R14 tire pressure... have you read the sidewall?
/ R14 tire pressure... have you read the sidewall? #21
However further investigation of what happened showed it should have had a max 10 psi +- cold. Not 35 and definitely not 44
/ R14 tire pressure... have you read the sidewall? #22
Dumb question but are you sure that's not 30.0 kpa which is around 4.4 psi?
/ R14 tire pressure... have you read the sidewall? #24
Big difference. Much attention has to be paid to this. Same with load capacity.
/ R14 tire pressure... have you read the sidewall? #26
AFAIK. R1 tires (ag tread) have relatively weak sidewalls compared to the rating of most modern loaders. Get a good load in the bucket and the front tires well be sagging. R4 tires (e.g. typical skid steer tires) have much stronger sidewalls, but traction suffers in mud etc.
/ R14 tire pressure... have you read the sidewall? #27
That's one of the reasons I have R4 tires on the tractor I use in the woods. I don;t need a sharp rock or stick/log tearing a hole in the sidewall. The traction does suffer in some conditions over what I would get with R1 tires, but the studded "euro-style" chains help make up for that (I'd have the chains on regardless of tire type for winter work anyway: both tire styles suck on ice.)
/ R14 tire pressure... have you read the sidewall? #28
I think the correct pressure is when you see the lugs on the floor, probably in the 20s. Mine were low 20s when I first checked.
/ R14 tire pressure... have you read the sidewall? #29
Great info, Wonder my Turf tires come in line with the R4 sidewall in comparison. Have other utility trailer, tandem trailers, now have to start paying close attention to the sidewall warnings.
/ R14 tire pressure... have you read the sidewall? #30
Typical turf tire sidewalls are nowhere near the strength/toughness of R4 tires
/ R14 tire pressure... have you read the sidewall? #31
I experienced the same. My manual did not cover the r14. The dealer told me to use the number on the sidewall which I knew was wrong. That’s typically the max allowable pressure not recommended pressure. Found the Titan tire specs that had recommended load vs pressure charts for my tires. So now I set tire pressure based on loader/ballast vs mid mount mower. Noticed much better ride when mowing and front wheels stopped scrubbing the grass in tight turns. Did have to guestimate tractor weight distribution. Here’s the link.
Thanks for the link…
Gives me a good starting point…
FWIW, these charts are for the Kioti CK10 tire sizes… other sizes are listed in the link above…
/ R14 tire pressure... have you read the sidewall? #33
There are always exceptions. Most times the weight limit and air pressure quoted on the sidewall is the pressure required to get the maximum carrying capacity. Some people always run the pressure quoted on the sidewall. I do so on my Kubota.
My tractor, guessing, weights maybe 3000 - 3300 lbs (with FEL and tire ballast)… extrapolating the charts, if I run max pressure (44 psi) in each tire I could carry a whole ‘nuther CK and still be under the tires weight ratings…
:unsure:
/ R14 tire pressure... have you read the sidewall? #35
:unsure:
Ummm,,, do you think that tire is only made to go on your CK?
I appreciate that tire manufacturers mark their sidewalls with this information. Another valuable one is "made date".
Use the marked information as a guide to not overload or over pressure your tires. Adjust accordingly.
/ R14 tire pressure... have you read the sidewall? #36
Definitely read and understand the 4 digit code for manufactured date.
/ R14 tire pressure... have you read the sidewall? #37
Especially trailer tires. It's like they have an internal clock!!!! At a certain age, and it's not very long, they self destruct. :)
…a very good point...
I should‘ve stated: I’ll be running these R14’s for the foreseeable future… I’m the epitome of the “weekend warrior”… I Don’t use my tractor on a daily basis, it’s more of a convenience on our property, well, that and way more fun than a shovel or a hand-truck…
Having R1’s on my other tractor I appreciate the smoothness of the 14’s… I’ll probably appreciate them even more when I get their pressure Adjusted correctly…
Your point regarding the manufacture date is probably the most overlooked item in the tire industry… for those who don’t know, the four figure date mark (stamped in an oval on your tire’s sidewall) is the week and year of manufacture… I.e. ”3321” corresponds to the 33rd week of 2021 (or, roughly, August 2021)
/ R14 tire pressure... have you read the sidewall? #39
And how old is too old for a tractor tire?
Are my 30+ year old tires too old?
Do I risk death if I still run them this winter plowing snow?
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
DEUTZ MARATHON...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
