2022 Outlander Max 6x6
/ 2022 Outlander Max 6x6 #201
Just throttle it up though all rpm range when mapping torque and hp curves while making adjustments.
Full pull to see max hp but torque has already dropped off at much lower rpm (as one would expect for it at over 9 liters.) Even torque at 850 rpm idle was surprising.
Ideal would be a flat torque line though all rpm ranges but that isn’t realistic, it drops off=hence the curve
As to your throttle position point. I guess I’m not sure if we are making the same point in different ways.
My only point is that judging the force on individual components by throttle position when plowing vs towing isn’t a good way to encapsulate your failure margin.
Impact or shock loads, dynamic weight transfer (lifting plow/snow loads) and more/less force on rear vs front drives, turning asymmetric weight/force with loads or impacts etc.
It isn’t surprising that it broke plowing at less throttle or even driving/turning with those pods.
It seems to be a lot to expect from that front end I'm sure the rear is more robust for weighted pulling (that would offload the front)
/ 2022 Outlander Max 6x6 #202
(Ps, arlya, I hope u get it fixed and it holds up)
It appears the “sleeves” also slide off? If so, that makes mating up a custom shaft a lot easier
Not sure if people are more interested the stress of plowing virs grooming or the actual repair. I got this responce on the can-am forum. I like the idea.
It's using the rigid boot on both ends. Ostacruiser gets credit for the "mod", but it's fairly well-known know afair.
The accordion boots allow that shaft to move ever so slightly, sliding between the through shaft and the front diff input. When you're really torquing the motor, it can allow for just enough slack for that front shaft to pop out, and you get what you've got. Solid motor mounts and double-rigid-booting the front shaft is the cure.
/ 2022 Outlander Max 6x6 #204
I wonder if under torque, the splines allow the shaft to walk it's way out of the sleeve? So, with your constant pulling the groomer then gives the shaft plenty of time for this issue to happen.? I then see where those HD boots would restrict the shaft's movement. (y)
Well that pretty much is what the poster states.
I'm searching for this "double-rigid-booting" the poster mentions is the fix. :) I now have high confidence this can be fixed.
/ 2022 Outlander Max 6x6 #207
See first video...post 155
I watched the video in hopes of seeing part numbers. Maybe I missed them? I did ask on the can-am forum for parts numbers. I hope to get these boots switched out before it pops out again!
/ 2022 Outlander Max 6x6 #209
Done beating a dead horse looking for reasons and solutions why the front driveshaft splines failed but this modification to groomer coupler probably won't hurt especially reducing hard impacts when starting and stopping. Made this pin coupler with junk I had lying around 15 yrs ago for a trailer to pull behind a snowmobile yes it's crude, but works better than I imagined. Haven't snapped an non reinforced bumper on a snowmobile since. Eliminated hard impacts when starting and stopping. I've seen similar with folks using hockey pucks unsure of results (I use those for hockey only lol) anyways used a medium duty spring I cut in half welded a washer to shaft midway and stoppers on both ends. I suppose if I had a groomer, I'd use a heavier spring, thicker metal, and weld it all up with 7018 from the get go.
/ 2022 Outlander Max 6x6 #210
I started making a version of hitches similar to that back in the 70's, using chevy valve springs for the springs.
It's the only way we could get a load going, up in the Alaskan mountains.
SR
/ 2022 Outlander Max 6x6 #211
SR
Unsure if I saw it or just thought it up probably a little of both. Anyways when I used to make wood in the winter was the only way to get a big load moving. Now I pull the family around with it lol.
/ 2022 Outlander Max 6x6 #212
We would go so far on our sno-machines we would have to pull some gas on a home made sleds behind. Deep snow and mountains doesn't make for good gas milage.
SR
Break away hitchs were once used on XC implements but they've since lost favor and thank god since because they were awful. Striking hard objects is not a problem for us and we do not use those hitches or the ones with rubber shock absorbers.
/ 2022 Outlander Max 6x6 #214
Break away hitchs were once used on XC implements but they've since lost favor and thank god since because they were awful. Striking hard objects is not a problem for us and we do not use those hitches.
Not a breakaway hitch just a hitch that applies gradual tension and pressure when pulling and stopping instead of a hard instant impact to drive line anyways good luck.
/ 2022 Outlander Max 6x6 #217
Arly despite your copious snowfalls, it sounds like you're also suffering from a pretty crappy winter too.
I think we're pretty much done with any meaningful snow accumulations and the +/-20" that we have on the ground is getting to an "annoying" condition if you know what I mean.
/ 2022 Outlander Max 6x6 #218
We are yet to have the first snowfall here, that's a bit unusual. None the less I'm ready for spring.
Interesting trailer setup to load downed trees into this trailer to be towed out via 6x6. I'd say pods were not need in that low volume of snow. What does that idler wheel between the axles do on this trailer?
/ 2022 Outlander Max 6x6 #220
Drive sprocket to independently propel trailer from loader hydros if they put tracks on that rig? Cool set up
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
Frontier RC2072 (A64126)
Frontier RC2072...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
