R14 tire pressure... have you read the sidewall?
   / R14 tire pressure... have you read the sidewall? #21
However further investigation of what happened showed it should have had a max 10 psi +- cold. Not 35 and definitely not 44
   / R14 tire pressure... have you read the sidewall? #22
Dumb question but are you sure that's not 30.0 kpa which is around 4.4 psi?
   / R14 tire pressure... have you read the sidewall? #24
Big difference. Much attention has to be paid to this. Same with load capacity.
   / R14 tire pressure... have you read the sidewall? #25
   / R14 tire pressure... have you read the sidewall? #26
AFAIK. R1 tires (ag tread) have relatively weak sidewalls compared to the rating of most modern loaders. Get a good load in the bucket and the front tires well be sagging. R4 tires (e.g. typical skid steer tires) have much stronger sidewalls, but traction suffers in mud etc.
   / R14 tire pressure... have you read the sidewall? #27
That's one of the reasons I have R4 tires on the tractor I use in the woods. I don;t need a sharp rock or stick/log tearing a hole in the sidewall. The traction does suffer in some conditions over what I would get with R1 tires, but the studded "euro-style" chains help make up for that (I'd have the chains on regardless of tire type for winter work anyway: both tire styles suck on ice.)
   / R14 tire pressure... have you read the sidewall? #28
I think the correct pressure is when you see the lugs on the floor, probably in the 20s. Mine were low 20s when I first checked.
   / R14 tire pressure... have you read the sidewall? #29
Great info, Wonder my Turf tires come in line with the R4 sidewall in comparison. Have other utility trailer, tandem trailers, now have to start paying close attention to the sidewall warnings.
   / R14 tire pressure... have you read the sidewall? #30
Typical turf tire sidewalls are nowhere near the strength/toughness of R4 tires
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Kubota LX2620 (A53317)
2017 Nissan Altima 4 door (A56438)
2017 Nissan Altima...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2019 JCB 457 (A60462)
