Buying Advice on Hydraulic links
   / Buying Advice on Hydraulic links #31
I just enjoy the options having hydraulics provides. I went from none, to dual, and now I'd opt for more if I could make the purchase over again. Easier to toss it in with the financing. 🤣
   / Buying Advice on Hydraulic links #32
Thanks. I haven't seen a side shift on a box blade, but I haven't looked for one either. The grapple can use the 3rd function that is already plumbed.
I'll never have or need some of the cool stuff @ovrszd has. A 6' brush cutter is plenty for the few acres that are not forest.
I may have to think on the log splitter, though. They are not fast, but I'm not getting younger. The Mrs. may be able to use a splitter. In the short term, I have a splitting maul and an axe that will work. Fortunately, firewood will be for ambiance more than heat.
Some tractors, well, most tractors 50hp or smaller aren't offered with 3. Not sure about yours. If offered, get it.
That's where I'm getting down to brass tacks.
The T494 comes standard with 2 sets. The 4820 says you can have up to 4 sets (optional). I reckon you can add more to the T494, too. I'm also not sure what type are 'standard'. I'd rather get what I need at purchase time as none of them are close by.
The two models are similar, but each has pros and cons. Same dealers either way.
   / Buying Advice on Hydraulic links #34
A hydraulic remote multiplier looks to be a handy way to add remotes beyond factory options. It's basically an electric diverter valve.
   / Buying Advice on Hydraulic links #35
I use a diverter on my LP rear blade. Very cheap multiplier.
   / Buying Advice on Hydraulic links #36
Sorry, I'm serious. Why the 3rd remote?
I need 4 remotes with some implements. My offset flail ditch mower, for example, requires 2 and the T&T needs 2. I have 3 on the rear of my L6060 HSTC and use the 3rd function valve as a 4th. It's tough to mess around with diverter / multiplier valves with a cabbed tractor unless they are electrically actuated.
   / Buying Advice on Hydraulic links #37
Such as the one used in the photo. This customer had a single rear remote and needed 3 sets of couplers.
A double diverter took care of his needs. :cool:(y)
   / Buying Advice on Hydraulic links #38
I measured up the top link on the 4820 at mid extension… so... everything level at the ground. I sits at 25” center to center. Looks like a 20”-30” link will be right in the ballpark, and I saw one on Amazon this week
   / Buying Advice on Hydraulic links #39
If possible, check to see if you can find one with a 2 1/2" dia cylinder and maybe even a 1 1/2" dia rod.
This would be ideal. I've seen my share of 2" units on these size tractors not hold up. :oops:
Just an FYI.
   / Buying Advice on Hydraulic links #40
I'm going to agree on 3 remotes if it is an option... @ovrszd & @MtnViewRanch (& others) have pointed out good reasons for them... Our NH TC40D had one rear remote when we purchased it used... I added 2 additional rear remotes & a front mounted diverter valve & now would not want to be without. Front diverter valve operates the grapple or the tree / post puller, two remotes dedicated to the TnT purchased from Brian @ Fit Rite (MtnViewRanch) & the third is used with the wood chipper, the back blade or the snow blower... I do think I need to add check valves to the top & tilt cylinder as they seem to not stay under load (but not sure the correct way to do it yet)... however I like being able to leave the TnT connected & still having the 3rd remote available for implements...
2277 (A58376)
2277 (A58376)
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
BOX BLADE (A58214)
BOX BLADE (A58214)
LeBlond Heavy Duty Lathe (A59213)
LeBlond Heavy Duty...
New/Unused Gold Mountain 12ft x 20ft Steel Carport (A57454)
New/Unused Gold...
