Radiator care
/ Radiator care #21
Non issue with me as I either own or lease the fields and I always walk the perimeter prior to cutting, especially where their are property owners next to them. Seems as though adjacent property owners have no respect for land they don't own. I always get their trash on the borders which I throw back on their property.
Think I mentioned it before but one of the leased fields, the adjacent property owner actually dug a hole for a BBQ pit in the field and the property owner (not me) took the clown to court and he had to remediate the issue at his own expense plus reseed it. People today are either stupid or ignorant or both.
In my case, I have trees on the property and limbs do get blown down by snow and wind.
/ Radiator care #23
2013 Kubota M59 with 1460 hours. First coolant change. Old coolant had some whitish color while flushing. Did several plain water flushes bring each up to operating temperature and getting diminishing color. Inspection of core looking down from radiator cap opening looked clear. Cleaned overflow tank. Thin layer of gunk on bottom.
Added bottle of Peak radiator cleaner/flush and water. Per instructions operated 3-6 hours at operating temp over several days time. Drained and again flushed with water several times. Not much color or solids seen. Core looked about the same.
One flush with distilled water.
Added fresh coolant diluted with distilled water. Coolant says it’s good for 10years or 300,000miles.
Know this contrary to Kubota 2year coolant replacement maintenance schedule. Wondering if improved coolant formulas could extend coolant life while protecting the engine? Flushing like I did does take considerable time over several days.
Can’t tell any difference in operating temperature but it’s been hot and humid.
I used to work at a shop that also had a radiator shop,the radiator tech told me to put in 1 large bottle of lime away and use it for a week,I did,no more white,inside of radiator looked like a brand new core. it also takes care of any rust in the coolant or water,but drain coolant first then use plain water with the lime away
/ Radiator care #24
If not mentioned previously (I'm pressed for time this a.m. and didn't read all the posts.) You might consider Evans permanert waterless antifreeze that is specifically made for diesel engines. You do a flush (or two) with their waterless flush and then put the straight antifreeze into the radiator. It has zero water to cause corrosion and is claimed to be 100% permanent. It's expensive, but certainly worth it if it lives up to the claims.
/ Radiator care #25
Where are you at near K? I'm near Seymour & similar Kubota +2!
/ Radiator care #26
I read your original post and you never got an answer regarding the whitish color in the fluid. Everything else discussed seems spot on, I grew up back flushing the radiators with a small pneumatic nozzle on our Farm Air compressor before and after every field clipping! The amount of dust and debris will amaze a newbie!
If your local water has a high calcium content, the whitish deposits could be floating calcium or magnesim. You said you refilled with coolant and distilled water - that should reduce the chances of the same floating whitish color if it was "hard water" in the initial coolant mix. Others have spoken of new generation coolants that don't mix with water - If you see something similar in the future even with distilled water - I'd recommend trying the "waterless" coolants. Good luck!
/ Radiator care #27
I bought an air comb radiator cleaner from local K dealer. Nothing could keep the A/C running when we were haying. Blowing from the front with air or water did no good. Using the air comb from the back and presto the A/C works. $40.46 from amazon, less from dealer.
/ Radiator care
Been using radiator genie tools for cleaning radiators and air filters. You get both an air and water wands. Best tool for cleaning the shop floor, blowing dirt and grass out the door. Just bought a air comb to try too. Thanks for sharing.
/ Radiator care
Ran the M59 during the hot part of the day using a high load pto Brown tree cutter. Tractor stayed a normal operating temp. Me not so much.
/ Radiator care #30
I highly suggest switching to the pink coolant on your diesel tractors. Doesn’t cause cavitation.
Seen more long term diesel engine failures from cavitation than I want to.
/ Radiator care #31
I don't. It all depends on what type of engine it is (parent bore or dry liner versus wet liner). Cavitation is a non issue with a dry linered or parent bore engine. One needs to determine just what the liners are subjected to before switching coolants. In my case, my engines have dry liners so any type of AF will do. In fact Kubota recommends conventional glycol antifreeze, least for my engines.
/ Radiator care #32
Nox Vidmate VLC
That made a HUGE difference in the temps I saw afterward. I had my radiator out of the Ford while restoring. I made it a point to spray it with a cleaner and let it soak. I used a soft "bench brush" to clean between the fins. I was amazed at all the caked-on dirt that came out of it during the brushing and rinsing. It was visibly more open.
/ Radiator care #33
I equate cleaning a radiator to brushing my teeth. regular brushing keeps them clean and promotes healthy gums and fresh breath.
Regular cleaning of ANY radiator promotes good heat exchange and prolongs the life of the engine.
/ Radiator care #34
Nox Vidmate VLC
/ Radiator care #35
Did you clean the outside too? That made a HUGE difference in the temps I saw afterward. I had my radiator out of the Ford while restoring. I made it a point to spray it with a cleaner and let it soak. I used a soft "bench brush" to clean between the fins. I was amazed at all the caked-on dirt that came out of it during the brushing and rinsing. It was visibly more open. The Ford will run at thermostat temp all day now. It shows pretty low on the temp gauge. I haven't seen it hit the red even with chaff on the grill.
Check out a tool called radiator genie. It makes the cleaning easy.
/ Radiator care #36
It takes a lot of work to clean a neglected radiator and a lot of times you can’t even do a good job without removing it. The vast majority of overheating problems caused by dirty radiators. Even if the owner says they’re clean they usually aren’t.
/ Radiator care #37
I always use what is recommended by the manufacturer. Just when you think you outsmarted them you find out injector cups or whatever is not compatible with the new type of coolant you have put in. I know the Injector cup sealant in one of my trucks is not compatible with anything but green conventional coolant with a SCA package added.
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
1998 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61573)
1998 Fontaine...
1992 21ft Four Winns 205 Sundowner Boat w/ Boat Trailer (A61574)
1992 21ft Four...
Shamrock 8ft. S/A Enlcosed K-9 Transport Trailer (A61574)
Shamrock 8ft. S/A...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
