~50~60Hp compact cabbed tractor with a good loader and lots of stability?
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #1
Sid Post
TX and OK
Massey 5711D, Kubota L4600, Kubota B2601
I own a Kubota L-4600 today. In relatively flat Oklahoma where I grew up, it was a great tractor for chores but, where I am at in Texas is sloped with feral hog wallows hidden in the pasture grass and similar obstacles that are hard to see from the seat.
I need something that is stable using a loader out in my pasture which my L-4600 is not. For those that will ask, yes my tires are loaded with "beet juice / rim guard" with wheel weights and normally a heavy 6' tiller for ballast and it is still too light in the rear. It also has a high center of gravity with a narrow "footprint" for loader work.
I need a tractor heavy enough for normal farm chores for me including but, not limited to using:
  • post hole digger
  • bush hog (AKA rotary cutter) so at least 35Hp PTO as a hard minimum
  • heavy loader work
    • big round bale movements (not stacking)
    • buckets of wet soil
    • Skid Steer pallet forks with moderately heavy loads like pallets of range cubes or half pallets of concrete
I am looking for something with a good cab which will serve me well as I get older than I am today. To me, this means easy entry and exit, air conditioning that works well in Texas heat and humidity, and ergonomic controls that won't fatigue me with age or extended use like mowing around trees and other obstacles.
My initial search has me looking at the TYM T574 and Massey 2850M/2860M since they have relatively good dealer support around me. Yanmar is of interest but, that dealer is ~200 miles away! The Massey options are in the $45K range new and the TYM is in the $38K range so, while $7K is a lot of money, not enough to encourage me to buy the wrong tractor due to cost.
John Deere and Kubota generally dominate this market space but, Kubota is not of interest right now because their tractors are too light for their loaders and are generally undersized in the class IMHO. John Deere's business model has this diehard legacy John Deere owner looking somewhere else these days. "Right to repair" may get around their proprietary software issues for fixing a broken tractor but, that was a real turn-off for me. United Ag and Turf, the local John Deere dealer, has not been a good experience generally so far when I went there for implements and similar stuff.
What are people's experiences with Mahindra and LS tractors in this class? LS dealer support is weak but, Mahindra seems to be really making an impact on the Lowes and Home Depot garden tractor shopping crowd that just bought a small acreage. I am open to other brands that have reasonable support and a track record of being good for the owners and long-term dealers.
TIA,
Sid
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #2
If your out on Kubota and Deere I'd probably look hard at Massey next. I haven't worked with their tractors but I've sat in a few when visiting the dealer I get most of my implements from and am impressed with a lot of what I see.
I've got experience with hog wallows, only thing I can say is look hard at tire size. Nothing smooths out the ride like bigger tires in a tractor. When I got my M4 my neighbor got a deer 5400 series and the difference in tire size when they are parked next to each other is staggering. I get across rough fields much faster than he does when we're working together.
Other thing, when you get a cab rear remotes are sure nice so you don't have to climb in and out so much when hooking up.
Goodluck.
Goodluck.
I tried to buy a Kubota M5-091 right as COVID hit so, the order never went through. During COVID I could not get one configured closely to what I wanted so, that and a $20K price increase for fewer features was a real turn-off. Recently the tractor I wanted was sort of available but, was delivered on "spec" so, there was no chance of getting the transmission I really wanted.
I ended up with a Massey 5711D! A lot more tractor and significantly cheaper too! That Dyna transmission with the Brake-n-Go feature is simply awesome!
The Massey's also have some features others miss. Specifically, the 2850M I looked at had 3-pt ends/swivels that spun 90 degrees to go from Cat 1 to Cat 2! Genius! :love:
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #4
If you go for the T574, that's a solid tractor with 2700# FEL lift capacity, heavy and stout tractor. Mechanical injected simplistic engine, it also has adjustable rims for width.
The engine I think is a cloned Cummins like you see a lot in irrigation systems and similar applications. With a single dry clutch plate though, the manual transmission will likely need service in ~2,000 hours or after many years to be replaced which will be pretty expensive.
The T494 I looked at seemed like a really nice tractor at a fraction of the price of a similar Kubota or John Deere. I really thought hard about a T754 before I committed to the Massey 5711D.
The current Massey's aren't like the ones I grew up around but, they still seem like a really solid tractor with good fundamental engineering and a solid design team unlike some of the others trying to build to a price point or to one-up a competitor.
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #6
Either tractor you mentioned will fit your needs but without comparing standard features to options between them will give you a better understanding of the cost.
As mentioned by TracorTYme, adjustable rear wheel width is important. For hilly terrain, the wider the better.
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #7
The 5711D is quite a big machine indeed, I'm sure it will serve you well.
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #8
Congrats on the 5711!
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #9
Dang, with a 5711 why do you care about a 50hp tractor's loader capacity :ROFLMAO:
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #10
I know the problem, and have a solution that worked for me....probably not a universal fix, though. But I have an old Ag tractor that has wheels on both ends that can be spread out until the tractor has approximently the same look and stability as a horned frog.
It's old two cylinder JD530 series Ag tractor - originally for 20 to 40 acre corn and vegetables - with adjustable front and rear wheels. Rears are power adjustable for width but fronts you have to wrestle out.
