Protecting top on a new welding table
   / Protecting top on a new welding table #1
YanmarFever
Elite Member
Eating a melon..
Mahindra 5010C- Branson 4520r- 5520C- Yanmar FX235-D - Bad Boy rogue mower
Im putting together a 4'x'8'x1/2 table with 4"x4" legs to do a few projects.
What is the best liquid, wax, or polish to keep it from rusting? This is my third table this size and the previous ones never rusted because I lived in a state that rust wasnt a problem.
However, now I live 10 miles from the ocean and rust has become a problem.
The other tables I would just spray them with spatter spray, wipe them down and call it good. Also I used them for 8 -12 hrs 6 days a week, which was probably the best thing I could of done.
Now that I'm retired I wont be using it as much, sooo are there any suggestions for keeping the rust off?
No oil, it transfers to your project then its a pain to paint later.
I will post pictures later... :D
   / Protecting top on a new welding table #2
following for the replies but Maybe black stove polish. seems to work in high heat applications but may make a mess on projects and no idea if it affects welds or paint after
You would think that there is some kind of wax that would do it...
   / Protecting top on a new welding table #5
I wonder if slickcote or glidecote would work??
I always just wipe mine down with Amsoil MP
   / Protecting top on a new welding table #6
Mine get greasy and oily from use but when they do get rust or grime I just clean them with the side grinder before I use them for welding.
   / Protecting top on a new welding table #8
Buy some cheap vinyl (disposable) table cloths...covering the table will greatly cut down on the rust...they are only a couple bucks...maybe even cheaper at the dollar stores...
Running a dehumidifier when there is high humidity will make a big difference...
   / Protecting top on a new welding table #10
My is made from what I assume is mild steel, 1" thick. I built it 12 years ago. Only way it tries to rust is when I get stupid and sit an iced drink on it and forget. 3-4 times a year I spray it with PB Blaster and wipe it down just because my conscience bothers me that I'm neglecting it.
I weld on mine a lot so a paint coat wouldn't work for me. I expect to clamp the welder ground to the table, throw something on it, and start welding.
2014 Ford F-250 4x4 Ext. Cab 8ft. Flatbed Truck (A55852)
2014 Ford F-250...
2016 Toro Reelmaster 4 Gang Mower Attachment (A55851)
2016 Toro...
Mini John Deere Truck (A55853)
Mini John Deere...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A55315)
2019 Cadillac...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
30KW GENERATOR (A58214)
30KW GENERATOR...
