Compact Tractors are Designed All Wrong
/ Compact Tractors are Designed All Wrong #401
Funny you mentions SHARP teeth. When I got my rock bucket with teeth from PowerTrac, the teeth were about 3/8" thick and rounded. They had a flat face. Someone on TBN suggested I sharpen the tips with a grinder. I did. GRRRRrrrr!! Digs right in now. Teeth make a huge difference VS a flat straight edge of a bucket. And they help in loose material like gravel, rocks and mulch, too.
/ Compact Tractors are Designed All Wrong #402
When I had a skidsteer, it came with a plain bucket and a tooth bucket. The tooth bucket never came off. Most of my work was in the woods and ditches, and the tooth bucket was a must. I actually preferred it for spreading and smoothing - the teeth chopped up and tore apart the roots and grass, and when tilted, it was like a sawtooth trowel that made smoothing out easier.
/ Compact Tractors are Designed All Wrong #403
I have a grapple bucket with teeth and a large material bucket with a tooth bar. Then I got the Ratchet Rake for the LMB. I like it much better - easy on and off and the downward facing teeth get used for removing gravel from the lawn due to snow plowing, scraping off weeds and grass, etc. A very useful implement when needed. Making your own would not be that hard. I have used it for digging but the conventional bar is better if doing an extended amount of digging.
Ratchet Rake, LLC - All Terrain Rake, Snow Edge, Tractor attachment, Bucket attachment, Loader, Skid loader, Kubota, Skid steer, Landscape rake, Brush remover, York Rake, Harley Rake, Rock Rake, Tractor rake attachment, Construction attachment, New Holland, Bobcat, Fire safety, Home fire safety, Fire prevention, John Deere, skid steer attachment, tractor implement
/ Compact Tractors are Designed All Wrong #404
One more year and we can get an antique tag for this thread. :)
/ Compact Tractors are Designed All Wrong #410
I read this thread and came to realize that Power Trac is better than any CUT ever made ;)
/ Compact Tractors are Designed All Wrong #411
If [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] made several smaller classes of loader than this. Make it with skid steer loader attachment and a 3 point hitch in the rear for your "old style" implements
Bruce
/ Compact Tractors are Designed All Wrong #412
We don't have to worry about you going in the tractor business.
/ Compact Tractors are Designed All Wrong #413
If Kubota made several smaller classes of loader than this. Make it with skid steer loader attachment and a 3 point hitch in the rear for your "old style" implements
Bruce
Bobcat makes smaller ones but no 3 point because articulated steering would drag the attachment sideways: https://www.bobcat.com/na/en/equipment/loaders/small-articulated-loaders?perPage=11
/ Compact Tractors are Designed All Wrong #416
Moss Road has not bumped this "antique" thread recently, so I will for those that have not seen it and all the good information in it.
/ Compact Tractors are Designed All Wrong #417
The OP's premise that most CUT applications are mowing grass is wasted on me. I have three CUTs, and have never mowed a blade with any of them.
/ Compact Tractors are Designed All Wrong #418
This reminded me of the Chalkey Cup thread. Now I can't find it though.
/ Compact Tractors are Designed All Wrong #419
Here's one...
Here's the original, but the pictures are long gone...
/ Compact Tractors are Designed All Wrong #420
Never mowed a lawn with one, but I've mowed fields plenty of times.
Rogator RG1100 (A63688)
Rogator RG1100...
JLG HC3 8ft Boom Lift Man Basket Attachment (A61572)
JLG HC3 8ft Boom...
RoGator and Terragator Manuals (A63117)
RoGator and...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
