ATV advice
/ ATV advice #81
Yamaha Grizzly 700 doesn't. It's open or locked (Electronically via handlebar switch). I actually think most are this way unless there is no switch to engage the locker.
I looked up a 2012 Grizzly 700 4x4, and found "limited slip assembly" as part #6 in the "front differential" page of the parts diagram.
/ ATV advice #82
That may be what it's called but it isn't a true limited slip action, it's a locker. We had a 2012 700 Grizzly and now a 2019 700 Grizzly so I know first hand.
Limited slip by most accounts is a differential that will still apply some force to both axles via friction plates usally until enough traction is achieved by one of the tires to stop it then it will spin the tire with the least traction only. A locker will positively engage both axles and both spin.
Even today they call it that but it's not technically correct.
  • Yamaha’s Exclusive On-Command® 4WD
    Unlike so many computer-controlled 4WD systems on the market, the Yamaha On-Command® system keeps the rider in charge. With selectable 2WD, 4WD limited-slip, and 4WD with diff lock modes, the Grizzly EPS delivers power predictably and consistently.
What you really have is 2WD, 4WD with open front diff, 4WD with front axle locked.
Edit: I suppose it's possible they have some sort of limited slip clutches in it, but neither Grizzly seem to operate like they do, any little bit of mud and only one tire spins. Once we lock it though, they ALL Spin evenly.
/ ATV advice #83
Yes, the LSDs are usually just one or more clutch discs that impart torque to the faster-spinning axle, and fluid viscosity is one of the methods of transferring that torque. I suspect that in normal off-road driving in 4x4 mode, the outer front wheel would usually be spinning on any turn, without LSD. Hence the need.
/ ATV advice #84
No, In 4WD unlocked mode the open diff allows the tires to rotate at different speeds through a turn, in 4WD locked, you better be in some low traction terrain so that either wheel can spin as needed, usually it's the inside wheel that will spin or slip.
On pavement you can't hardy get the front handle bars to turn if it's locked, try too hard and you risk busting the diff. or an axle.
/ ATV advice #85
Greetings, TBN!
I've lurked and looked through some old threads here, but would like to seek input on a good ATV for my purposes, which are typical in many ways, but possibly unique in others. I have both a four-wheel tractor and a two-wheel tractor that are used for mowing, hauling, ground engagement, etc. These work well in the summer, when the ground is firm, but dig into the ground significantly when things are wet - and, living near Seattle, that's 9 months out of the year. I've been trying to smooth things out on my property for a few years and I've reached the point where I'm doing as much damage with my equipment as I am fixing. I am looking for solutions.
Up until recently, I've been considering a set of tracks for my two-wheel tractor, but they're close to $2k all told, and it occurs to me that an ATV would not only accomplish a low PSI for ground contact, but perhaps match or possibly increase the pulling/towing power of my two-wheel tractor, and also be a whole lot of fun. So here I am, contemplating another vehicle. But which one?
In terms of new choices, I am initially attracted to the low-end of the Honda line (420cc) for its price, torque and reputation for reliability. However that is a relatively uninformed opinion. I don't know much about ATVs, so I'm here to be advised, convinced, and educated. My interests are low PSI, pulling capability, reliability, and safety of rzr xp1000 accessories(no special features needed, but I'd like to avoid 'tippy' ATVs). I'll probably spend most of my time under 10MPH. And of course I'd like to keep cost under control. What new ATVs should I consider?
I am certainly willing to consider used ATVs if they are reliable and relatively easy to work on, but thus far the used ATVs I see for sale in my area seem fairly expensive. I can get a 20 year old ATV for about half the cost of a newer one, but that path seems like it may be more expensive in the long run. I may be looking in the wrong place, and not thinking about other considerations. If anyone thinks used is the way to go I'd love to hear their suggestion of models and rationale.
Many thanks!
Keep an eye out for those big, pretty picture ads on CL that ask you to click on a link/connection. Almost ALWAYS a scam. I only say that b/c both of those deals seem almost too good to be true. Maybe we just have a nasty Cost of Living adjustment here in New England but i don't think i'd find either of those quads for less than $4-5K.
Do you know what year the Polaris is? Don't have a lot of experience with Bombardier, can't go wrong with a good polaris.
/ ATV advice #86
I would stay away from the Honda Rancher 420 in the 2009 vintage, they have an auto trans that is shift button controlled and they are known for shifting issues. My neighbor has one and he brought it to me to try and figure out what was wrong, what I ended up doing and it seemed to have fixed the problem was replace the PCM and shift angle sensor. I believe the model number is TRX-420FA, if it were me I would stay clear of that one. This same problem happens with the 350CC of the same vintage but, you can remedy the issue by adding a couple of relays and bypassing the shift circuit through the computer which makes it a very reliable method of remedying the issue. Hope this helps with your search.
/ ATV advice #87
For years we operated 700 Grizzly's and Kodiak in hash conditions. I'd call them good.
/ ATV advice #88
To me, ATV and UTV are completely different options. Unless the ATV is like Arly's 6x6 with a bed. I'm only talking here about work machines.
An ATV, to me, is for herding cattle and checking fences and quick transport across the property.
UTV, on the other hand, is like having a small truck and workshop platform that can get places and haul things. Also better for multi-person use. Not so good for cattle work (though you could do it).
If I was not going to work livestock, I'd go UTV. Otherwise, I'd want at least one ATV.
/ ATV advice #90
Very different.
Seems to me that if you are chasing cattle, a 4-stroke dirt bike would be better than either ATV or UTV. Can't carry a lot of tools, yes, but neither can you on a horse. But I am no rancher.
The best tool for the job is not always what you have.
