240D for sale
/ 240D for sale #62
When looking for a Yanmar, a person on the YTOG asked, What are the better models to look for? From knowing these machines over many years, this is the reply given . . .
You are doing the smart way of finding a tractor, find the best model types for ease of service and plentiful parts.
The YMxx10 & YMxx20 models are the favorites as those have the PowerShift, better tach meter gauges and more controls.
Some even have the engine block ports ready for winter block heaters.
Additionally, these models have the multi-PTO ability and better brakes. Once you decided on a YMxx10 or YMxx20, the next item is to pick the 3 cylinder engine over the 2 cylinder. The 2 cylinder is loud. It's nicknamed the Yanmar hammer. The 2 cylinder hammer is more pronounced in the longer stroke sizes like the 2TR17 up to the 2TR27. The 3 cylinder runs quieter and smoother. These are the 3 cylinder popular engines in the lineup, 3T72SB, 3T72SA-B, 3T72SA, 3T80 with no "U" suffix, and any 3T84. The 3T75 and 3T82 engines are not popular enough for parts. Suffix "U" engines have no sleeves and are costly to rebuild if there is cylinder wall damage. The 2T90 and 3T90 engines are rare birds. Deere has one in the JD950, yet when the engine fails, people snag a 3T80 as it's a bolt up plug-n-play option. If you only find a 2 cylinder, the 2T84 shares parts with the 3T84 for the pistons, rings and more.
I still can't believe how lucky I got when I bought my YM2310 complete with the FEL, a box blade, and forks for $2500.00. The 3 cylinder motor starts right up and runs great. The clutch was sticking when I bought it but less than a month later was unstuck and it now works great. I love my tractor and use it way more than I thought I would. I bought a Yanmar 5 foot wide rototiller for it and the machine has no problem powering it through my clay rich soils.
Eric
/ 240D for sale
Did he already pay or is it possible he may back out?
Seems the fellow has done work for her and he said he's take the tractor and implements as part of the deal. Sounds good to me but I suggested to the owner he'd take it this fall.
/ 240D for sale #64
Eric
Could you please send some good luck to ArlyA?
/ 240D for sale #65
Maybe find that guy and negotiate with him?
Looking at your photos, that YM240 left outside to rust has the same history that made my YM240 look so thrashed. Mine was a few years farther along in the process when I bought it. But a month of tinkering with minor stuff bought it back to where everything worked as it should. Then over the near 20 years I've owned it, no problems aside ffrom things caused by gross user abuse such as snagging and ripping off loader hoses. But it never got any prettier. :)
/ 240D for sale
I'm not going to search him out and this machine has been parked outside its whole life. We do get mousture here and I'd guess has water in this and that.
/ 240D for sale #67
Rodents nibbling a wiring harness on a tractor left in a field was more detrimental than when my tractors were exposed to the elements. I eventually had to replace the entire lower harness on my old L 2850 solved most of the issues i had with it.
/ 240D for sale #68
That tractor might still be sitting there 6 months from now or not.
I'm seeing more used tractors listed for sale around me than in a while. Asking prices still seem high, but that could change in the next 6-12 months. I'd rather have one that is at least in running condition instead of one that's sitting dead where it's difficult to guess what repairs it might need. There's a difference between an old tractor that has been kept in running condition and stored indoors and an old tractor that's been left outside and isn't running.
/ 240D for sale #69
These old Yanmars are blessedly simple. These loose lights were the about the extent of electrical repair my YM240 needed when I bought it.
They were dangling down by my knee when I found the tractor. No problem, Hoye had the replacement set.
802253-img_5916rym-dashlights-jpg.49339
/ 240D for sale #70
All Org. YM2000 Purchased in 2008. Water Temp. light problem has been the only problem after getting everything pretty much taking care of. The circut always been bad. Been coming on randomly for Yrs.. I stick my hand under the dash and feel the Temp. of the Radiator Fan air. If it's in the summer, When usually happens I have stopped and checked the overflow water level if it felt warm. All's good I turn the Ing. key backward/off when the light comes on. When the tractor gets cut off for few minutes it stays out for days. Or until ? Always been a pain.
/ 240D for sale #72
/ 240D for sale #73
I think this or something like it could be a good fit for ArlyA's use. 4x4, big enough to work, small enough to be easy to haul, not priced through the roof, in running condition, etc.
/ 240D for sale #74
But no loader, which I think is essential on a first real tractor for rural homeowner use. Move snow, a 750 lb capacity wheelbarrow or shop crane, level rototilled ground by dragging the bucket backward, even a raised work platform. The uses are endless.
/ 240D for sale
Ya, loader seems pretty important for our needs.
/ 240D for sale #77
To reiterate, at best we are only modesty interested in this dated 240D but will keep tabs on its sell.
If I had no tractor and the Massey showed up, I would jump on it. Mitsubishi machines are as dependable as the Yanmars. And no worries about gray market issues as it's a Massey.
See attached. Look thru this doc on its history and good support.
I was once a moderator at the Mitsubishi-Satoh group until I became the full admin of the Yanmar group.
I've revised this old document to become refreshed with much helpful info. Its pinned at the top of the Mitsubishi TBN section too.
Yanmars and Mitsubishi share many tractor parts. Not really the engine, yet all the stuff on the engine being used.
  • MITSUBISHI-SATOH HISTORY REV 3.17.pdf
/ 240D for sale #78
On this property I used a rear scoop on the Yanmar YM2000 for decades. Had a FEL on a JD. that was just a couple miles away. Never had to move it over here though. Seen the Ford tractor on CL. 2500$ with the loader is what I gave for it 63-2000 gas. Loaded rear tires so no need for 4WD.. The weight is has to be huge. No problems with traction even wet!! Just need to replace the front grill and fenders now. Been through everything. 12v new Ing.points, Clutch/P. Plate etc. If I do find and replace the body parts I may paint it. So into it with my time and 1600.00 in repair/Parts. Plan on keeping this one. The cool factor is off the chart!!...
/ 240D for sale #79
Farmers used to do a lot with only a rear pond scoop, brush cutter, and box blade on their tractors.
Chances are that a good 4x4 tractor with a FEL won't just be $3,000.
/ 240D for sale #80
Pond scoops are alright. They do have working limits.
A REL behaves like a FEL, with the exception the vertical height is limited.
A few SCUT Yanmars used them as well, typically less than 1/2 the price of a FEL.
For my use, a FEL is bulky and take time for removal off the tractor. There isn't much need for the FEL on my farm to be lifted very high. A REL or pond scoop would satisfy my needs overall and quickly change out.
As the OP is living in winters of feet of snow vs us at inches of snow, a REL or FEL is to be considered.
2017 Grand Design RV Toy Hauler Camper VIN # 573FS4334H1108024 (A61166)
2017 Grand Design...
2024 SILVERBACK 53XH3A 53FT TRI/A GOOSENECK CAR HAULER TRAILER (A59910)
2024 SILVERBACK...
2018 KENWORTH T880 FLATTOP DAYCAB ROAD TRACTOR (A62130)
2018 KENWORTH T880...
2004 FOREST RIVER CHEROKEE LITE CAMPER (A62130)
2004 FOREST RIVER...
2016 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2016 VOLVO VNL630...
24in excavator tooth bucket (A61307)
24in excavator...
