Gasoline Tractors are they coming Back ?
/ Gasoline Tractors are they coming Back ? #101
/ Gasoline Tractors are they coming Back ? #102
I’ve been burning road diesel in my equipment all summer because it’s been cheaper than red. There’s only one supplier in town for red is the only reason I see for it. But I’ve never seen red diesel at $1.50 cheaper than road fuel. It’s usually 50-60 cents cheaper. If you had a farm card the difference might be a little more. But us construction guys still have to pay sales tax on red fuel.
We have a couple places selling off road for 50-75 cheaper than taxed diesel. They are somewhat convenient in that I drive by them, so a special trip isn’t usually necessary.
I didn’t know construction equipment was required to burn taxed fuel? I always burned off road in my backhoe.
/ Gasoline Tractors are they coming Back ? #103
One thought for hand cranking the engine - adapt the crank to use a battery powered tool.
Can you do this? Would the engine kick back when it starts?
/ Gasoline Tractors are they coming Back ? #104
You can buy a 40HP Briggs Vanguard EFI engine in many high end commercial mowers and it makes more horsepower and more torque than say a 25hp diesel small tractor. Why not?
The fuel efficiency isn't anywhere near that of a diesel. This isn't complex stuff to understand. Diesel has more energy and a higher compression ratio. Plus I can tell you from running a commercial mowing business that gas engines just don't hold up like the diesel
/ Gasoline Tractors are they coming Back ? #105
With the high prices of diesel fuel , & possible shortages looming are manufactures considering bringing back gasoline engines that have become more efficient than the ones from 50 to 60 years ago ! & the EV tractors are starting prove themselves not reliable in extreme weather conditions , & the power grid is not there in rural areas & not to mention operating cost ! The diesel engine is still the most efficient as far as fuel consumption , But having to meet stronger emission standards allot of owners are not happy with the regens & having to run def in there tractor of 25 HP or more which adds more to operating cost & efficiency ! In summary would you consider buying a new gasoline engine tractor instead of a EV tractor ! Or as a substitute for a diesel if they were available ? Just a thought :unsure: .
I have been predicting the return of gasoline engines to the small/mid sized tractor market for several years.
The federales have seriously damaged the light truck diesel market as well as the farm tractor market with nonsensical regulations and will continue to do so.
Presently, the opportunity exists for application of modern gasoline powered engines to small and mid sized agricultural applications.
Sadly, any such innovation will not be done in the US and may not be done for the US market because the investment into design and development of such machines can be rendered valueless overnight by an unelected, cube-dwelling bureaucrat in DC.
Of course, should gasoline powered farm tractors become a trend, relentless federales will quickly regulate such into obscurity.
/ Gasoline Tractors are they coming Back ? #106
Would a newer gas be much better maintenance wise than diesel since the catalytic converters would be fire starters along with all the sensors on new gas en
Would a newer gas be much better maintenance wise than diesel since the catalytic converters would be fire starters along with all the sensors on new gas engines.
No hotter than a regenerating DPF.
/ Gasoline Tractors are they coming Back ? #107
There was a time when diesels were the simplest motors. They were entirely mechanical without any electrical systems or carburetors. Gas engines were better at just about everything else, and much less expensive because of the lower compression ratio.
I liked the gasoline industrial engines. They ran wonderfully smoothly at low RPM and started easily. Easy to maintain and rebuild. Lasted just as long as diesels. A much quieter engine and easy to control emissions.
I don't see any great advantage to today's diesels. For most things, the gasoline engines do better.
rScotty
Well said.
/ Gasoline Tractors are they coming Back ? #108
Small, turbo'd gas motors might work well.
They'd LOVE to make us drive electric tractors. Not going to happen (to me anyway)!
/ Gasoline Tractors are they coming Back ? #109
I can agree with your later parts, however I disagree with your first point. People want to compare a diesel engine to a gas engine designed for two completely different applications.
/ Gasoline Tractors are they coming Back ? #110
Would love to see actual facts and statistics. Believe me, JD, Kubota, CNHI, Bobcat, LS, kioti, all the major brands have stuck with diesel. If they thought gas was within reach or made sense, they would have considered it. But they haven't. It's all opinion on here.
/ Gasoline Tractors are they coming Back ? #111
My other biggest problem with this discussion is people have been pushed to believe diesels are bad and that they should move to gas. They can't see past the madness and actually understand. People have bought into the medias narrative and have caved. People also want to compare a 40 year old gasoline industrial engine to a modern diesel and say "oh the diesel has so much stuff on it and it's too complex. Have you actually looked under the hood of a modern gas engine?!? No question diesel is far more complex. No doubt. It's more expensive to maintain it. But a gas engine just can't keep up. They don't last as long. People love to look at specs on paper and say the gas engine is the obvious choice. Have you actually used either? But seriously, These arguments are weak and have no backing.
/ Gasoline Tractors are they coming Back ? #112
I can see where the smaller tractor might be nice to have gas. You have a gas powered lawn mower, gas snow blower, power washer, generator, etc.
