BX 23, sputtering and hard/won't start
/ BX 23, sputtering and hard/won't start #21
I would be testing the stop solenoid. It either is not getting power or has failed.
Ok - a lot of things to update on. Not sure how to interpret this, so a it’s a little long;
Went back and tried starting it, after about 5 seconds of cranking it started up and stayed on (it’s a lot warmer than when I tried in the morning, so not sure if that’s the reason.)
Let it idle for 20 mins and it stayed on - sputtered a bit after 10 mins but went back to normal idle.
Managed to drive it a bit and rev it to full throttle and it was fine. Felt like it might sputter but was fine.
Then, disconnected the fuel shut off solenoid and tried starting it and it started right up in half a second.
Connected the solenoid back and it needed 5-7 seconds of cranking to start.
Still doesn’t turn off with or without the solenoid connected and have to manually lift the lever.
So to testing the solenoid as K5lwq suggests.
Connector voltage; same as battery.
Not sure if the diagram is the same as the solenoid for a bx 23 but there’s only a black and red wire from this solenoid and no white, so I didn’t know how to try step 3 and 4.
I tried the battery positive to the red and battery negative to the black and it causes the switch/ button to pop out and stay out for as long as I have it connected and pops back in when I release the connection.
The instructions say to push it in with your finger, but I can’t seem to - it’s really strong.
/ BX 23, sputtering and hard/won't start #23
If I am understanding correctly yours must stop the engine by momentarily sending power to the solenoid when you turn the switch to off. Then it should retract and it is ready to run next time. So there is a timer relay that controls that if I am correct. As long as the solenoid is powered it would keep the engine from running.
The one I posted works the other way. It has a pull section of the coil and a hold section. That is why it needs 3 wires. It needs power all the time for the engine to run.
The fact that yours will run with the solenoid unplugged tells me that it is retracting but maybe the relay is firing when it is plugged up some times. Next time it happens check the voltage at the solenoid before you turn the switch off. If it has power you need to find out why.
/ BX 23, sputtering and hard/won't start #24
When I had my BX after I shut it off after a few seconds there was a distinct pop, which was the shut off popping so it was ready to start next time. There must be some kind relay or timer like K5lwq said.
/ BX 23, sputtering and hard/won't start #25
I have several Kubotas (3 B2150s, one BX2200, others I work on) and all of them provide an audible click shortly after you turn off the engine. I assume it to be a solenoid, sounds like one, but never knew what for.
Thank you all - i never knew what a fuel shutoff solenoid was until yesterday so I’ll work through this tomorrow and revert.
I think I hear the audible pop a few seconds after shutting off, but that doesn’t explain why the engine still runs.
I bought a new solenoid so will try working on them both tomorrow and also try testing voltage at different times and revert.
Thank you all again - sincerely
/ BX 23, sputtering and hard/won't start #27
It may be the linkage on the solenoid to shutoff is hanging slightly.
Also, if you don't hear pop or see movement, check the fuse. Looking at the wiring diagram for this model, it looks like they relocated to the fuse area. It is rather large compared to the other fuses and it is a 50A.
Visual and audible diagnostics will be easier than accessing the solenoid wiring itself.
/ BX 23, sputtering and hard/won't start #28
Are the fuel shutoff valve and the fuel shutoff solenoid two separate items or one unit? Maybe the valve (rather than the solenoid) is hanging up ? I'd lean toward replacing them and having it over with.
/ BX 23, sputtering and hard/won't start #29
BX tractors are self bleeding. Two things to check. They have a small lift pump, it almost looks like a fuel filter but it’s metal. Make sure it’s clicking when you turn the key on but don’t start. I’d also change both filters even though you said you had flow. They are very small and plug easily and they are also cheap. They also had a problem with the sending unit rusting and plugging things up.
Just had the no click issue, fixed with battery jump on a B7800. Battery showed 12v but maybe insufficient Cold cranking amps. Curious for more info on the “lift pump” mentioned, (the fuel stop solenoid ?)
/ BX 23, sputtering and hard/won't start #30
On a BX there is a small lift pump after the rear most fuel filter that pump fuel to the main injection pump. If you turn the key on but don‘t start the tractor you can hear it clicking. Sometimes the tractor will run without the lift pump working because the main injection pump will still pull fuel but it might not run well.
So, more progress on this and also explains the hard starting issue;
This is my understanding on how the solenoid appears to work (don't have a WSM - I wish I did and might try and look for one).
The plunger is normally in the in/retracted position.
When you turn on the tractor it should stay in/retracted and get no power.
When you turn off the tractor there is 12v that goes to the solenoid that pushes the solenoid plunger out, which cut off the fuel and shuts the engine down, there is a relay somewhere that keeps the 12v of power for 6 seconds and then the plunger retracts back in.
Connector voltage:
If the above is correct, the solenoid should not get any power to it when starting / cranking and only get the 12v power for 6 seconds when you turn the key off.
