b2650 almost rolled need front wheel spacers
/ b2650 almost rolled need front wheel spacers #41
alexinPA, the difference is traction. You are running the tyres backwards so they clog up and don't self clean.
/ b2650 almost rolled need front wheel spacers #42
I contacted Bro-tek, they are going to do a custom set of spacers for me on a tractor they do not have listed. I am going to do the fronts as well, just to keep the tires in line.
On a related subject, you can fill tires with fluid without a special pump and tools if the sidewalls collapse when you let the air out.
/ b2650 almost rolled need front wheel spacers #43
Like I said, if you swap them (put left tire on right side and right on left) both tires running in required direction
/ b2650 almost rolled need front wheel spacers #44
I looked again at my front wheels, and I can get a few more inches by just flipping them inside out so I will skip the front spacers. The stems will be inside but I can live with that. I will put the spacers on the rears for sure for stability.
/ b2650 almost rolled need front wheel spacers #45
That's what i did just to fit snow chains. If you flip front wheels change the sides to keep direction of rotation as arrow shows
/ b2650 almost rolled need front wheel spacers #46
/ b2650 almost rolled need front wheel spacers #47
I contacted Bro-tek for a special quote for spacers on Aug 15. A Richard jumped right on it on Aug 16 and I gave him all of the information needed the same day. Then a question or two, then dead silence, even after a couple of follow-up/reminder emails from me to him. Today I forwarded the email string to their general sales email to see what is going on. We'll see what they come back with.
/ b2650 almost rolled need front wheel spacers #48
Anyone use a wheel spacer to change bolt patterns? In other words, the inside pattern would match the existing hubs, but the outside pattern would be something more standard. I have an old 1980s Japanese bulletproof tractor that I want more stability on. Custom spacer for sure.
/ b2650 almost rolled need front wheel spacers #49
can you swap sides with the rear wheels to gain extra width? or does it already come in the widest configuration? I did this once on a mahindra to lessen the overall width to get down some narrow grape rows. Took some getting used to
/ b2650 almost rolled need front wheel spacers #50
Most instances of tractors tipping has to do with inertia rather than balance only/
SLOW DOWN!
It could save your life!
I've been on three wheels to many times, (I have a very hilly piece of earth called home) but at the speeds I prefer, there is still time to put the bucket on the ground!
/ b2650 almost rolled need front wheel spacers #51
Spacers do not change bolt patterns and are too thin to offer much more stability.
Stay off steeper slopes completely. Death is permanent.
/ b2650 almost rolled need front wheel spacers #52
I added beet juice to my tires - added about 900 lbs to the weight of the tractor so that is goodness all the way around.
I have to operate on slopes from time to time and when I do I creeeeeeeeeeeep. All it takes is a hidden rock on the uphill side, or a dip on the downhill side to change all the weight and balance. I hate operating on sidehills. I am tense the whole time.
Great advice to go slow...which I have followed bush hogging my steep hills for the past 12 years. IF you feel (sudden spike of fear) something happening to increase your side angle (the unseen uphill rock pops the uphill side of the tractor up, the unseen downhill erosion hole that wasn't there last year, or just a surprise increase in steepness) to decrease your side angle do two things. Turn down the hill immediately (so plan to be able to do this - as in avoid mowing along the bank right next to a pond), and once turning (nearly simultaneously) drop the FEL bucket (hopefully if won't have a load in it while mowing). The quick turn introduces a cetrifugal force that will (hopefully) right the tractor back onto all four wheels. You have to have some forward momentum to make a downhill turn possible.
Going sideways rather than up and down is preferable to me for a few reasons. Sideways avoids short sidehill turns. Turning around while on a hill to go back up the hill centrifugal force will act on the tractor. Additive to the sidehill angle of the hillside/tractor. I tried going uphill and then hogging in reverse, but that is uncomfortable for long.
Ensure your front and rear wheels are installed so they extend the tires outwards the furthest, with or without spacers. Most tractor rims are reversible.
I had 4" rear spacers installed before I dared to hog my hills. I bought them from Motorsport Tech in Reno, Nevada, fabricated of aircraft aluminum, and both were anodized black. I also spray painted them Kioti Charcoal Gray to further prevent possible corrosion from possible future dissimilar metal contact - bolts, nuts, washers, axle ends and rims. Checking their website just now I see BORA spacers advertised (they sound like mine), but I think in 2013 they custom shaped them from solid pieces of aluminum because no BORA logo (they had a bolt hole template for my Kioti DK 40SE already). Motorsport Tech provided quality bolts and nuts. A minor snag was despite the template the holes in the spacers for the bolts were just a tiny bit too small to pass them through. Fortunately a machine shop is close by and they carefully drilled out the holes for a perfect bolt pass though. I painted after the holes were enlarged to get a thin coat of paint into the holes - the boring had removed the anodizing inside the holes.
Loaded rear wheels. Mine were loaded at purchase with Rimguard like Robert's. If you plan on getting spacers and haven't loaded your rear wheels yet put the spacers on first. I couldn't handle removing and reinstalling 700 pound loaded rear tires so I had my dealership do it with their block and tackle equipment.
To the OP's question...I considered also adding front wheel spacers. As many have said front wheel spacers may do little to prevent a rollover because the axle design may allow for it to tilt, causing the center of gravity of the tractor's chassis (heavy engine) to move sideways in the wrong direction. I read that spacers (rear or front) also increase the downward bending force exerted on the axles. For the beefy rear axle it's a non-issue, but for the front it sounded risky. My front axles are already wide (less width than rear stock wheels), and they are full of oil so sealed, and with gearing inside. I didn't want to mess up designed geometry and increase center of front axle downward forces already being exerted.
