Saving a 5g fuel can
/ Saving a 5g fuel can #21
According to Posts #1 and #5 OP has a somewhat battered metal 5-gal. gas can that "has developed a little leak on the bottom". It is unknown, but likely, other leaks are developing. I am with ruffdog and 3 Horse Ranch, it is best to retire or discard the old can. How much time, aggravation, and money are you willing to spend to extend the life of the can? While I and others can relate anecdotal accounts of how we purged flammable liquid containers to work on them with heat or an open flame without blowing ourselves up, there is still some risk.
For around $70 - $100 OP can purchase a new "Justrite, Type II Safety Can" that has flame screen, overpressure protection, and a spout, that in my experience, works better than those plastic contraptions and that will probably last as long as the old "Eagle" can. If cost is a consideration, a plastic 5-gal. container is around $25. I discarded the plastic "no-spill" spout and cut a disk from an old plastic container to fit the hole in the treaded ring and thereby seal my new plastic container. I remove the new "cap" and pour directly into a funnel as OP likely does with his old can. There are many blogs and videos of ways to modify, adapt, and vent the plastic containers.
I happen to have identical can but mine doesn’t leak, if it did leak I would quit using it and replace it with a new No Spill can.
Can I have your old can! 😄
There is one type of these that seems ok with a push button to pour operation, I have a 2.5g but like so many things these days the spout is the first thing that I see failing and likely not sold separately so you junk the whole thing.
For around $70 - $100 OP can purchase a new "Justrite, Type II Safety Can" that has flame screen, overpressure protection, and a spout, that in my experience, works better than those plastic contraptions and that will probably last as long as the old "Eagle" can. If cost is a consideration, a plastic 5-gal. contaner is around $25. I discarded the plastic "no-spill" spout and cut a disk from an old plastic container to fit the hole in the treaded ring and seal my new plastic container. I remove the new "cap" and pour directly into a funnel as OP likely does with his old can. There are many blogs and videos of ways to modify, adapt, and vent the plastic containers.
It's a personal challenge. There's 3 metal parts to my cans, 2 of which can be had on Ebay by the half dozen. No BS springs, no flappers and no BS screens.😆
It's kinda like getting another year or so out of your favorite old boots. Ya just gotta try.👍
/ Saving a 5g fuel can #24
Another product I have used to seal gas leaks is Seal All. It's easy to use and works for gas and oil.
/ Saving a 5g fuel can #26
I retired a pair of Army boots last Fall. I was issued those boots in 2005 on my way to Iraq. They were so deteriorated that my socks got dirty if I walked in mud or dusty dirt. I had to force myself to throw them in the trash. I'm wearing the last pair I have. Will be a very sad day when these are worn out.
I completely understand the can issue Eric. Fix it and use it until it's used up.
Stand for something or you stand for nothing. :cool:
/ Saving a 5g fuel can #28
I fixed a small pin hole on the bottom of an old Evinrude gas tank with JB weld and it's holding up just fine. Just sand it and clean it up good and put a glob of JB epoxy over the hole. For regular gas cans I really like the plastic "utility jugs" they sell at TSC. They will hold 6 gallons and will empty very fast compared to the crappy ventless EPA cans.
/ Saving a 5g fuel can #29
I had a leak in my 1974 Ford puckup gas tank and I
sanded around the hole and used JB Weld it only
lasted for 10 or 11 years then I purchased a new tank
willy
/ Saving a 5g fuel can #30
You guys that say "replace it" just don't get it......
Eric, JB Weld is a very good product. Applied to the outside. I'd want the hole to be evident enough that I could squish the product thru the hole into the can a little. This would give it the best chance of bonding and staying put.
Keep us posted.
Awesome can!!! I have a smaller version with the more modern cap/vent system.
No I think we "replace it" guys get it.
I finally figured out buying cheap dollar store tools costs more because I have to buy the tools at least twice. Once when I am suckered into buying the cheap tool, the second time to replace the broken cheap dollar store tool.
A new gas gerry can cost me $25. JB Weld costs $15. Enough Kitty litter or oil dry costs $20 to try and sop up 5 gallons of spilled gas on my concrete floor.
If I go buy a new gerry can I will spend $25.
If I try and repair a gerry can it will cost me $60 and my barn floor stinks like gas for 6 months. Priceless.
/ Saving a 5g fuel can #31
I understand your feeling - Rustyiron. I have four military Jerry cans. Brought them with us when we came down from Alaska. I know - for a fact - they are OVER 55 years old. No rust - no leaks. Mainly due to - the design for military use, the UBER dry weather here - the cans NEVER sit on the ground. Alway up on a pallet.
Be very careful on how you repair that can.
/ Saving a 5g fuel can #32
Good math. Maybe reread the thread title.
/ Saving a 5g fuel can #33
Not to mention the fire hazard from that leaked gas. o_O
Good grief, it's just a gas can. From the looks of the can the OP posted, that whole bottom seam looks kinda sketchy. Buy a new poly one, an aftermarket spout and it'll last you the rest of your life.
Mike, good luck with getting 30+ years out of your new tank. This is a large part of my motivation, most new and improved chit is neither, particularly when it comes to a simple vessel to contain a liquid.
The beaurocrats have actually managed to screw up something that's been "developed" and used for thousands of years and worked perfectly.
If you read all of this you'll see that I'm poking fun at myself over this silly little toppic/post.👍
I think it's a combination of being a cheap ******* and slowly turning into an old fart "thing" and also rejecting the throw away mentality. 😄
/ Saving a 5g fuel can #35
Mike, good luck with getting 30+ years out of your new tank. This is a large part of my motivation, most new and improved chit is neither, particularly when I comes to a simple vessel to contain a liquid.
Well stated. I'm right there with you. I find comfort in the old things I use. :cool:
/ Saving a 5g fuel can #37
NATO Jerry cans are not cheap to buy, but are the best and lowest cost in the long run.
They are available in 2.5 & 5 gallon size.
/ Saving a 5g fuel can #38
I have a 30+ year Scribner and one I bought 2 years ago. Neither one leaks and the fit and finish are identical. Here is a video that compares Vp vs Scribner jugs and the caps that leak.
/ Saving a 5g fuel can #39
I have a gas can just like the one he has and I purchased
it in 1971 and no leaks and I spill a whole lot less gas when
pouring from it that one of the new stupid safety cans. In
fact when is wrong with fixing something old??? Lots of old
things are being fixed instead of buying new! The so called
new safety cans you don't dare leave them in the sun!!!!!! The
old metal gas cans you can leave almost any place without a
problem!! For the price you have to pay for one of these so
called safety cans is stupid! Plain and simple! Just trying to
pour gas from them is a hassle and very easy to spill gas!
Taking a 2/5 gal oil jug and painting it red is a 100% better
than a safety can! Probably won't spill very much gas and
no gizmo to mess with to get the gas out! Just simply pour!
When you have something good why not fix it????
willy
/ Saving a 5g fuel can #40
I guess storing a slowly leaking gasoline can in an open shed would not be real dangerous.......except for smokers....but.........if there is some doubt..........I'd THROW IT OUT.
Cheers,
Mike
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2015 International ProStar T/A Day Cab Truck Tractor (A61573)
2015 International...
Michelin 29 x 9.0 x 15 5 Lugs Tires (A61573)
Michelin 29 x 9.0...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
JOHN DEERE 310 - 16' DISC HARROW (A64276)
JOHN DEERE 310 -...
