My Micro Hydro Project
/ My Micro Hydro Project #1
Ktm rider
Member
Kubota MX5100
So I researched Micro hydro for probably 10 years and finally decided to pull the trigger on it since the political climate isn’t very promising and I retired and needed A project.
I did post a about this a few months ago on another thread but Inthought I’d start my own and show my progress.
My system measurements are 500+ gpm flow 990 feet of 8” penstock and 60 ft of head. I have two turgo turbines custom made my Spencer at Langston Alternative Power. A Growatt split phase 12k inverter going into six Lifepo4 Lithium Phosphate batteries. Along with 20 230w solar panels that will be installed in the spring.
I guess I’ll start at the beginning. I hand built the weir from rocks on my property.(pic#1) This took WAY longer than expected and was very time consuming. I’m talking over 100 bags of motar/ concrete used. I also poured the concrete box that the coanda screen sits on. (Pic#2)This saved my about 6k verses buying a prefabbed stainless steel one sized to my system.
I then buried the 8” penstock in the Very rocky ground just beside the creek. (pic#3) My Ford 555 backhoe didn’t miss a beat in the rocky soil.
990 ft later ( and about 4 months..lol ) I got to the end of the penstock run and installed the turbines. (Pic 4,5) Due to the huge rocks down off this hill, I couldn’t get the powerhouse floor and the penstock completely square but I got it workable and close enough.
I am now working on burying the wire 360ft up to my house and to the inverter and battery bank.
I have done this project 100% solo so far. I ran into some pretty good roadblocks along the way. The huge rocks were an issue. I had to buy an electric jack hammer to break up some of the absolute huge rocks I couldnt dig out with the backhoe and just cut a wedge out of them to allow the pipe to sit properly.one rock took me about 6 hours of constant hammering. Not fun at all.
then getting my backhoe back out of the thicket / woods because the pipe wasn’t buried yet and a snowstorm was coming took two full days of cutting trees brush. I finally got it back home safe and sound.
once I get the line to the house buried it’s on to installing a sub panel. This is the part that I may have to recruit an electrician friend to at least look over once I’m done installing.
So that is my progress so far. Any advice and or questions are always welcomed.
/ My Micro Hydro Project #5
Very cool project ... I always wanted to build some like that, is your stream flows all year round? where about are you located? is the winter is going to affect the stream flow or its components?
/ My Micro Hydro Project #6
Thats a lot of work you have done there, thanks for posting. Hope you will continue to post on your progress.
/ My Micro Hydro Project #7
Awesome project. I never knew that hydro power could be scalable. This is great. Keep up the good work KTM!
Very cool project ... I always wanted to build some like that, is your stream flows all year round? where about are you located? is the winter is going to affect the stream flow or its I live in the mountains on the western and/Wv border.
I live in the mountains on the Wv/Md border and our summers are very cool. We don’t even have AC at all. Just ceiling fans. So we designed this system to get the max out of the winter time flow. I should make enough power to not only power but to also heat
My house in the winter. We just installed a Mr Cool universal heat pump.
The stream slows way down in the summer which is why we also have 20 solar panels to supplement the system. But like I said we don’t have AC so our power needs are much less in the summer months. Even though the new heat pump does have AC we will probably rarely use it if ever.
It’s actually very scalable. I’ve seen some systems as small as just a few hundred watts using just a 2” poly line.
There are many examples on youtube
/ My Micro Hydro Project #10
KTMrider
A couple of questions about the project come to mind:
What voltage do the turbines generate?
what voltage do the solar panels generate?
Does the inverter have to 'play nice' with both inputs?
Does the voltage drop on a 360 foot run require increased wire size?
Is there GFCI/AFCI protection on the electrical outputs?
DC/AC outputs?
I have a 7500 watt solar array installed 3 years ago. I ran into voltage drop concerns
that required conductor upsizing due to inverter manufacturer requirements. Added to the costs.
The DC output on the array is 400v +/-.
And since the AC voltages at my place 'run hot' -125/250volts, I had to fine tune the inverter output.
I am following this with interest because in the future I will add battery bank to the system.
(I get yearly incentive from my utilty right now so when that expires the batteries will go in.)
Great job and good luck,
regards.
