Yanmar 2500 frankensteined
/ Yanmar 2500 frankensteined #1
Uncle_Charlie
Member
Yanmar 2500
I bought a YM2500 to brushhog my property. It runs fine, the hydraulics work fine, but it's not exactly a YM2500. The front half is 2500, and the back half is YM3000. The seat is from a Murray riding mower. Somehow, it all works together just fine despite being built from parts of other tractors.
I am confused by the cooling system. The 2500 is not one of Yanmar's tractors that used a thermosyphon cooling system. It has a water pump, but no thermostat. I keep seeing reference to the 2500 being identical the JD850. The JD850 uses the same 3T80 engine, but a different water pump backing plate that accommodates a thermostat.
I'm confused by the design. What is supposed to keep it from overheating? Without any interruption to the coolant flow, even a new radiator won't be doing much to dissipate heat. It pushes coolant into the overflow tank and pulls coolant back into the radiator as needed. So the cooling system is working at some level. But that doesn't change the fact that I can turn off the engine and hear coolant boiling in the block. Hence, my concern and confusion.
/ Yanmar 2500 frankensteined #2
I'm familiar with this having a used a 2500. I went and looked and correct. No Thermostat showing in my Yanmar parts. I knew the 2000 didn't have one either. But! the YMG2000 does have a Thermostat. The 2500/2000 Temp. sending switch about it. Test the Pressure in the Radiator sounding like a bad Head Gasket. You can Rent one at most any parts store.
/ Yanmar 2500 frankensteined #3
This is VERY common to split these two models and yes, they will bolt together and work.
Why is that? Because they both share this attached parts manual. ;)
Compliments of the YTOG,
  • YANMAR YM2500 YM3000 PARTS MANUAL.pdf
/ Yanmar 2500 frankensteined #4
The YM2500/YM3000 Parts Manual shows,
The YM2610 has he same engine as well,
/ Yanmar 2500 frankensteined #5
Sure no thermostat can cause something to actually run hotter under certain circumstances but as a whole it shouldn't, it should run normal or even slightly cooler.
I'm just guessing here but I'd say you have a bad head gasket. Maybe not enough to leak water into the cylinders bad enough to cause performance issues but something doesn't sound right .
/ Yanmar 2500 frankensteined #6
And if that's not what's causing overheating, then maybe the radiator needs to be rodded out by a pro radiator shop. After 40 years who knows what's in there. The first owner in Asia may have just used ditch water for his seasonal operation.
I assume the radiator fins are clear.
Compression getting into the cooling system should be apparent, looking in with the cap off.
I reread my original post, and I didn't make it clear. The radiator is new. The original was weeping a bit when I got the tractor, so I swapped it out for new one as I didn't want to try to salvage a 45 year old radiator when new ones are readily available. The fins were clear while I mowed as I cleared them several times due to the buildup.
I haven't posted in this thread for a while, so I figured an update is in order. Just for grins, I looked up the torque specs for the headbolts to see if they had worked themselves loose. Not all were fully torqued to 160 lbs/ft. With that corrected, I tried to start the engine and the engine didn't even try to turn. The solenoid didn't click. The battery was new a few weeks ago and still reads 12.3V, so it's not dead. Digging into the electrical system seemed to be the next logical step. For a tractor that is powered by a mechanical diesel engine, there is an unholy amount of electrical harness hackery hiding behind the cover panels.
What I've done is to bypass almost the entire electrical system. There is the high current positive cable to the starter. Next is the low current wire that goes from the starter to the ignition switch. I replaced the ignition switch and bypassed the wire going from the ignition switch back to the solenoid. I removed the two wires from the clutch safety switch and shorted those together, though that should not even be in the circuit at this point. There is still nothing happening.
There is another thread in in this subforum addressing solenoids that get sticky and fail to work. I'll pursue that next weekend.
/ Yanmar 2500 frankensteined #9
I don't recall relays on the YM2500. Just a VR and a fuse box.
