Built a new camp grill
/ Built a new camp grill #1
gsganzer
Elite Member
Denton, TX
L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
One of our deer lease members got off the lease and took his grill with him. So I threw one together using a 3/8" thk x 36" vessel head I had laying around. It came out pretty good. I'll put a 24" round solid plate in the bottom, so it has a flat bottom and is easier to shovel ashes out of.
/ Built a new camp grill #3
It looks like a keeper.
How do you move it with only 2 handles? Looks like a 4 man job to me.;)
/ Built a new camp grill #4
great job. what type of steel? prob food grade mild... am sure it's not chrome or zink plate that i'd steer away from, prob wire feed mig on that?
/ Built a new camp grill #5
Very nice. What did you paint it with? I'm not aware of any food grade paints.... are there?
/ Built a new camp grill #6
That should last years and years. (y)
It will stay in one place at camp, but 2 guys could lift and move it a short distance with the handles if you needed to. They're really there so you can lift/turn it so the high back is upwind. But they also work for slings/chains to lift it with a FEL.
The head is mild steel and painted on the outside only, with 1200 degree paint. The grill is just carbon steel that will get seasoned like a cast iron pan. Stick welded with 6011
/ Built a new camp grill #10
Where did you get that belly from? Can you buy those or did you have that formed somewhere?
I only painted the exterior of the head, the wind deflector, legs and very outer angle/ring of the grate with 1200 degree grill paint. I left the inside head and grate itself unpainted. I'll season the grate with some grate seasoning, just like you'd season a carbon or cast iron pan. The grill sits under a canopy, so doesn't get rained on. If the grate doesn't stand up, I'll replace it with some stainless expanded metal.
It's a 36" flanged and dished vessel head, 3/8" thick. I used to work for a company that had a pressure vessel fabrication shop. The customer changed the nozzle size after the shop had already cut the hole, so the head was scrapped. I had to weld the part the shop cut out for the nozzle, back in place. Fortunately, I'm best friends with the shop manager, so he had the head and patch nested together for me in the scrap bin.:)
/ Built a new camp grill #13
Yea, that's the holy grail for that grill. My dad had those large pipe and vessel head connections when he was alive but I'm not that fortunate. That one is the perfect size and shape for what you needed. Nice job. I would love to have one of those. I'll post up some pics of the one I do have when I can. I have to leave for KC for 2 weeks tomorrow morning so it will be when I get back.
/ Built a new camp grill #14
good choice, mild steel & 6011 has been my own since college days for job like yours... cure it out before using, you know that, regards
If I didn't have the vessel head, I would have built a hexagonal grill using a sheet of 3/16" thick carbon steel. The bottom would be flat and approx, 1/2"- 1" larger in diameter than the sides, this way you just do a stitch fillet weld to join the sides to the bottom and the two don't have to be bent as precise.
A hexagon is really simple to draw with a compass and has simple 60 and 120 degree angles. You can bend the plate easily by making a thin groove using a straight edge and angle grinder with a cut-off wheel. Make your groove on the inside, so you have a nice clean corner on the exterior. After you've bent all 6 sides and tacked it to the bottom, you can run a thin weld bead on the inside angles where you made the groove.
I hope that makes sense.
UNUSED WOLVERINE PT-16-01C 3 PT QUICK TACH (A64281)
UNUSED WOLVERINE...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
iDrive TDS-2010H...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
Caterpillar V Series Lift Truck Service Manual (A63117)
Caterpillar V...
