Protecting top on a new welding table
/ Protecting top on a new welding table #1
YanmarFever
Elite Member
Eating a melon..
Branson 4520r 5520C- Yanmar FX235-D - Bad Boy rogue mower
Im putting together a 4'x'8'x1/2 table with 4"x4" legs to do a few projects.
What is the best liquid, wax, or polish to keep it from rusting? This is my third table this size and the previous ones never rusted because I lived in a state that rust wasnt a problem.
However, now I live 10 miles from the ocean and rust has become a problem.
The other tables I would just spray them with spatter spray, wipe them down and call it good. Also I used them for 8 -12 hrs 6 days a week, which was probably the best thing I could of done.
Now that I'm retired I wont be using it as much, sooo are there any suggestions for keeping the rust off?
No oil, it transfers to your project then its a pain to paint later.
I will post pictures later... :D
/ Protecting top on a new welding table #2
following for the replies but Maybe black stove polish. seems to work in high heat applications but may make a mess on projects and no idea if it affects welds or paint after
You would think that there is some kind of wax that would do it...
/ Protecting top on a new welding table #5
I wonder if slickcote or glidecote would work??
I always just wipe mine down with Amsoil MP
/ Protecting top on a new welding table #6
Mine get greasy and oily from use but when they do get rust or grime I just clean them with the side grinder before I use them for welding.
/ Protecting top on a new welding table #8
Buy some cheap vinyl (disposable) table cloths...covering the table will greatly cut down on the rust...they are only a couple bucks...maybe even cheaper at the dollar stores...
Running a dehumidifier when there is high humidity will make a big difference...
/ Protecting top on a new welding table #10
My is made from what I assume is mild steel, 1" thick. I built it 12 years ago. Only way it tries to rust is when I get stupid and sit an iced drink on it and forget. 3-4 times a year I spray it with PB Blaster and wipe it down just because my conscience bothers me that I'm neglecting it.
I weld on mine a lot so a paint coat wouldn't work for me. I expect to clamp the welder ground to the table, throw something on it, and start welding.
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
4'x6' Stack of Sheet Metal (A60463)
4'x6' Stack of...
2005 KENWORTH T800 OPEN ROLL OFF (A60736)
2005 KENWORTH T800...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
Kubota LX2620 (A53317)