The torquing down of the headbolts is done in 3 stages for torquing and each stages has a bolt sequence. Its common to find in the Yanmar service manuals and the TM1192 for the 3T80 engine of the JD850 and JD900HC.
There is a starter upgrade available for the 3T80 engines. The old starters use a solenoid and turns at 1.2Kw of power, the newer technology is a OSGR starter and turns at 2.0Kw of power. Best of all OSGR starters draw less power from the battery. It's all done in the gearing. If you have a very old and tired starter, then upgrade.
/ Yanmar 2500 frankensteined #10
The YM2500 has a decompression cable. It holds the valves open so there is no compression when you start the motor. Are you using it? Pull it open and then see how easy the motor starts to spin. If the motor starts to turn over wait and let it get spinning and then release the decompression and see if it tries to start. I wait for my oil light to go out and then release it. I set my Throttle at around 2000 rpms. I've used it enough to know were to set it. I've heard it said to set it at full throttle? I Never have. should be able to jump the solenoid and bypass the Ing. Key. I jumped mine at the Solenoid connections. Stater problems 15yrs. ago which finally had to get it rebuilt. 75$ I believe it was.
DECOMPRESSION CABLE ASSEMBLY -
/ Yanmar 2500 frankensteined #11
old starters use a solenoid and turns at 1.2Kw of power, the newer technology is a OSGR starter and turns at 2.0Kw of power. ... If you have a very old and tired starter, then upgrade.
That starter or one very near the same is what I put on the YM240 to replace the bad amateur rebuilt I found when I got the tractor. It was under $100.
With the higher amperage and the gearing, it cranks much faster, so I expect this would even start a worn out tractor that doesn't have spec compression.
/ Yanmar 2500 frankensteined #12
I've mentioned Before that I always use the decompression. My rule of thumb the oil light goes out let it the decompression handle go and let it rip!! Easier on the starter also. My old Org. starter has the light off by the count of 5 one thousands. Hot,Cold, Rain or shine. Few yrs. back is how I knew the org. battery of 10 yrs. was going bad. It would show 12V. but the CCA, Cold Cranking Amps was real low when I had it checked. Replaced it and went up from 550cca. to 850cca. and that made big a difference. When its hit it's been super quick firing up ever since. I was actually in mine before having to get it rebuilt and put a ghetto rig on it. Shop mentioned it they could tell. There wasn't anything left of the brushes I turned around.;) Not much doubt it'll be rebuildable again if need be.
There's been no update for some time as I just didn't have anything to update. This past week, the tractor is finally running correctly and not showing any sign of overheating. As a reminder, the PO said he thought the engine was overheating but he wasn't sure. When I put the tractor into use, it was filling the overflow tank within a few minutes, and boiling coolant in the block after half an hour of operation. Replacing the head gasket did solve the matter of filling the overflow tank as the cooling system was no longer pressurized with combustion gases. However, it was still overheating (meaning boiling in the block). Bear in mind, this was with a new water pump, radiator, hoses, and belt. I went back to the exploded parts diagram earlier in this thread and found the answer. The water pump has two pipes on it. One goes to the lower radiator hose, the other goes to a bypass hose. They are the same size and right next to each other. You can probably see where this is going. I had the hoses on the wrong pipes. Effectively, water from the pump was pumped right back into the block, never making it to the radiator. This has been corrected now.
I ran the tractor for the better part of a day in 90 degree heat and another partial day in 75 degree heat. It never pumped anything into the overflow tank or sounded like it was boiling coolant in the block. How this engine took as much abuse as it has and can still run is beyond me. Now that everything is correct, it is running at normal temperatures and not losing coolant. I would have expected the head or block to be warped, but there's no evidence of it.
The tractor still needs some attention, but now I'm comfortable running it.
Thank you to all who helped.
/ Yanmar 2500 frankensteined #14
"Built Yanmar tough".
I think that Yanmar tractors were designed to be used and perhaps overused in lots of low resource settings.
The old Timex tagline comes to mind, too.
Congratulations on getting the hoses worked out!
All the best,
Peter
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2015 Ford C-Max Hatchback (A61574)
2015 Ford C-Max...
