gsganzer
Elite Member
- Joined
- Jun 11, 2003
- Messages
- 4,397
- Location
- Sunset, TX
- Tractor
- L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
It looks like a keeper.
How do you move it with only 2 handles? Looks like a 4 man job to me.![]()
It will stay in one place at camp, but 2 guys could lift and move it a short distance with the handles if you needed to. They're really there so you can lift/turn it so the high back is upwind. But they also work for slings/chains to lift it with a FEL.It looks like a keeper.
The head is mild steel and painted on the outside only, with 1200 degree paint. The grill is just carbon steel that will get seasoned like a cast iron pan. Stick welded with 6011great job. what type of steel? prob food grade mild... am sure it's not chrome or zink plate that i'd steer away from, prob wire feed mig on that?
I only painted the exterior of the head, the wind deflector, legs and very outer angle/ring of the grate with 1200 degree grill paint. I left the inside head and grate itself unpainted. I'll season the grate with some grate seasoning, just like you'd season a carbon or cast iron pan. The grill sits under a canopy, so doesn't get rained on. If the grate doesn't stand up, I'll replace it with some stainless expanded metal.Very nice. What did you paint it with? I'm not aware of any food grade paints.... are there?
It's a 36" flanged and dished vessel head, 3/8" thick. I used to work for a company that had a pressure vessel fabrication shop. The customer changed the nozzle size after the shop had already cut the hole, so the head was scrapped. I had to weld the part the shop cut out for the nozzle, back in place. Fortunately, I'm best friends with the shop manager, so he had the head and patch nested together for me in the scrap bin.Where did you get that belly from? Can you buy those or did you have that formed somewhere?
good choice, mild steel & 6011 has been my own since college days for job like yours... cure it out before using, you know that, regardsThe head is mild steel and painted on the outside only, with 1200 degree paint. The grill is just carbon steel that will get seasoned like a cast iron pan. Stick welded with 6011
