tacticalturnip
Super Member
I just enjoy the options having hydraulics provides. I went from none, to dual, and now I'd opt for more if I could make the purchase over again. Easier to toss it in with the financing.
Some tractors, well, most tractors 50hp or smaller aren't offered with 3. Not sure about yours. If offered, get it.Thanks. I haven't seen a side shift on a box blade, but I haven't looked for one either. The grapple can use the 3rd function that is already plumbed.
I'll never have or need some of the cool stuff @ovrszd has. A 6' brush cutter is plenty for the few acres that are not forest.
I may have to think on the log splitter, though. They are not fast, but I'm not getting younger. The Mrs. may be able to use a splitter. In the short term, I have a splitting maul and an axe that will work. Fortunately, firewood will be for ambiance more than heat.
That's where I'm getting down to brass tacks.Some tractors, well, most tractors 50hp or smaller aren't offered with 3. Not sure about yours. If offered, get it.
I use a diverter on my LP rear blade. Very cheap multiplier.A hydraulic remote multiplier looks to be a handy way to add remotes beyond factory options. It's basically an electric diverter valve.
I need 4 remotes with some implements. My offset flail ditch mower, for example, requires 2 and the T&T needs 2. I have 3 on the rear of my L6060 HSTC and use the 3rd function valve as a 4th. It's tough to mess around with diverter / multiplier valves with a cabbed tractor unless they are electrically actuated.Sorry, I'm serious. Why the 3rd remote?
Such as the one used in the photo. This customer had a single rear remote and needed 3 sets of couplers.I need 4 remotes with some implements. My offset flail ditch mower, for example, requires 2 and the T&T needs 2. I have 3 on the rear of my L6060 HSTC and use the 3rd function valve as a 4th. It's tough to mess around with diverter / multiplier valves with a cabbed tractor unless they are electrically actuated.
If possible, check to see if you can find one with a 2 1/2" dia cylinder and maybe even a 1 1/2" dia rod.I measured up the top link on the 4820 at mid extension… so... everything level at the ground. I sits at 25” center to center. Looks like a 20”-30” link will be right in the ballpark, and I saw one on Amazon this week
