LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,823
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I don’t see a tank or return in the diagram. But there must be somewhere.
Diagram is a little dark and vague but it looks like the loader and curl lines are connected to the relief at all times.
As ptsg has said it is a relief from the curl extend to the lift port of the main cylinders. It will prevent binding from the MSL or extreme back blading by relieving into the lift cylinder.Yes that's a relief valve, but that's a self leveling loader with a mechanical linkage. You need that relief valve because under certain conditions the mechanical linkage can't push or pull the bucket any further so something has to give, in this case, pushes fluid through the relief valve from the curl cylinders to the lift cylinders.
The Tank or return is from the valves. There is no return to tank from that relief.