In the good news category the roll over angle is surprisingly steeper than I thought. For a static situation where the tractor isn't moving and on level ground...with the help of a friend who loves trigonometry we played around with various rollover/point of no return heights for different vertical centers of gravity. Biggest variable is the FEL height and what you might have in it. With a heavy load in the FEL the CG moves forward and that is why one, or both, of the rear wheels will raise off the ground first (which can result in a rapid rollover WITH tractor chassis rotation around a front wheel - ungood!). Side horizontal CG we left the same at 36 inches - tractor's front to back centerline. Here are our theoretical results with my 4" spacers.
Disclaimer - I am not an engineer and these should be seen, as a movie pirate captain once said, "More like guidelines!". But not even that - just some math showing static rollover angles are pretty dang steep with low vertical CG's. Every potential rollover scenario will have its own variables.
Also...I have no experience about when an increasing side load on the "downhill" side's tires might break a wheel rim seal, suddenly resulting in air/fluid loss and a likely increasing of the tractor's side angle, both in the ungood category. I would think jacking a tractor up on one side and getting near 40 degrees would risk it. No way am I going to intentionally allow for a side angle more than 30 degrees. When I've gotten over 20 degrees the risk of the tractor sliding sideways on loose dirt or wet grass exists.
"The static sideways rollover angle for the Kioti DK40 Hydro FWD, with FEL positioned with an empty bucket parallel to the ground, and Tartar 6’ bush hog, 4” spacers and loaded rear tires is probably above 40 degrees. There are no markings to let an operator know where the vertical CG actually is so...best guess for any given situation. I pasted this in from another document.
"Center of Gravity dynamically varies when the rear implement and the FEL are attached. Here are a number of predicted static rollover angles based on a range of vertical height CG’s.
Vertical CG Predicted Static Rollover Angle
25 inches 57.20 degrees
31 inches 49.25 degrees
33 inches 47.50 degrees
36 inches 45.00 degrees
40 inches 41.98 degrees
46 inches 38.00 degrees
55 inches 33.20 degrees
...and, lastly, a really high, heavy FEL load's best vertical CG guess...and one where a fast rotational roll over would likely be catastrophic.
72 inches 26.50 degrees"
I'm a retired pilot and I'll be quite honest. I'm more afraid of a rollover, or other potential life-altering mishap, operating my tractor than I ever was of flying an airplane. For example...pondering buying a hydrostatic transmission versus a manual transmission the terrible vision of me, new to tractors, pointed downhill and having it somehow slip out of gear came to mind. My foot brake for the rear wheels is, literally, useless once the tractor has momentum going downhill. I envisioned my tractor hitting the pond at the bottom of my long hill at 70 mph. Hydrostatic therefore a no-brainer for me, but I do know manual tranny's are operated safely by experienced operators - my neighbors! I also am in 4WD on my hillsides so the hydrostatic transmission stops the front wheels too.
Rhino
/ b2650 almost rolled need front wheel spacers #53
Instead of trying to justify Stupidity, mow up and down the hills. NOT SIDEWAYS.
The front axle is Not Fixed and will do nothing to prevent rollovers.
/ b2650 almost rolled need front wheel spacers #54
If you have the budget fit dual wheels. FAR more stabil. On steeep hill sides you will slide NOT roll.
Also duals will give a smoother ride.
Look at www.clickdualwheels.co.nz for an idea of quick removal /fitting fo duals on sub compacts.
Keep the loader down low to keep the centre of gravity low.
/ b2650 almost rolled need front wheel spacers #55
It has been said before but be careful when reversing the front wheels especially on front wheel assist and a loader. Often these axles are not built heavy enogh to take the added load. Check your operators manual and or your dealer for specifications.
Many safty precautions have been given by others. Such as slow down, watch for holes, rocks, tree limbs, and others things that may "surprise" the operator.
Keep loader low or remove it when mowing steep areas.
Purchase and use a roll bar (ROPS) with a seat belt. If you do roll it will keep the tractor off you, and give you a chance to keep on mowing instead of helping grass to grow.
Some have suggested mowing up and down a hill. That may work for you but it also help cause erosion. Back in the fortys farmers were taught to go across hills to prevent erosion. When I was younger and helping on the farm I hated plowing on hills (mountains?) especially when plowing down hill as the right wheel was eight inches lower in the furrow.
/ b2650 almost rolled need front wheel spacers #56
Bentrim > "Purchase and use a roll bar (ROPS) with a seat belt. If you do roll it will keep the tractor off you, and give you a chance to keep on mowing instead of helping grass to grow." 😂 😂 😂
/ b2650 almost rolled need front wheel spacers #57
Not sure of your statement, put 3 inch spacers on rear of my GC 1715 and it made a world of difference in its stability.... As for slopes, you can go up a slope and you can go down a slope, NEVER across a slope....
/ b2650 almost rolled need front wheel spacers #58
That was for plowing (IE: dust bowl).... Mowing does not damage weed root base for erosion....
/ b2650 almost rolled need front wheel spacers #59
Having been raised on a farm with the name of Hillside Farm I have seen even well established sod fields wash out with a heavy rain. Dad set up the farm with the fields setup in contour where the field is as level as possible across the hills. Going across the hills helps keep water from getting started running down hill especially in row crops, but it works with sod too. But after all I can only made recommendations after being taught to go across the slope for the last 65 years.
/ b2650 almost rolled need front wheel spacers #60
Adding 3” rear wheel extensions and fluid ballast in rear tires of our B26 made a world of difference in stability and traction on our hillside farm.
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2007 DRAGON 130BBL STEEL (A63569)
2007 DRAGON 130BBL...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
2016 Boxer 700HDX Compact Skid Steer (A63116)
2016 Boxer 700HDX...