Here's what's happening with mine.
When you turn the key just before you crank, the solenoid is getting 12v of power that pushes the plunger out and it stays out for 6 seconds and then retracts.
That explains the hard starting as the plunger is getting pushed out, cutting off fuel and if you keep cranking for 6 seconds, the plunger retracts and the engine starts.
Sometimes once it gets started and you let go of the key, it gets 12v of power, pushing the plunger out, explaining why letting go of the key sometimes switches off the engine.
Other times it seems to get the power for a fraction of a second and pushed the plunger out again and back in quickly.
If it doesn't push back out the engine stays on.
If it pushes out and in quickly, that sputters the engine, but it stays on.
If it keeps pushing in / out (which it seems to do for a few seconds on occasion), the engine sputters and either stays on or turns off based on what the plunger eventually does.
Since I now have 2 solenoids I was able to test this with one outside and just connected to the wiring harness, and the other screwed in place to prevent fuel shooting out.
So, the solenoids are fine, the issue is either at the key switch or somewhere in the wiring, but I don't know enough to know how to start understanding.
I'll try and get a key switch replacement, but wondering what your thoughts are on possibility of a wire shorting somewhere and if so, how do I go about diagnosing this?
This winter we had a lot of rain and with the tractor outside, that might be part of what caused this.
I know it's a bit of a lengthy explanation, but just wanted to try and be as clear as I could.
Thank you all - appreciate any thoughts.
/ BX 23, sputtering and hard/won't start #32
Boy, I think you have now figured out more about the sequence of events with the fuel shutoff solenoid than the rest of us knew ! Certainly more than I. I would not go changing out the key switch just yet. Sounds like a sequence is out of whack and that is probably a relay rather than the key switch.
/ BX 23, sputtering and hard/won't start #33
Connector voltage:
This is what I was thinking was happening. The reset for the relay is 12v supply on the signal wire. When the switch is turned to off it knows to fire for 6 seconds. If the supply wire is not making good connection then it would do as you are experiencing.
I would look closely at connectors for corrosion that could be a bad connection. A faulty timer relay could be to blame as well.
Very good job tracking down the problem. You are getting close now.
  • Good Post
Reactions: JWR
/ BX 23, sputtering and hard/won't start #34
If it’s in the wiring about all you can do is trace the wires. Easier said then done as you may have to take a lot of things apart to get at them. It could be a mouse chewed threw or water or corrosion in a connector. I hate wiring problems.
  • Good Post
Reactions: JWR
/ BX 23, sputtering and hard/won't start #35
Another thought just completely disconnect the factory wiring and run a new wire with a manual button to turn it off and on.
Thank you - you guys gave me a direction to work toward, which I really appreciate about the forum. I'm always willing to put in the work, but the experience of others helps point you in the right direction.
I've never liked when someone just comes and ask a question and expects others to solve it for them. You are all so generous with your time and I really want to convey how much it's appreciated.
I'm really thinking that's what it likely is - but just have to work through this one step at a time. I don't have pins, clips, connectors, wires etc - so need to purchase some parts and work on this later this week - but i'll be sure to update once I have more info.
It's a good thought but after how much this problem has stressed me out, I really want to get it fixed right. Plus I think I would make it difficult for anyone else in the family wanting to use the BX.
I also worry i'll snag the switch some how and turn off the tractor at the most importune time, like while mowing or using the backhoe.
I tend to put gloves, hats, sunglasses on the dash and i'm sure I'll often mess it up.
Then I also worry, i'll use the button to turn off the engine, but forget to turn the key back and drain the battery. Better to just do this right.
Oh - One more question.
If you were to plan new wiring, where would you buy wires, connectors, clips etc?
I have none of these (apart from fuses) and want to buy some quality products - Amazon is so inconsistent on quality and didn't know if there was places you might recommend.
I'll probably buy quite a bit extra parts as a lot of the lights on the BX don't work and other places the wires look like they could need replacing.
/ BX 23, sputtering and hard/won't start #38
An auto parts store has some of that stuff. A lot of the connectors are going to unique to your tractor. A lot of times if it is a connector you can take it apart and clean it. If seen connectors that were an obvious problem where they were turning green.
  • Good Post
Reactions: JWR
/ BX 23, sputtering and hard/won't start #39
Know this has the symptoms of a fuel related issue...but on the outside chance...you might also check for possible corrosion or shorting on one of the safety switches...
/ BX 23, sputtering and hard/won't start #40
Slash Pine, I’m pretty sure he has diagnosed tge problem correctly.
  • Good Post
Reactions: JWR
SHOPBUILT T/A TRAILER (A64278)
SHOPBUILT T/A...
BESTWAY AG 1600 GALLON NURSE TANK (A64278)
BESTWAY AG 1600...
EZGO (A64557)
EZGO (A64557)
REDDICK OFFSET DITCHER, 3PT (A64278)
REDDICK OFFSET...
2018 Ford F-250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F-250...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
