Grapple (mytractortools.com)
/ Grapple (mytractortools.com) #21
Green - yes. That picture( post #13) was taken on July 3. Same area - August 18.
A grapple would have been a BIG help when we burned wood. Raise that trunk up off the ground and not cut so darn much dirt. In this part of the world everything is still packed with volcanic ash. 1980 - Mt St Helens. I fall a large pine due to Pine Bark beetle - leaves a vapor trail of volcanic ash when it falls. My undisturbed meadows still have a two inch layer of ash - very near the surface.
I've found that a really wide grapple is unnecessary when gathering up brush, limbs, vines, etc. It all kind of gathers up and the grapple holds it all together. My Land Pride grapple is 60" wide. That rock & root grapple from mytractortools would probably serve just as well. At 100# it's sure a heck of a lot lighter.
Jery said it it wasn't really for brush but i will certainly use it for that. there is so much created when cutting up a tree. This will be a slick way to move the debris. Also much quicker than using my forks. To avoid getting into dirt with my saw. Once a year Ill rent a mine excavator. Use that to pick up the fallen tree and cut them up into 10-15ft logs. Take them back to my stoned area. Where i have a log cutting frame to put them in. It serves two purposes. Keeps the log elevated so im not spending a ton of energy bending over and makes ease of cutting the log. Once i get this grapple ill most likely use it instead of the frame.
/ Grapple (mytractortools.com) #23
At just 100# for the rock and brush grapple - it's a most interesting implement. My Land Pride grapple is 820# of A400 steel. It allows me to lift - with great care - loads up to 3000#. I seldom lift loads this heavy. If I do - the lift is kept so close to the ground - it leaves knuckle drag marks in the dirt. Most of my lifting is in the 2000# to 2400# range. Large rocks and chunks of pine tree trunk.
That grapple would look interesting on his little Massey.
/ Grapple (mytractortools.com) #25
Hey gang
I have the (Massey) 1705 i purchased new in 2016. I ended up getting the quick attach for my tractor with the forks from mytractortools.com. its been a great purchase. Im looking to get his grapple for my machine and was wondering if anyone here had it. If they liked it. Ease of install and so on. I sent him an email end of the week last week about pricing. I may just call him. Looks like he maybe trying to sell his business.
I had my Massey dealer put a 48 inch CID grapple on my Massey GC 1723 and I love it. The grapple with the quick change bucket is the best thing I ever bought for my tractor
those look nice.
You are absolutely correct that the Quick attach is a must have. Jery's quick attach (tach n go) comes with the ability to allow you to put a hitch recoverer into the quick attach. It allows me to move my trailer with my tractor. Its ease of use rather than using my pickup to move it on property. His grapple is only 70lbs as well. Im looking forward to it
/ Grapple (mytractortools.com) #27
those look nice.
Nice. I wish I had that feature to put boats down the ramp to the water.
/ Grapple (mytractortools.com) #29
Doe anyone have one of these? I wonder if there is a way to mount it to a SSQA plate?
This is exactly the one im getting. Jery is the guy that owns this business. Its where i got my quick attach and forks. His quick attach is awesome b/c it allows you to insert a hitch receiver into it. I can move my trailer around on my property or check air pressure without using my truck. So its really handy. I dont think any other company has that with there quick attach setups. At any rate im excited about getting this. Its light as well. It will come in handy for my firewood processing
/ Grapple (mytractortools.com) #33
Is this quick attach compatible with other attachments? Such as an FEL bucket?
Yes the loader bucket that comes with the machine works with his quick attach. So you purchase his set up. Unpin the bucket, install quick attach, and then re-attach your bucket. Here are the two main reasons I went with his set up
The quick attach allows you to insert a hitch receiver. This allows me to move my trailer around on my property without using my pickup. Its really nice. Or my wood splitter.
The forks that you get from him that go with his quick attach setup can also be hooked up the 3pt as well. I have used this variation several times for tasks. Nothing special is needed either to do this
/ Grapple (mytractortools.com) #35
So,, you don't have an SSQA bucket? You unpin your bucket. install his bracket. And your bucket will quick attach to his quick attach? I struggle to see that using the pics as a guide. I'm very anxious for you to get this and post some pics of it in action!!!! :cool:
/ Grapple (mytractortools.com) #36
On your factory bucket, Jery sends pins to install in it. These pins are non greasable. The factory ones which are greasable go into the Tach-N-Go to hold it onto the FEL arms. The Tach-N-Go picks up the bucket with these pins. The stationary forks I have from Jery have "pins" welded in it to be picked up by the Tach-N-Go. And it has holes in brackets that get loose pins through to hold it on the 3pt arms and top link. Does this make Jery's system easier to understand? Jon
the above poster hopefully shined some light on this. But Jery has made his quick attach bracket so that it uses the original bucket. The QA uses those pins on the bucket. Basically what he did is put some thought into this so the owner does not have to buy another bucket. Which is what most QA systems do. Ill take a pic of my set up tomorrow and post the pics
/ Grapple (mytractortools.com) #38
Seems like a pretty ideal system for a BX because with such limited lift capacity you don't want to give up any more than you have to with the weight or 'stickout' of the QA, and with his design it seems very optimized that way. All the same conclusions ive come to from my own research/experience/understanding all seem to be made use of in his designs. One thing i like which he does is make use of the 2" receiver for actual implements. Not every 2" receiver is actually strong enough to deal with even a small loader but if you make it strong enough than it is! Even a 1/4" wall 2" square tube is able to deal with a good amount of what a small loader can put out, and it's sort of the ultimate 'quick attach' for anything light enough to pick up because it's as simple as sticking a drawbar in the back of your pickup truck. It's extremely easy to build your own custom doodads for a 2" receiver format.
So im a big fan of the designs. I don't have a BX but working with a lot of the same size/strength constraints on my B6100 FEL it's obvious that his stuff is purpose built for the limitations of the small machine, vs slapping a 45" wide SSQA on everything and calling it a day. I have nothing against the SSQA format but on the smallest SCUTs it forces you to 'build in' about 60-100 more lbs than you probably strictly need and it dictates a certain minimum width and height for everything. If you're only going to have a few front end attachments it makes sense to reuse your existing bucket and build the other couple things to a super simple format (2" square, with an extra brace here or there as needed) that is strong enough for the job.
here is the pic
17394SFL (A61568)
17394SFL (A61568)
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2019 Chevrolet Express 2500 Cargo Van (A61568)
2019 Chevrolet...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
