Buying Advice on Hydraulic links
/ Buying Advice on Hydraulic links #51
Ordered my top link today from a local place. I should have it installed in a week or so. I’ll post up when I do. Also bought a 3pt quick hitch
Great addition to any tractor. Next you're gonna be wanting a tilt cylinder. Makes hookups using a Quick Hitch much easier. We'll need pics of course. :)
/ Buying Advice on Hydraulic links #52
Richard, do you know what port size you have on the top link?
Let me know and I should be able to figure something out.
Brian, here's some pics I took. Of course I'm hydraulic fitting ignorant. I don't recall the size or type of cylinder ports. If you can't figure it out by the pics I'll do some more research. I probably have the receipt for the cylinders. I bought them from Supply House and then modified them to fit my application. Thanks in advance for your efforts. I really appreciate it.
/ Buying Advice on Hydraulic links #53
One thing at a time. The top cylinder should help a bit with attachments, especially since they all reside in an enclosed barn on level concrete. I bought the Harbor Frelight Quick Hitch and aftermarket top hook as recommended. $149 total
/ Buying Advice on Hydraulic links #54
Totally understand. :)
For my application on the Kubota I use the tilt cylinder more than the top cylinder. My most used attachment is a Box Blade. Allows me to cut slope.
The Ford just has a top cylinder. It's most common use is with a rear blade. The blade has a tilt cylinder.
My junk gets parked on a gravel floor or on dirt. The TnT makes rehitching a breeze.
/ Buying Advice on Hydraulic links #55
Beenvenue - a shame we are so far apart. I was given a hand crank unit. Never used it. I would give it to you. I think this may be what you are looking for.
I installed that kind of link to offset my rear blade, replacing the telescoping link on the blade. I like it. It’s simple, works fine, and only cost $100. Typically when I offset the blade, I use it like that until the job is complete, then it’s no problem adjusting the blade back to the standard position. Sometimes going full hydraulic isn’t worth it unless you’re going to be constantly changing the setting.
/ Buying Advice on Hydraulic links #56
My preferred top toplink;
I have a rope tied to the latch end and I can adjust the length from the seat till it will set right on and latch in.
Not cheap by any definition but very handy.
/ Buying Advice on Hydraulic links #57
Double check the wrench size, should be 7/8"
Check your PM please.
/ Buying Advice on Hydraulic links #58
Replied to your PM and completed contact page info on your website.
7/8" is correct.
11 1/4" center of port to center of port.
Thanks Brian!!!
/ Buying Advice on Hydraulic links #59
I suppose these are technically parts, but they attach to the tractor, so apologies if this is poorly placed.
I am about to pull the trigger on a T494H (maybe a 4820H or T574H). I want to get a hydraulic top and side link. My primary use will be box blade work on driveway (200-300 ft) and paths. I have some questions for those who have been down this road before me.
1) Have dealer install it or aftermarket?
2) Options/features to look for?
3) Min-Max lengths?
4) Manufacturers with good reputation?
Installation seems pretty straightforward, but somethings are better in experts' hands.
One day (free) ship from AgriSupply. Very well packaged, and I’ll get it installed ASAP.
/ Buying Advice on Hydraulic links #60
That's where I'm getting down to brass tacks.
The T494 comes standard with 2 sets. The 4820 says you can have up to 4 sets (optional). I reckon you can add more to the T494, too. I'm also not sure what type are 'standard'. I'd rather get what I need at purchase time as none of them are close by.
The two models are similar, but each has pros and cons. Same dealers either way.
Torvy, If they are available as an option I'd sure get them! I have 3 on mine and haven't "yet" used the third set but if I ever need it I know it's already there and available. Any piece of equipment that uses a set of remotes I can use. Provides equipment buying options. Buy once, cry once. I kind of wish I'd have gotten 4. Best of luck in your decision. Greg
2014 Parker Trailer Sales Trailer (A60352)
2014 Parker...
SCAN TO RECEIVE TEXT UPDATES (A62129)
SCAN TO RECEIVE...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2003 International 9200I (A53317)
2003 International...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
John Deere 4044M (A60462)
John Deere 4044M...