R
I am actually
Not a new member. I have thousands of posts on here as “Scesnick” but I retired from work and that was the computer I posted from and signed up with. Now I can’t retrieve my old account
/ My Micro Hydro Project #12
500 gpm?!? wow. Thats a lot of PVC. Total system cost?
Do you have a macro diagram of the whole system? For example, why do you need the coanda effect, where does it help make power? Why do the turbines have multiple valved inlets like that?
How long do you expect all that PVC to be durable and functional for? (is it UV stable)
/ My Micro Hydro Project #13
Those are good questions, Back in the early 1980's I helped set up and designed some control and switching circuitry for a micro hydro for friend.
He had over 150 feet of drop but State limited year around flow.
The state granted a specific amount of GPM that could be taken from the creek IIRC~15 gallons a minute.
System ran 24 7.
We learned a couple things running a Pelton wheel driving a GM alternator to a large bank of batteries and a 10K watt Trace now (Xantrex) inverter and the much lower flow but much more head than what the OPs system is.
First when the system is running Never shut the flow off quickly down at the Pelton wheel or turbine feed.
We did it once and it caused a hammering (spike) of the water pressure blowing the pipe up at the bottom.
Second if/when the pelton wheel or turbine is subject to varying loads.
You need a ballast of sorts in addition to charging batteries and feeding an inverter. Today lots of solutions available.
Back in 1984 not so much.
I built a sensing circuit that would switch in a 200 watt water heater load when the batteries voltage was at peak. Without this load switching the pelton wheel at times would "run away" and damage itself and the alternator bearings.
My friend sold the Off Grid place about 15 years later and other than bearings and batteries and filtering the water to not plug the chosen jet size the system was very trouble free. IF it hadn't been for the advent of OP amps and MOSFETS we would have not succeeded.
OP That looks like quite a system you have built.
If you have enough 24 7 water flow you should have more power than you need.
Threads like these make ne want to install solar and battery back up. Micro Hydro would be great but we don't have any here.
KTMrider
DC/AC outputs?
regards.
R
Yes my Growatt inverter has a 7kw input for the hydro and a 7kw input for the solar. ( although it is classified as a 12k )
/ My Micro Hydro Project #15
System ran 24 7.
yeah my problem where I am from is most stream we have around stop flowing during the winter and in the middle of the summer, that why I was wondering about Ops situation but looks like he has the best of both worlds.
I don’t have a diagram. The coanda screen is simply to keep any and all debris out of the penstock and the turbines. Coanda screen is well worth the money to protect your turbines.
The turbines were designed for 500+gpm, so at maximum flow all eight valves( jets ) will be open. As the flow decreases towards summer you close the jets according to the flow you have to obtain optimal pressure to spin the turgo wheel.
As far as the PVC, all the penstock will be buried so no worries about UV damage or falling trees and stuff like that. The turbines and all the piping for the turbines will be I closed in a powerhouse eventually. I just haven’t gotten that far yet.
As far as system cost. Well, that depends on what u want to achieve and how you want to utilize your grid power. I also have 6 lifepo4 batteries that were the most expensive part of the whole system. ( see pic ) I saved about 5k by pouring my own concrete coanda box. I also dug around on eBay and found the double wye fitting ( where the pipe sits into two for the turbines ) it was around 1k but I got really lucky and found that one for $150.
Right now I would guess I have a little over 20k in the whole thing. That’s all the 1,000 feet of penstock (which I also got a great deal on ) both turbines, the inverter and the batteries. Then I also had a good bit in concrete and other fitting and such.
/ My Micro Hydro Project #17
I would love to be able to experiment with small scale hydro. I even have a small, fast-moving river as my back property line. The downside is that it's quite a ways back...it would take decades to recover just the cost of the wiring from the river to the house, let alone any of the generating equipment.
/ My Micro Hydro Project #18
Ya, it would be fun, but you and i would have to look at it like a hobby. Kinda like fishing or hunting, and trying to make that pay for itself.
How far is quite a ways ? My turbines produces A/C power ( AC wild) and can be a great distances from the point of use
/ My Micro Hydro Project #20
Wow, I'm watching. I guess my questions are aimed at the hydro dynamics of the system.
How much does the velocity of the flow coming down effect the pressure or speed of the turbines vs just the 60' head? Wouldn't it be best to have a smooth as can be transition from the main downtube to the turbines to let the velocity help? or am I thinking wrong? It's late. My thinking cap already went to bed.
I will be watching!
