b2650 almost rolled need front wheel spacers
/ b2650 almost rolled need front wheel spacers #1
rrasi
Member
still in shopping mode
howdy, i have a b2650 with a LA534 front end loader. i am getting mighty tired of almost rolling this thing daily when i have my front end loader on, (with and without my bucket).
I have a belly mower, I am thinking of getting 3 inch front spacers... but then again, is 3 inches enough? I mow and dump things down on my hill all the time. should I go 4 inches? I already rolled my last machine (yeah it happens quickly)
Does a few inches on both sides really help and how do I determine what size spacers to get?
Also, why are these things so darn expensive? Who has the best deal on them?
/ b2650 almost rolled need front wheel spacers #2
I have 3" on each side and it makes a big difference. Mine are milled from high strength aluminum and they costed dearly. But I'm worth it.
/ b2650 almost rolled need front wheel spacers #3
You need wheel spacers for the rear, not the front.
T-B-N ARCHIVE:
VENDER:
/ b2650 almost rolled need front wheel spacers #4
There is an argument that when the front pivoting axle hits the stop, spacers will add some stability. I guess from a geometry view the axle will hit the stops sooner with the spacers.
That said, spacers on the rear, non pivoting axle, is definitely the way to go to add stability. As far as expense they aren't cheap. I put a set of Bora spacers on my zero turn that I setup for bank mowing.
/ b2650 almost rolled need front wheel spacers #5
Interesting. Have you had to replace the axle bearings yet? Seems like that would place a lot of stress on the "spindly little" drive axles on most ZTRs.
/ b2650 almost rolled need front wheel spacers #6
Brotek is what I used, 2" front and 3" rear as suggested by the man who makes them there.
The results are a noticeably less unstable machine. Expensive yes. Added stability, yes.
I have loaded rears as well.
/ b2650 almost rolled need front wheel spacers #7
By the time your front axle reaches its rotational limit, chances are extremely high that your rear axle and frame assembly have already passed the point of no return. Realize that the machine is already on a side slope of some degree to begin the process of turning over sideways, so now you start the process of rotating the frame over that front axle pivot. You add the starting ground angle to the ultimate rotational angle allowed in the front axle. Your going to be travelling over a great amount before the hard stop hits. The odds of it stopping at that hard stop are low at best.
The best option you have is to increase width of the rear axle/wheel assembly by any means possible, add weight to the rear wheels with fluid or bolt on wheel weights to fight the tendency to lift a rear wheel, reduce any unnecessary lift (height) to the loader arms and use operator technique and skill to reduce or eliminate the chance of rotating over.
The front axle width is more of a mental fix than a physical one due to the pivot travel. If you could add a great amount of front axle width, you would eventually get what you are looking for, but inch for inch and pound for pound added, you get exponentially more stability by working these gains on the rear axle compared to the front axle.
/ b2650 almost rolled need front wheel spacers #8
I went with 3 inch spacer on the REAR of my SCUT.... Made of world of difference.... Still on hillside operation its called go really slow and be aware of tractor balance all the time.... Wheel tractors are not good on sidehills ...EVER....
Yes the BROTEK are the best....
/ b2650 almost rolled need front wheel spacers #9
I know that uneasy feeling. I have a TZ25da New Holland and finally decided I had to do something. Put 4" spacers on rear wheels and it helped considerably. Like different little tractor.
/ b2650 almost rolled need front wheel spacers #10
T-B-N ARCHIVE:
VENDER:
That wouldn't be because of the scientific articulation of the frontest most axle, would it ?
/ b2650 almost rolled need front wheel spacers #11
This is on a Kubota ZD326, which is very heavy duty. The spacers I installed are also not real extreme at 2".
/ b2650 almost rolled need front wheel spacers #13
You're probably right. Now that I think about it, the rear wheel lugs on the Bad Boy are about 8" deep from the edge of the tire.
/ b2650 almost rolled need front wheel spacers #14
Relying on the free pivoting front axle to stop a rollover is interesting. Thinking that the spacer will help by the time the tractor has already tipped enough to hit the hard stop is risky thinking. The angle that the hard stop hits is called the butt-pucker angle.
/ b2650 almost rolled need front wheel spacers #15
Only thing front spacers do is increase steering effort, no moment transferred because of the axle pivot. Tests show it makes things worse because the jolt from hitting the angle restriction causes a jerk (change in roll acceleration)). Front spacers just keep the front track in line with the rear if you are trailering..
/ b2650 almost rolled need front wheel spacers #16
The pivoting front axle makes a stability triangle the similar to a forklift. Widening the front axle will have none to little effect. Biggest gains to stability are counterweight on the tractor's 3pt, loaded tires, then spacers on the rear axle.
/ b2650 almost rolled need front wheel spacers #18
Can you add weight to front with out causing problem for loader just be on the grill.?
/ b2650 almost rolled need front wheel spacers #19
For what reason, what would your goal be? Front axles are typically under rated or overloaded as it is with a full load in the bucket, you are required to use 3-point counterweight to reduce the front axle load to a safe level. If you look at the manual, it will specify the amount of 3 point weight required to use the machines loader. Adding additional front weight would require additional rear ballast (on the 3 point hitch, not in or on wheels) to compensate for that added weight.
/ b2650 almost rolled need front wheel spacers #20
Adding washer fluid in the wheels of my T-330 greatly added to the stability with the F.E.L. and backhoe when digging.
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2005 Fontaine FTW5-8048SLW 48ft. 38 Ton T/A Piggyback Flatbed Trailer (A61573)
2005 Fontaine...
UNUSED WOLVERINE HYD SNOW PUSHER (A64281)
UNUSED WOLVERINE...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A61572)
2018 Roadtec...
