair cost should be on the rental company. I would think everyone that has ever rented that machine has contributed to that failure along the way. Not right that it just happened to fail during your rental time.
Thats the way they are handling it.
/ Massive storm clean up #142
Huge difference between the area you cleaned up and the area with the downed trees. The area with the downed trees is painful to look at.
It really is. The clock is now ticking on the area with the downed trees. I know that beech trees are pretty much junk after about 1 year. They do not store well and there are quite a few beech trees in there. Also there are several already-dead ash trees.
Pretty soon that area will turn to junk. Would like to get in there and start pulling trees out.
/ Massive storm clean up #144
Watch it start raining, hopefully after the next cutting of hay but hauling those logs out on those freshly disturbed (mud) slopes will be skidder work.
That's presuming the trucks are in the bottom land and not up hill.😖
We got a few loads of logs hauled when it was dry.
A new issue is developing: What to do with the “cut offs” or “stubs” of the logs which are trimmed for length to fit on log truck. Many are 3-5’ long. Some are 3’+ in diameter.
I think the owner may be OK with scattering them around on the property. Might be a way for me to use the dump truck to make a little more money.
/ Massive storm clean up #146
Does anyone you know need firewood? Load them up and deliver them for maybe $100 a load. You won’t make much at that but at least you covered fuel and got the job done.
It’s all pine, so no good for firewood.
/ Massive storm clean up #148
Burning them is not an option?
Any ideas for making them decompose together in a single pile more quickly? Scattering them would seem to just junk up more area unless there are some gulley areas washing out where they could be used to stop erosion.
/ Massive storm clean up #149
On my own property, I use a few larger logs to make a base for a wildlife brush pile, then throw slash over the top of it. It makes for great wildlife habitat, and contains what we humans think of as a "mess" into a few smaller areas, rather than leving it scattered all over the place.
A lot of landowners are interested in wildife and creating habitat, but have a hard time understanding that wildlife likes it messy. They spend a lot of time making their forest and yard look like a park, then wonder why they see such a narrow sampling of wildlife species. Some of them get more comfortable with the idea once they understand that the mess has a purpose.
EDIT: added this old file I had kicking around about building brush piles for wildlife. They recommend starting with more durable species than Pine, but anything will work, it just doesn't last as long as more rot resistant species.
  • Brush Piles MD Ext.pdf
/ Massive storm clean up #150
Based on this research, my post about making one neat tidy pile is absolutely the wrong thing to do if they want the wildlife habitat to recover.
I have a guy nearby that makes pine shavings I should give him a call
Would think theyd go nicely in a tub grinder.
/ Massive storm clean up #152
To go with the theme of clean look and no burning i would haul them off site with the dump truck and dispose or burn. Unless the grinder is coming back later.
/ Massive storm clean up #153
What about the cutoffs being camp fire wood? Don't have to worry about chimney creosote. Any other bad reason Jon
Reviving an old thread from the summer. Over the fall months, I have been able to truck-out 6 loads of logs and haven’t really put a dent in the massive amount of logs. The storm in our area caused so much damage, all the log processing plants are at capacity. It’s actually difficult to get rid of pine logs and we have hundreds of them.
Then there’s the issue of the cut-offs and the pieces too short to put on log truck. I am handling this part of the task and I was able to find a local processor who would take the unwanted chunks & pine shorts.
Using the Challenger with single arm log grapple and 5,000lb HLA forks. Makes easy work out of odd shaped junk wood like this
We are getting good use out of the 261C and the new 500i.
261c
Loading up with the log grapple forks on a 25* sunny morning in North Wilmington.
And onto the IH7500 dump truck
Down the steep driveway out of the property. This is a white knuckler getting out. Steeper than it appears.
Then on over to the wood processing plant
Jumped out and snapped a quick picture at the unloading pile. I feel blessed to have this facility in my area. It’s a bit longer drive than I would like, but it’s better than nothing.
I’m curious to see what the Customer decides to do with the gigantic brush piles.
That, along with the downed hardwood presents quite an opportunity.
One of the family members who calls himself a “biologist” wants to drill holes in the downed hardwood, place mushroom spores in the holes, and try to grow ****akes and other mushrooms in them, rather than harvest the hardwood logs for $$$
/ Massive storm clean up #159
That's a lot to clean up! I collect the brush and downed trees for several neighbors, and burn it off every fall. Nothing like the volume you are dealing with though.
I particularly like the picture of the chainsaw sitting in front of all that WORK!
/ Massive storm clean up #160
I don’t remember the bumper being kinked…..
Get into a scrape, ore did I just not see it before?
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A67148)
2019 HINO 195 18FT...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2022 EZ-GO ELITE...
2015 CATERPILLAR 336FL EXCAVATOR (A65053)
2015 CATERPILLAR...
PETRATOOLS HAND PUMP SPRAYER (A64278)
PETRATOOLS HAND...
2007 Chevrolet Silverado 3500 4x4 Service Truck (A64556)
2007 Chevrolet...
