Hydraulic Top Link?
/ Hydraulic Top Link? #21
Thanks everyone for chiming in, this is just yet another thing I have zero experience in and I'm trying to cram likely years of knowledge and understanding into a short period of time. Pardon me if I am asking newbie questions, I feel like the manufacturer doesn't provide easily accessible information regarding the 3pt and attachments.
I guess I'm not sure if I want to float or not. I am thinking I dont. I plan on using a snowblower, box blade, and I recently ordered a CP572 brush cutter. I think all of these I want to be able to hold it so it doesn't ride up when they meet resistance. But if I remove the ability to float on the 3 point, what am I giving up? maybe using a bush hog would be a little more rough as it wouldn't follow the ground as well?
How did you determine that this was the appropriate one? I am new so maybe I'm missing something but when searching for information on my tractors top link I couldn't find specifics for length etc. The most I found was in the MF4700 product book it stated the tractor was cat 2 with fixed ball ends. I feel like I must not be using the right search terms because this seems like it should be easier to find measurements for the top link. Either way I appreciate the help, depending on if I need float or not I'll likely order this just to have something ready to rock when the tractor comes in.
Is anyone able to comment on the difference between the one mtnview suggested, Fitrite, and Haytools? It seems like fitrite is just one guy? Is he the equivalent to someone custom building violins vs just buying one at guitar center?
I am Fit Rite. I custom build every order that is placed. I have supplied several top links for the 4700 series tractors. I supply a 3" dia cylinder with a 1 1/2" dia rod typically without the check valve for this series of tractors. It has a working length of
23 1/4"- 35 1/4". You will not find this working length any where else. I assume that you do not want to wait the minimum of 36 weeks to get one of my units, thus I provided what I feel would be the best available off the shelf unit. If you decide that you want to be able to use the float feature of your tractor, simply do not use the check valve that comes with the recommended off the shelf top link.
Here is a link that describes how to determine what length to get for any 3pt hitch application.
You do not have your tractor, so pretty much useless for you to use to get a top link and have it ready to go.
You have the information available, use it as you see fit.
Yep, one guy named MtnViewRanch
Well I feel a bit sheepish.
I am Fit Rite.
It's nice to actually interact with someone that makes the equipment I am interested in. You're right, I don't want to wait so I'll probably end up getting the one you recommended, and submitting an order for one of yours. I feel like I ran into someone famous hah.
Any chance you can expand on when I would want float vs not? You say most people get your top link with float. Again I plan on primary snowblowing and brush cutting with my 3 point.
/ Hydraulic Top Link? #23
Probably the #1 use for float that I can think of with a top link is for a brush hog. Even though most rough cut mowers have some articulation built into the implement itself, depending on the circumstances that you have, that built in amount of articulation may not be enough. So having a top link adding additional capabilities is often nice to have.
My recommendation would be to get the off the shelf unit that I recommended as well as the hose kit that goes along with it.
Use it as is. Only remove the check valve if that becomes a hindrance.
Good luck
/ Hydraulic Top Link? #24
I do not have the extra remotes for top & tilt. They have been on my list for a very long time. Very slowly collecting the needed parts.
It makes using your tractor very easy.
I am a huge fan of remotes & crying once. The value of buying new makes that easier (maybe not cheaper).
One other thing that may be available for your tractor (I'm not familiar with that model): extendable links for the lift arms. Another device that makes using 3 point tools much easier. Helps a lot when the ground isn't flat and you are changing implements.
Your dealer should be able to discuss this feature with you. It was one of my requirements when I started my search.
To flip back to the remotes. There is a hydraulic switch often called an "a/b" switch (or valve). They are a bit pricey, sometimes so close you may as well buy another remote. Just depends. It switches the device the hydraulic valve controls (usually either a, or b; haven't seen one that has more, but there could be). Not as convenient as 2 remotes. For my tractor you can only have 4 remotes due to the cab. And that includes remotes for the loader. If you needed more these could be the way to go. Or, if you had a 3rd circuit for the front that only got used for say a posthole digger, and you needed a curc6uit for tilt; not much conflict as one would not be used with the other. Etc.
/ Hydraulic Top Link? #25
Here is a triple diverter. This tractor has a single factory rear remote. (Only 1 rear remote is available from the factory)
4 sets were needed to control all the different hydraulic functions,T&T and offset & angle on rear blade & rake.
