b2650 almost rolled need front wheel spacers
/ b2650 almost rolled need front wheel spacers #21
howdy, i have a b2650 with a LA534 front end loader. i am getting mighty tired of almost rolling this thing daily when i have my front end loader on, (with and without my bucket).
I have a belly mower, I am thinking of getting 3 inch front spacers... but then again, is 3 inches enough? I mow and dump things down on my hill all the time. should I go 4 inches? I already rolled my last machine (yeah it happens quickly)
Does a few inches on both sides really help and how do I determine what size spacers to get?
Also, why are these things so darn expensive? Who has the best deal on them?
/ b2650 almost rolled need front wheel spacers #23
I added beet juice to my tires - added about 900 lbs to the weight of the tractor so that is goodness all the way around.
I have to operate on slopes from time to time and when I do I creeeeeeeeeeeep. All it takes is a hidden rock on the uphill side, or a dip on the downhill side to change all the weight and balance. I hate operating on sidehills. I am tense the whole time.
/ b2650 almost rolled need front wheel spacers #24
Don't want to be a spoil sport---But ---- be careful when adding spacers. You may overload the axle, cause bearing or even axle and or wheel failure. You are moving the center of the wheel out farther which puts more leverage on the axle and more load on the bearings. Most front wheel assist axles were not designed with a loader in mind. Some manufacturers only recommend the wheel be installed only one way. Be aware adding spacers to the rear wheels can also cause the axle to break or cause bearing failure.
Have had combines on steep hills with bin full and a large head break the center of the wheel!! Talk about pucker power!!
Back in the 60's and 70's when reverse wide wheels were installed on cars it was causing bearing failure because the center of the load was moved away from the inner bearing and causing the smaller outer bearing to fail.
Be careful, out there.
/ b2650 almost rolled need front wheel spacers #25
When using the front end loader, I have a serious counter weight I attach to the 3 point, easy, cheap, not permanent and makes a world of difference.
/ b2650 almost rolled need front wheel spacers #26
Set your rear wheels out wide and add something heavy and low on the 3 point, like a bush hog, or box blade. And even then you can tip it pretty easily on a side slope when using the loader if you lift up high, or hit some holes and bumps.
Also if its not muddy, or you don't have to back up a slope with a load on the loader, you can start doing all your loader work in 2wd, then you will start breaking traction with the uphill tire when you start to take weight off of it. Don't do this on or near a steep slope as you only have 2 wheel braking and with a heavy bucketful you might not have enough braking.
/ b2650 almost rolled need front wheel spacers #27
After cleaning out my drainage ditches with a BX w/air filled tires. I bought a B2650 w/rim guard in rear tires and a ballat box filled with solid cement blocks.
Something every tractor/loader manual advises against -- UNLEVEL GROUND
/ b2650 almost rolled need front wheel spacers #28
As 2 previous posters said spacer go on the BACK axle. It is a waste of time and money fitting spacers on the front as you will be past the point of no return, before the front axle runs out of travel.
Alternative, DUAL wheels pricey but much wider and FAR more stabil. Use quick release fittings on the duals and if you use ballast only fill the inner tyres as if you need to remove the outer tyres they are a lot easier to move with air in them. I used to remove the outer right tyre on my tractor for hay mowing, and leave it of for the hay season.
/ b2650 almost rolled need front wheel spacers #29
Like you I used to use a belly mower, however, now having a cabbed machine the tip factor increased due to the change in my center of gravity. As a result, I now have my rear tires filled with Rim Guard. I also have rear wheel weights (300lbs total) and wheel spacers. For the wheel spacers I went with Bora 3”, because I have a drive over deck and anymore would have interfered with the MMM deck operation for my machine).
