2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,466
The guys who cut steer slopes here have dual rear tires. I suppose checking into the option of adding dual rears would also be something to consider when shopping.
I know the problem, and have a solution that worked for me....probably not a universal fix, though. But I have an old Ag tractor that has wheels on both ends that can be spread out until the tractor has approximently the same look and stability as a horned frog.
It's old two cylinder JD530 series Ag tractor - originally for 20 to 40 acre corn and vegetables - with adjustable front and rear wheels. Rears are power adjustable for width but fronts you have to wrestle out.
The front and rear can be made to be ridiculously wide. The tractor only has 32 hp, but they made larger ones. I doubt this is special to JD. Chances are a lot of older Ag tractors in the utility 30 to 60 hp size were used for truck and crops were available with wide adjustable width.
This JD530 one weights right at 7500 lbs. 4 speed, manual shift, factory power steering. The loader easily handles a ton or more. The 3pt is cat II with draft and has hand cranks for adjustment, the PTO is independent and clutched, and the hydraulics are high flow. Seat is sprung and damped.
Nice old tractor, and you simply can't tip it over. Maybe there is something similar in your neck of the woods.
rScotty
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Tractor capability is more closely correlated to tractor weight than any other single (1) specification.
The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations.
- post hole digger
- bush hog (AKA rotary cutter) so at least 35Hp PTO as a hard minimum
- heavy loader work
- big round bale movements (not stacking)
buckets of wet soil
Skid Steer pallet forks with moderately heavy loads like pallets of range cubes or half pallets of concrete
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Kubota L4600
Kubota L4600 Weight 2WD gear : 3,109 lbs
1410 kg4WD gear : 3,186 lbs
1445 kg4WD hydro : 3,197 lbs
1450 kg
Dimensions 2WD Wheelbase: 72.8 inches
184 cm4WD Wheelbase: 72.6 inches
184 cm2WD Length: 122.8 inches
311 cm4WD Length: 117.9 inches
299 cmWidth: 62.4 inches
158 cmHeight: 91.7 inches
232 cmGround clearance: 15.2 inches
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
You need a 5,000 to 6,000 pound bare weight tractor. These are the heaviest tractors in the compact tractor category. Engine will generate 60 to 100 horsepower. This weight tractor will rut wet ground.
Width will be 72" to 84" in standard configuration. Almost all will have adjustable rear wheel/tire widths.
A cab will add 700 pounds to bare tractor weight. Cab air conditioning will absorb approximately 5-horsepower on hot days.
Massey Ferguson 5711
Dimensions Wheelbase 95.7 inches
243 cmWidth 70.7 inches*
179 cmROPS Weight 9195 lbs
4170 kgCab Weight 10011 lbs
4540 kg
If you have a Deutz dealer near you check out the 5080D 75 hp
5D Keyline - Deutz-Fahr America
deutz-fahramerica.com
willy
Congrats on your pick. Which dealer did you use?
In Junior and High School, I spent my time mainly on a John Deere 4630 with dual 20.8x38's so, I totally get that option.To the OP, look at dual wheels. The difference in stability is amazing compared to single rear wheels. Also use a quick release style of dual wheel attatchment(don't fill with ballast either).
Always keep the loader DOWN LOW when travelling. It is amazing how many people travel with the loader up high where it can destabalise the tractor and cause a roll - over.
Good luck in your hunt.
h
rScotty
That tractor is double the size of what you started this thread with. I couldn't use anything that big. I look forward to seeing pics of it in action!Thought I had one locked down at Jarvis in Lufkin which was a very good dealer experience but, they sold the loader off of it, and in the meantime, the price became a bit too high.
I'm dropping off the cashier's check with Cunningham in Paris, Texas today if all goes as expected. Smaller dealership overall but, I think I will have a good ownership experience there with very personalized service (no big company commercial infrastructure because I dealt directly with the owner and had simple straightforward conversations without the MBA business school banter and drivel).
