55" grapple build
/ 55" grapple build #1
MELEON
Member
FREETOWN
JD 4310
We had a pretty bad hurricane blow across our island last fall. My property sustained quite a lot of tree damage. Thought I could use tractor to help out with the clean up.
So I modeled up a grapple and had a buddy cut it out on his plasma table.
I'm sure it will be clear from where I drew my inspiration from (i.e. robbed, it looked like the best out there.)
I used 1/4 AR400F for the majority of it and spent a few hours this weekend and got the lower jaw mostly complete.
/ 55" grapple build #2
(y) very nice. Are you using bolts or pins and bushings on the pivot points?
/ 55" grapple build
I oversized all of the pivot locations on the plasma parts so I can so I can turn accurate bushings out 1144 stress proof.
I'll be using pins on the cylinder lugs and 3/4" grade 8 bolts on the hinge.
/ 55" grapple build
Put a little time on the grapple last weekend. still need a few gussets and finish welding.
Then install the diverter valve when it arrives.
/ 55" grapple build #5
Nice looking grapple.
What was your total cost to build?
/ 55" grapple build
Thanks tradosaurus, Pleasantly surprised at how well its coming out.
The AR400 was $900 and I've probably got 1/4 sheet left over. (oops I mean I have a stump bucket left over.)
Plasma cutting, my buddy did the for free.
Cylinders $200
Tube and sch80 pipe $140
Grade 8 bolts $6
I used some drops I had kicking around to turn bushings and pins.
6lb of wire and a small tank of c25 gas
$1021 (canadian) total so far.
That doesn't include the diverter valve and various hoses and fittings
/ 55" grapple build #7
Nice fabrication skills!! Doubt you save much as your time is worth something. Even manufacture’s prototypes are expensive. But you have a piece of equipment you should be really proud of.
/ 55" grapple build
Thanks Smokeydog!
The grapple I "borrowed" my design from the most is currently on sale for $2400 which is $3000 Canadian, and that is assuming I could even get here.
As far as my time goes, well I design farm equipment for my day job which involves sitting on my but 10 hours a day. That leaves me cracking to do something productive with hands evenings' and weekends. I would almost pay double to do it myself, in fact I'm sure there times that I have. lol
tinkering in the shop and playing on the tractor is as close to a hobby as I've got and I know for a fact that I would never have splurged on a grapple purchase outright. its just a bonus that the time I spent building it will save ten times the effort it is going to take to clean up my wooded property from the damage hurricane Fiona caused last fall.
/ 55" grapple build #9
Looks great. What type of farm equipment doe you design?
Andy
/ 55" grapple build
Mostly potato planting/ harvesting equipment, with some blueberry and grain handling stuff.
/ 55" grapple build #11
Grapple looks great!
Is that a Certiflat table? Do you like it?
/ 55" grapple build
Same guy that cut the grapple, cut the table for me as well.
I love it. Makes clamping and squaring up assemblies so easy. I just have a terrible habit of laying crap on every horizontal surface.
/ 55" grapple build #13
Thank you for sharing. Lot of us try to modify, repair and innovate our equipment to meet our needs. Materials and fabrication equipment certainly has changed and improved attachments. Operating a tractor in the woods needs several modifications. Any special procedure for welding AR400?
/ 55" grapple build
Not an expert by any means, but my understanding is that its pretty standard up to 1/2 thickness. These thinner plates can be welded at room temp without preheating. The biggest thing as far as I'm aware is you want the welds to cool slowly.
/ 55" grapple build #15
I used 1/4 AR400F for the majority of it and spent a few hours this weekend and got the lower jaw mostly complete. View attachment 804184
looks great so far. I am wondering why you didnt put any lightning holes in the lower jaws.
/ 55" grapple build
Mostly oversight. As I was watching the parts being cut, I said to myself "I meant to put speed holes in those bottom tines."
/ 55" grapple build #17
Cylinders $200
Grade 8 bolts $6
The 55" grapple from EA is $2400. Not sure if it would be worth it for me to do it myself (if I had the tools and the skill). The plasma cutting would add a few hundred $$ to the price if you had to pay for it.
55" Grapple
/ 55" grapple build
Yeah. 2400$ is 3000$ Canadian. I’m in for just over 1000$ I’m happy saving just under 2000$ besides that I enjoy it.
/ 55" grapple build #19
I’m self employed now days. I find a ton of value in building my own things always. I was a machinist for years. I have a mill and lathe at home. As someone stated time is worth something. It is indeed, but I value my federal I owe you notes in my bank more then some spare time. Awesome fab work !
/ 55" grapple build #20
😂 Always hate when that happens.
2019 CHEVROLET TAHOE (A66091)
2019 CHEVROLET...
Toro Groundmaster 228D (A64912)
Toro Groundmaster...
PALLET OF MISC FLANGES/BOLTS (A68842)
PALLET OF MISC...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2001 FORD F-250 SUPER DUTY (A67714)
2001 FORD F-250...