The front and rear can be made to be ridiculously wide. The tractor only has 32 hp, but they made larger ones. I doubt this is special to JD. Chances are a lot of older Ag tractors in the utility 30 to 60 hp size were used for truck and crops were available with wide adjustable width.
This JD530 one weights right at 7500 lbs. 4 speed, manual shift, factory power steering. The loader easily handles a ton or more. The 3pt is cat II with draft and has hand cranks for adjustment, the PTO is independent and clutched, and the hydraulics are high flow. Seat is sprung and damped.
Nice old tractor, and you simply can't tip it over. Maybe there is something similar in your neck of the woods.
rScotty
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #11
I like my NH Workmaster 75 HP. It comes in a 55 HP/40 HP PTO and a 65 HP/50 HP PTO model. Same cab, chassis, and loader. It weighs 6,800# without the loader. The 555LU loader is rated at 3,153# at max lift height of 131" (10.9'). The AC keeps the cab cold in the East Texas heat.
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #12
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Tractor capability is more closely correlated to tractor weight than any other single (1) specification.
The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations.
  • post hole digger
  • heavy loader work
    buckets of wet soil
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Kubota L4600
Kubota L4600 tractor photo
2011 - 2014
Standard L Series
Compact Utility tractor
Kubota L4600 Weight
2WD gear :3,109 lbs
1410 kg
4WD gear :3,186 lbs
1445 kg
4WD hydro :3,197 lbs
1450 kg
Dimensions
2WD Wheelbase:72.8 inches
184 cm
4WD Wheelbase:72.6 inches
184 cm
2WD Length:122.8 inches
311 cm
4WD Length:117.9 inches
299 cm
Width:62.4 inches
158 cm
Height:91.7 inches
232 cm
Ground clearance:15.2 inches
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
You need a 5,000 to 6,000 pound bare weight tractor. These are the heaviest tractors in the compact tractor category. Engine will generate 60 to 100 horsepower. This weight tractor will rut wet ground.
Width will be 72" to 84" in standard configuration. Almost all will have adjustable rear wheel/tire widths.
A cab will add 700 pounds to bare tractor weight. Cab air conditioning will absorb approximately 5-horsepower on hot days.
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #13
I ended up with a Massey 5711D! A lot more tractor and significantly cheaper too! :love:
Massey Ferguson 5711​
Massey Ferguson 5711 tractor photo
2017 -
5700 Series
Utility tractor
Dimensions
Wheelbase95.7 inches
243 cm
Width70.7 inches*
179 cm
ROPS Weight9195 lbs
4170 kg
Cab Weight10011 lbs
4540 kg
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #14
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #15
Congrats on your pick. Which dealer did you use?
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #16
As rScotty mentioned, rear wheel spacing will do wonders for increased stability. Unfortunately, a lot of new tractors have limited adjustments available in rear wheel spacing.
An easy solution is wheel spacers. BroTek (Bro-Tek) makes wheel spacers for just about every new tractor make/model. I confirmed with LS corporate that adding them does not violate any warranty.
I added 2" rear spacers to my LS when I bought it new. I bought them myself and the dealer installed them for free when assembling the tractor as it's not really any extra work putting them on at the time of assembly.
One thing to be careful of when going this route is it may push your rear wheel spacing just enough that you need to size up implements by an extra foot. This is what kept me from putting on 3", or 4" spacers. I would have had to buy an extra foot wider in all of the implement sizes. With the 2" spacers my implements "just" cover my tracks.
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #17
To the OP, look at dual wheels. The difference in stability is amazing compared to single rear wheels. Also use a quick release style of dual wheel attatchment(don't fill with ballast either).
Always keep the loader DOWN LOW when travelling. It is amazing how many people travel with the loader up high where it can destabalise the tractor and cause a roll - over.
Good luck in your hunt.
/ ~50~60Hp compact cabbed tractor with a good loader and lots of stability? #18
TYM would be a very good choice, they probably have more lift capacity than any other 50-60 horsepower tractors, and superior hydraulic pump capacity .
Both are wider than my L-4600 which was an initial starting point. Weights are also higher which is good for stability, especially with loader work.
What I learned shopping for my 5711D Massey, is that a spec sheet only gives you part of the story.
Around buildings, in corrals, around trees, etc. all make a smaller tractor useful and a good complement to a big one.
Plus, if I need to take it somewhere, a smaller tractor is a whole lot easier to load up and travel with when I don't need a ~10K pound tractor with a ~4K pound lift capacity.
Lastly, some places are not good for a tractor that heavy where you may crush water and sewer lines, or generally destroy someone's yard with heavier ruts.
2019 Chevrolet Express Van, VIN # 1GB0GRFP7K1370206 (A61165)
2019 Chevrolet...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2015 Freightliner Coronado 122SD T/A Day Cab Truck Tractor (A60352)
2015 Freightliner...
2016 TAKEUCHI TB216 EXCAVATOR (A62129)
2016 TAKEUCHI...
2020 MACK P164T (A58214)
2020 MACK P164T...
2014 Dodge Ram 4500 Versalift Bucket Truck (A60352)
2014 Dodge Ram...
