Streetcar
Most rebar is uncoated because that is the cheapestGalvanized or coated I would say no. Rebar is bare, uncoated steel for a number of reasons.
Mild steel is just weaker rebar, the high end all thread is stronger rebar. I have repaired bridge piers using all thread as the reinforcement by designI've been in construction inspection for 40 years.
Rebar is high carbon, graded and generally at least 40 grade usually 60 grade. (Very hard, very strong). All thread can come in different grades, but generally the off-the-shelf stuff is mild steel, same as a grade 2 bolt (different grading system).
While using this in your concrete won't do any harm, it won't replace rebar for adding additional strength. In other words. If you need rebar, use rebar as well.
I don't know why rebar is uncoated, mostly, but apparently galvanized steel is fine in concrete. I looked into this a while back because I have some 4 x 4 x 1/4 galvanized fencing, I think it is called hog fencing, that is excess to needs and I thought it might be good to add to a concrete pour. And the question about galvanized steel was answered in the positive. As I recall the alkaline environment of concrete is fine for zinc coated steel, it's acidic environments that attack zinc.Galvanized or coated I would say no. Rebar is bare, uncoated steel for a number of reasons.
I wouldn't hesitate for a minute using the all-thread. I bet it'll be stronger than the chicken-wire, and other trash metals that I've used in the past. Foot traffic and shower, etc. isn't going to come anywhere near enough weight to break your 4" of concrete slab.I should have indicated what I plan to do. Have a lean to (15x40 feet) on an ag building. Would like to pour concrete in it as a floor, enclose the same so I can put in a toilet, shower and sink so I can clean up after working. The plan is to have 2 inches of concrete rigid foam, water vapor barrier and 4 inches of concrete. This pour would be drilled and pinned to the ag building concrete so no settling. No weight on the same except for foot traffic.
Just felt for such a light load the all thread rod would be sufficient.
For an inside slab pour with very little load, you are wasting the thread rod and your time putting it in. Sell or use the thread rod for other purposes. Fiber reinforced redimix will work just fine for your floor. Never use the thread rod for an elevated slab reinforcement. 40 years in construction / engineering industry so I might just happen to know something about it.I should have been more specific. This is for a slab pour that will be inside and really have nothing heavy on it.
Four inch thickness will be hard to get any practical use from reinforcing steel except as crack controlI should have indicated what I plan to do. Have a lean to (15x40 feet) on an ag building. Would like to pour concrete in it as a floor, enclose the same so I can put in a toilet, shower and sink so I can clean up after working. The plan is to have 2 inches of concrete rigid foam, water vapor barrier and 4 inches of concrete. This pour would be drilled and pinned to the ag building concrete so no settling. No weight on the same except for foot traffic.
Rebar is weldable. welding is used primarily on large diameter barsDidn't know you weren't supposed to weld rebar. I thought I'd seen it done on some very large posts/piers on TV. Only done it when making my own concrete railway ties for a retaining wall so I won't worry about it.
What is matting? To use it as a mat to walk on?When I poured the 40x40 addition on my shop, I used cattle panels which I had on hand after we sold off all the stock for matting. Been in there over 10 years now and no cracks anywhere.
Some rebar might be weldable, but generally it isn’t. And whether it can be welded would highly dependent on where it is, and where the weld is in relation to the rest of the bar.Rebar is weldable. welding is used primarily on large diameter bars
A layer of reinforcing steel is referred to as a mat. Depending on the purpose of the structure, and loads it is designed to withstand. A bridge structure may have so many mats, and so much steel in each mat that you have to be carefull of not get teh steel so close together that the larger aggregate in the concrete to pass between the steel.What is matting? To use it as a mat to walk on?
Standard rebar is weldable. Some specialty rebar may not be weldable.Some rebar might be weldable, but generally it isn’t. And whether it can be welded would highly dependent on where it is, and where the weld is in relation to the rest of the bar.