I NEVER mow with the FEL on the machine. It’s too risky. Especially with the steep grade on my property. It’s not worth the risk of a roll-over, just because I was too lazy to remove the FEL. On your BX, you may not be able to easily remove the loader, and are only able to remove the bucket. In this case, Always keep your ROPEs up and in addition to the aforementioned ballast options (rear spacers, rear wheel weights, rear tires filled w/ rim guard), I also would suggest buying a ballast box or having some form of rear ballast. The further out it can be the better, but that’s not always possible, safe or feasible, however a ballast box is.
Considering that you have already rolled your previous machine, I’m surprised that you didn’t already have these four ballast options on your new machine.
/ b2650 almost rolled need front wheel spacers #30
I stuck a liquid filled "inclinometer" (not sure of correct name) at top of my windshield. I have a (non wheel-spaced) L6060 Grand Cab. I was told 15° is about max inclination for this tractor which is fitted with liquid filled R1s. I've just about hit 15° on several occasions & go very slowly when I get there to avoid any lurching from hidden bumps or holes. So far I've not lifted a wheel (that I'm aware of) and I always shift my 220/lb body weight well to the high side of the cab. Am I taking a risk doing this? What max. degree of tilt is generally considered safe for this type of tractor and what would be safe with 4" rear spacers added? I'm usually mowing with a 72" rear 3/pt. hitch LandPride brush hog when doing this. I often see road crews mowing at crazy angles with their ag tired tractors and batwings and am encouraged by their bravery.
/ b2650 almost rolled need front wheel spacers #31
I don't think front spacers will work as well as 3" spacers on the rear wheels. The front axle pivots, and the rear wheels are what stabilizes the tractor frame.. just thinking..
Made a world of difference when I added 2-1/2" spacers on the rear axle to widen the rear wheels. Comfort level increased greatly.
/ b2650 almost rolled need front wheel spacers #32
Spacing the front axel isn’t going to do much besides creating excessive wear to the axel. Space the rear axle and add enough weight to keep it on the ground.
/ b2650 almost rolled need front wheel spacers #33
Can you add weight to front with out causing problem for loader just be on the grill.?
The only real need to weight the front end of tractors is on tractors without loaders. The loader provides plenty of weight on it’s own.
/ b2650 almost rolled need front wheel spacers #34
I forgot to mention the inclinometer! Very good call. I have one stuck to the middle of my windshield as well. You don’t need a digital readout or anything fancy, just the standard “bubble level” liquid filled style like @kohog mentioned works just fine.
/ b2650 almost rolled need front wheel spacers #35
Is that 15 degrees (corrected) with the loader raised? That seems like an awful lot, particularly with a load in the FEL, but I don't have an inclinometer to know what 15 degrees feels like.
/ b2650 almost rolled need front wheel spacers #36
Hard to measure almost.
/ b2650 almost rolled need front wheel spacers #37
Is that 15% with the loader raised? That seems like an awful lot, particularly with a load in the FEL, but I don't have an inclinometer to know what 15% feels like.
I wouldn’t push that with a FEL. You had better have rear spacers, filled tires, weights, and one hell of a rear ballast to maneuver 15°. Unless you actually meant 15% instead of 15° as there is a difference in the degree angle vs. grade percentage.
/ b2650 almost rolled need front wheel spacers #38
Talking about front wheels spacers... What is the difference between installing spacers and swapping and reversing front wheels?
I understand that reversing wheels only gives me about 2-3" extra width. Most people are against that but don't mind spacers.
/ b2650 almost rolled need front wheel spacers #39
Sorry, he said degrees, I mistakenly typed percentage.
15% is steeper = 26.8 degrees. Same question though, 15 degrees sounds like a lot.
/ b2650 almost rolled need front wheel spacers #40
Absolutely. In any case I stick with my suggestion - rear ballast (x4 methods).
No need for front spacers and front weight is only needed if you have weight on the back (such as a rear mower) and don’t have a FEL attached.
UNUSED FUTURE ELECTRIC WET POLISHER (A60430)
UNUSED FUTURE...
UNUSED RAYTREE REDM32 HYD MULCHER (A60432)
UNUSED RAYTREE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