If you ask most people if they would want a diesel, it's 'oh ya, sure do!' ask them why and it's more like 'uhm cause everbody says they're better'.
/ Gasoline Tractors are they coming Back ? #113
Fuel has multiple taxes applied with road tax and sales tax being 2 of them. Construction and other off-road equipment can avoid the road tax but still have to pay sales tax. Farm equipment doesn’t have to pay sales tax. At least that’s how the local place sells it.
/ Gasoline Tractors are they coming Back ? #114
Diesels really do need the emissions crap on them because they really are bad for the environment. Old smokey diesels put out big soot particles that make smog and turn everything black, the new diesels with high pressure common rail multi injection are much more efficient but they make tiny soot particles that get far down into your lungs and act like asbestos and can give you cancer later down the road. That is why the new engines have DPF and those over 74HP have DEF systems on them.
After having three emissions diesels in pickups (nightmare emissions problems with the RAM, the Fords were better) the last pickup I bought was a F350 dually with the 7.3 gas engine in it. Tows 20K pounds just as good as the diesels did (just does not accelerate uphill as fast) and is so much easier to live with. Gets the same crappy mileage the diesels did but fuel and maintenance are a lot cheaper. And you can even see the engine and get to everything to work on it if needed down the road. When the powers that be decide to tighten emissions again, I think gas engines will make a comeback.
/ Gasoline Tractors are they coming Back ? #115
I could never figure out why diesel is more expensive than gasoline when the refinement process is more expensive for gas than diesel.All about control I guess
/ Gasoline Tractors are they coming Back ? #116
I am not a conspiracy theorist, but let's face it, diesel is in the public eye these days. Our current government would love to do away with it completely. If they somehow create an environment artificially that keeps fuel prices high, perhaps it will give the industry more incentive to start moving away from diesel. At least, that's the plan. And it seems to be working, with Cummins developing a gasoline version of their popular 6.7L engine, Ford dropping two new gas engines in the last 24 months, and semi-truck manufacturers showing off hydrogen fuel cell and electric options to fleets. I would say it's only a matter of time until ag equipment follows suit.
I would like to note that I do not personally agree with the way things are going. I'm just pointing out how it is. This current administration sees environmental issues as their key to staying in power. All they have to do is convince folks there is a problem, and then present themselves as the solution to that problem.
When I visited Europe I noticed that everything ran on diesel,trucks,cars,minivans you name it but here quite the opposite the government has done all it can to see diesel’s are kept only for industrial purposes
/ Gasoline Tractors are they coming Back ? #117
You raise an interesting question. One drawback of gas for occasional users is that it doesn't store as well as diesel does. I can shut my diesel tractor off, pull the key and walk away from it for a year. (Theoretically speaking... it's a rare occasion that it sets for more than a week.)
I did that with my Ford Explorer. I did keep the battery on charge, though. It had to crank a little on the starter, but fired right up after sitting that long.
I think a modern gas tractor with fuel injection would work quite well. The quick warm-up of gas motor would be well matched to the hobby/casual user with mostly spurts of short activity.
Including an OBDII port would allow use of common diagnostic tools and make it friendly to owner-maintenance.
/ Gasoline Tractors are they coming Back ? #118
Supply and demand.
Diesel fuel prices started getting more expensive around the same time diesel pickups started becoming popular, back when diesel was less expensive than gas.
Same thing happened to the price of vegetable oil when people found out it was cheaper than diesel fuel and started that short-lived fad of burning veggie oil in diesel trucks. The price of vegetable oil Doesn't anyone remember that?
/ Gasoline Tractors are they coming Back ? #119
And before all the craziness going on in the world in the last two years, Diesel was like 50 to 70 cents cheaper per Liter than gasoline. Which is a big part as to we tend to have lots of diesel engines everywhere, from small air cooled 4hp diesel engines to 750 HP like the ones used on Volvo trucks.
Even way back in the day, we've always had diesel engines on tractors. Gas engines were a complete minority and often brought out by companies like JD, Massey, and maybe a few others.
/ Gasoline Tractors are they coming Back ? #120
Gas engines are not a good match for high torque load (like a farm tractor) or constant run (like a high mile OTR truck) tasks.
They have less torque rise and low end torque meaning they must rev higher, meaning shorter lifespan and more fuel consumption.
The newer/improved gas engines took a cue from diesel engines with turbocharging, heavier bottom ends, higher compression to make them more efficient, but also cost more to build, so the cost advantage is shrinking since gas engines have more accessories bolted to them, adding cost.
That being said, if gas is going to be 2/3 the price of diesel, I could see people putting up with the les’s torque at low RPM and high gallon consumption. Especially if the buy-in price for the engine is less.
A breakthrough in diesel engine emissions technology that makes the price more affordable could change that.
We live in an unpredictable, ever changing world where you never know what can happen.
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
Pittsburgh Heavy Duty Solid Steel Auto Ramps (A59230)
Pittsburgh Heavy...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
