Detaching hoses in the warm
/ Detaching hoses in the warm #1
ning
Elite Member
Northern California
Branson 3520h
Occasionally a question comes up "how do I take this hydraulic coupling apart it's stuck!" and almost invariably it's because the temperature was cooler when it was coupled and due to the increase of temperature, fluid pressure inside the hoses has increased to the point that you can't undo the coupling.
Here's an example - I have a hydraulic fluid pressure gauge with two couplers; I keep it as a loop when not using it.
Apparently it was cooler when I last used it than today:
and after a minor temperature drop - this is like 65°F water -
it's only 76 out today though this was in the sun it wasn't hot to the touch.
/ Detaching hoses in the warm #3
I’ve soaked mine with the garden hose for a few mins. Especially the hard lines.
Now I disconnect in barn…..no more issues!
/ Detaching hoses in the warm #6
I use this $10 welding clamp from Harbor Freight:
Takes about 2 minutes with an angle grinder to open the jaws enough to fit the notch in the coupler barrel
Opens any pressure bound coupler with a pop and a spurt of oil. I usually wrap it with a rag first.
The clamp is also a hands free way to hold the coupler open when connecting.
/ Detaching hoses in the warm #7
It’s not always possible, but I try to wait until machinery has cooled overnight to uncouple hydraulics.
Also, always unhook with lever in float position.
  • Good Post
Reactions: mo1
/ Detaching hoses in the warm #8
I just shut the tractor off and work the levers back & forth a few times to relieve the hydraulic pressure. On some electro-hydraulic controls, you may have to turn the tractor off, then turn the ignition switch back to the "run" position, but do not start it.
Putting the couplers back together when an implement has been sitting in the sun is another story. I use one of the Waite hydraulic decompression tools: Shop - Rocky Mountain Waterjet
This video is way too long to show something so basic. Skip ahead to the 7:00 minute mark
/ Detaching hoses in the warm #9
I usually don’t have any problems unless the implement was uncoupled at rest temperature and then left in the direct sun. When that does happen loosing a hose or sometimes both hoses to relieve pressure is the only fix I’ve found. It doesn’t take much fluid loss. Just a few drips will do the job.
/ Detaching hoses in the warm #10
I’ve had more problems disconnected an attachment before I start using it vs when it’s at operating temperature. When the fluid is at operational temperature it would be unlikely for the sun to be able to heat the hoses hotter then they already were.
/ Detaching hoses in the warm #11
You push the ball/tit in the middle of the fitting..I thought this was common knowledge.
/ Detaching hoses in the warm #12
That’s hard to do with flat faced couplers.
Not sure what this was referring to. The original thread is detaching and I'm not sure how you get to the middle of the fitting without taking it apart first lol
/ Detaching hoses in the warm #14
And not always easy even when you don't have flat face couplers, especialy when tings have warmed up significantly since the attachment was removed. I have to smack the end HARD against the frame to get the pressure to release. I was concerned about doing that repeatedly.
THey are problably referring to my comment from yesterday evening where I said "Putting the couplers back together when an implement has been sitting in the sun is another story..."
Topic drift: a way of life here on TBN.
/ Detaching hoses in the warm #15
You turn the machine off and cycle the valve. This releases the pressure in the lines. Same for hooking up.
/ Detaching hoses in the warm #16
If the attachment is not connected to the the tractor, you can also take a couple of wrenches and loosen one of the couplers from the hose, to relieve any pressure.
/ Detaching hoses in the warm #17
I'm old and I'm cheap.
I keep like 1' pieces of hardwood handles (like from broken rakes/shovels/hammers/etc...) scattered around my shops and old shop rags. Quick cover and push and always been good to go.
If i can't find one around a simple broken tree branch and for male connectors push onto loader arm or similar metal piece. Gentle of course so not to damage connectors.
Fingers crossed never failed me yet.
/ Detaching hoses in the warm #18
Disconnect - waggle the control lever from the neutral position. Cover the connector with a rag and pull outer shield to separate.
Connecting - cover the connector with a rag. I have a 6" x 1/2" nylon rod. One end on the ball - light tap with a hammer.
/ Detaching hoses in the warm #19
^ This is the key right there. This will also make life a lot easier when reconnecting the coupler the next time as float bleeds off all of the pressure. If the valve doesn't have float, shutting the tractor off and cycling the valve between extend and retract a few times does the same thing. Some couplers can disconnect under some retained pressure and getting a coupler with some retained pressure reconnected the next time is fun, it will look like it went in just fine but then pop out of the quick connect with a spray of oil as soon as you hit "extend."
2018 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 VOLVO VNL 6X4...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