If a person goes with a control grip with all the controls in a single point, it is actually more convenient than having 4 separate levers to operate. All 4 functions can be operated and never removing your hand from the main control lever. :cool:
There are some companies that only offer the separate rocker switches to control the different valves, but even that can be a good alternative. (y)
/ Hydraulic Top Link? #26
I just got a Mahindra 2655 with a cab. This is my first tractor with a cab and with a rear remote. I am going to get a hydraulic toplink. When attaching an implement, will I have to get in and out of the cab to adjust the top link with the lever or can you pull/push it in and out manually?
/ Hydraulic Top Link? #27
You will need to use the control lever for the rear remote to adjust the working length to get hitched up.
You get used to where it needs to be to get attached and really is not that big of a deal after you have done it a few times. ;)
If you could simply move the rod in & out by hand, it would basically be a worthless addition, even a hindrance. o_O
/ Hydraulic Top Link? #28
Yes you will need to use the lever inside the cab to adjust the top link. But if your tractor is also equipped with a lever outside the cab for raising-lowering the two lower three point arms you can also use that lever carefully to help get the proper distance to be able to hook the top link. At least that’s how I usually wind up doing it.
/ Hydraulic Top Link? #29
I'm not sure about the Mahindra, but with my Kubota, I can open the side window (not the cab door) and reach the valve levers from outside.
I'm not aware of any top link cylinders with a push pull action.
/ Hydraulic Top Link? #31
It's hard to realize how very handy a hydraulic top link is - until you actually get one and use it. It's even harder to put into words. I got my Fit Rite in 2013.
/ Hydraulic Top Link? #32
I only see the need on a box grader. Other than that, it's see no need.
/ Hydraulic Top Link? #33
Well......lets see. I have six land engagement implements plus a chipper. It sure makes connecting the top link a whole lot easier. And I use it to fine tune each of the implements - while in use.
Rather than the implement working - just OK - - it can be tuned to perfection. Makes each of the implements work a whole lot better and easier.
If you like adjusting a manual top link - so be it.
/ Hydraulic Top Link? #34
In addition to all the above, a hyd. top link is also useful for controlling FEL attachments mounted with an adapter on the 3pt hitch. I find it's quite handy for adjusting the angle on a set of forks. It makes it a snap to lift a pallet, especially on uneven ground.
When moving material, I can put a FEL bucket on the 3pt and back into the pile. In addition to doubling the amount of material I can carry in a single trip, it also makes good rear ballast.
I also double the lift I can get with a 3pt boom.
/ Hydraulic Top Link? #35
As you previously mentioned, it's hard to put into words.
If I had never used one I'd want to remain blissfully unknowing.
Having used one for 12 years, I'll never be without.
/ Hydraulic Top Link? #36
How much have you used one, not much? I haven't either but it didn't take me long to realize how useful it would be on things other than the box blade on, especially when I put the boom pole on that tractor with the hydraulic top link.
/ Hydraulic Top Link? #37
I have operated lots of 3point equipment with and without a hydraulic top link, I very highly prefer having the hydraulic top link. But It definitely costs more money.
/ Hydraulic Top Link? #38
I also added tilt to my Kubota. At the time of installing it I added a Quick Hitch. I've never took them off in the last 11 years.
I think the cost justification has to be a personal thing. Some members here rarely use their 3pt or maybe only use it in limited situations.
If a member uses their 3pt on a wide range of implements, as has been mentioned here multiple times, TnT becomes a blessing.
/ Hydraulic Top Link? #39
How much have you used one, not much? I haven't either but it didn't take me long to realize how useful it would be on things other than the box blade on, especially when I put the boom pole on that tractor with the top link.
I have used one plenty. Like I said, box grader needs one. I moved 130 cubic yards in one day. Pulled it up with the box grader, had two dump trucks hauling it, loaded by two skid steers. I know it was 130 because I had figured the needed volume plus 20% addition for compaction of loose fill. Everything worked out, so my 130 number was fine.
/ Hydraulic Top Link? #40
Well, evidently, based on your assessment of the need for a top link, your use has been very limited. :)
Asphalt Melter (A61572)
Asphalt Melter...
2016 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2020 CATER PILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATER PILLAR...
