Getting the wheel/tire combination I want on a new tractor
/ Getting the wheel/tire combination I want on a new tractor #1
Hendey T&G
Maine
2007 Branson 4720
I'm looking at a Mahindra 5145 and twice now I've been told I can't get R-4 tires with the 2 piece width adjustable wheels.
They can get R-1 Ag tires like that but not R-4s. I pointed out that the factory brochure shows the wheel/tire combo I want
but have been told they can't get them like that. Is the this the sign of a dealer not willing to go the extra mile or am I being unreasonable?
My property is very hilly and I need to get the wheels out as wide as possible. They told me I could turn the factory 1 piece wheels around and switch sides with them but there's no adjustment. I was also told I could use spacers but I don't want spacers.
Picture of brochure attached.
/ Getting the wheel/tire combination I want on a new tractor #2
Get the R1 tires, especially on hillsides.
I don't mind R-1s I just like the idea of the tougher side walls on R-4s.
I think part of my land was cleared with a big slasher and there are many punji sticks to contend with.
/ Getting the wheel/tire combination I want on a new tractor #4
The dealer is incorrect.... an R4 rim is much wider / deeper. You cannot "turn them around or swap side to side
Vs. an R1 rim:
Don't forget the R4's are much wider to begin with. The new R14's fit on R4 rims and are also wider.
/ Getting the wheel/tire combination I want on a new tractor #5
Vs. an R1 rim:
You are correct, 1 piece R4 rims as you have pictured cannot be turned. The OP has a picture of R4s on 2 piece adjustable rims on the tractor that he wants.
His posted picture is an OEM brochure picture with factory supplied tires and wheels. The 2 piece R4 rims are common on full sized utility tractors, I have them on my tractor. Maybe Titan has not caught up with their back logs, but the 2 piece R4 rims are indeed available and were a std item for Mahindra utility sized tractors.
/ Getting the wheel/tire combination I want on a new tractor #6
I bought R4s for 2 of my tractors. I was thinking the wider tires would be better on hills. I was wrong, They slide sideways on hills, don’t grip well. Last tractor I got R1, which are almost as wide as the R4s I had before. Will never get R4s again.
/ Getting the wheel/tire combination I want on a new tractor #7
You can get wide (or narrow) R-1’s with higher load capacities for loader work. I have some pretty heavy duty R-1’s on mine
/ Getting the wheel/tire combination I want on a new tractor #8
I think that the OP wants what is suppose to be a std no cost option for the tractor that he wants to get.
There are all kinds of options if you want to pay additional $$$$ which most people seem to prefer not to do.
/ Getting the wheel/tire combination I want on a new tractor #10
I don’t know if that’s true or not. One thing I do know, once you buy them you’re kind of stuck with them, so make sure you get what you want.
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
CHANDLER 500 BBL FRAC TANK (A60736)
CHANDLER 500 BBL...
CFG Industrial H15R (A60463)
CFG Industrial...
2017 MACK CXU (PINNACLE) (A60736)
2017 MACK CXU...
Pat's QH and hydraulic top-link.
Pat's QH and...
2024 JOHN DEERE 85G EXCAVATOR (A59823)
2024 JOHN DEERE...