/ ATV advice #91
Very different.
I don't ranch , but have family in the Black Hills with a sizeable ranch. They use a few horses and a small fleet of ATVs, and one sporty sxs. My Cousin used a bike when he was young, and dumb and full or hormones. Hard to ride a bike with a calf aboard. You can put a calf on a horse or an ATV. Hard to get the dog on the bike, either. Though they don't do well on horseback. :)
The last time we were out there (2020), there were some cattle that had just got out and we had 3-4 ATVs rounding them up. The bike doesn't work so well when you have to stop and open a gate. Kick stands don't work well on soft ground. Bikes also have a hard time going slowly. Bikes are fun, but not the best for ranch work, imho.
/ ATV advice #92
I used a Polaris Ranger to coral cows whenever we were taking them to the market, worked like a charm.
/ ATV advice #93
My ATV since new is a 2006 Arctic Cat 400cc 4x4 automatic, 2 inch receiver hitch (standard) hand brakes on both handles, snow blade and cargo seat
it had better clearance, towing capacity, beefier cargo racks on front and back, and improved features for my needs than the Honda, Yamaha, Polaris, and Suzuki (same local dealership). I have had it flying at 95 kms / hr (stock)
/ ATV advice #94
I am assuming you purchase an ATV by now ? ,... anyhow I will give my two cents... Hauling and light weight don't mix well. Wide tires help distribute the weight and minimize ruts, so I would consider getting wide tires with ''small'' treads yes it minimizes traction, but it also optimizes flotation. ATV in general have very good flotation unless it's pure muskeg it's not 100lb that is going to make a difference if you compensate with tires, but tires can bog down a low hp ATV so it's a trade off.
I love honda but I find the new Honda with low cc's lacking torque even on low gear. Honda in the 2000's often had trouble with their rear differential and their thumb shift. You can't beat a Honda engine, but the suspension and ride comfort are not the best but for what you want to do with it, it's no factor... I grew up with a Kodiak 450 not sure the year but early 2000's, we beat that thing really hard, and we didn't put much money in it, and it is still running strong so I dont have anything to say againts it.
Now I wouldn't buy anything other than a Can-am they are well built, strong and have a smooth ride, after that it would be between Honda and Yamaha the last would-be Polaris, I wouldn't touch a polaris ATV even if you gave it to me, in between is fair game. Compare the axel diameter and the geometry of the CV joints and shaft it speak for itself and it is most of the issue you will have with them.
/ ATV advice #95
as with tractors, ... Dealership support, relationship, and location, are also good factors to consider. i needed a workhorse (12 years before I bought my tractor) and Arctic Cat won it for me.
preferences may vary :)
/ ATV advice #96
thank you so much for your suggestion
/ ATV advice #97
Honda is an innovator in the ATV dept, since 1969/70, esp with respect to transmissions.
Current models still preserve the ancient semi-auto trannies, whether foot-shifted, or solenoid-shifted with push buttons on the handlebar. They also have had the Hondamatic torque converter ATs, borrowed from the long-forgotten CM400 and 750A motorcycles from the 1980 era. (I had a CM400A.) They also offer a dual-clutch AT now. I have not tried it, but it is intriguing.
I have had a few of the electric-shifted semi-auto Hondas (350 Rancher and 450 Foreman). In the case of the 350, the ES had failed due to wear-out of the mechanical shift mech internally. An easy fix. I am not a big fan of this kind of trans, but it easier to shift than the foot shifter, esp if not wearing decent shoes.
I do think you can't go wrong with any of the name brands, tho I think Polaris, from my experience, is not as reliable, esp with brakes and gauge clusters.
Note that Arctic Cat used to use Suzuki engines/drives, but now uses Kymco for most mechanical components, and is called Textron. My own personal use 2017 Kymco MUX450i has worked flawlessly. Same mechanicals as in the AC.
If considering a large ATV with 4x4 and locking front diff, seriously consider the power steering option, or you will have difficulty steering when the diff is locked.
Rear independent suspension is a big plus if you want a softer ride. Rubber suspension bushings WILL wear out eventually, and all 32 will need to be replaced (big job). Something to consider if keeping the quad a long time, or buying used.
/ ATV advice #98
Whatever you do, don't buy a Can-Am ATV.
After 35 years of riding Honda, Suzuki, Polaris, and Arctic Cat I bought a brand new Can-Am Outlander 570 last year. It's been the worst piece of **** I've ever spent money on. I work on it more than we ride it. 13 months old now, 800ish miles on it, and I think it might be to the point where I can use it this summer without fixing something else. What a piece of trash.
The plastics have gone brittle and literally fell apart in some areas, it overheated constantly so I had to install a radiator relocation kit, servicing it is a nightmare, brakes literally fell apart and the pads and calipers were destroyed, front diff whines like a couple of cats fighting, front diff drain screw is installed from the factory at an angle so it got stripped upon first service, I can't even remember all the issues. And this is in the first 12 months. Pathetic.
/ ATV advice #99
We have the outlander 1000, 6x6 and have liked it. Have had greif with front propeller shaft which we think we fixed. Only use it for work thought.
/ ATV advice #100
After all those why not go ahead and step up to the best and get a Yamaha? :)
We have 3 now (2007 Raptor, 2019 and 2022 Grizzlies) and I had others over the decades and Yamaha's always have been trouble free and perform as well or better than all the others.
Claas Lexion 700 Series Folding Grain Bin Panels (A63117)
Claas Lexion 700...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
JCB 92" Clamshell Bucket (A64119)
JCB 92" Clamshell...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
KUBOTA KX057-5 EXCAVATOR (A65053)
KUBOTA KX057-5...
