Need advice on a larger chainsaw for an older guy.
/ Need advice on a larger chainsaw for an older guy. #321
Buy a new, bigger saw - get a younger guy to run it for you.
/ Need advice on a larger chainsaw for an older guy. #322
For larger than 12" trees you are in at least 60cc territory. You will be surprised what size tree you can work up with a 60cc even with a 20" bar. I see nice used 036 pro's and 361's for $3-400.
/ Need advice on a larger chainsaw for an older guy. #323
indeed, I wouldn't touch anything less than 60cc ... anyone has had an electronically controlled fuel injection chainsaw for a while ?? the first one (ms 500i) entered the market in 2012, the first Husky came out in 2018. Pretty resent still but with the carburetor one being discontinued I am wandering what is your experience so far with fuel injections?
/ Need advice on a larger chainsaw for an older guy. #324
The MS500i is fuel injected. It's Stihls only FI saw. It's only been available in the US for a year or so. The TS series concrete saws have used the same FI setup for a while. By all accounts it is pretty reliable.
The CM series Stihls have computer controlled carbs. Which is not the same as FI, it's more primitive. The computer controls the carb jets. Those have been around for longer and use tech originated by Husqvarna and used in some of their saws. There are regular carb versions of many of the CM saws. It's actually pretty cool- the computer only needs to measure the engine rpms in order to figure out how to set the carb. There's no sensors to go bad.
Like the FI saws the CM saws are also reliable. There's a reset procedure that you can use to make the computer start from defaults and relearn your saw. I have not needed to do it for my CM saws. They just run like perfectly tuned regular carb saws without me needing to get out the screwdriver and tach. I'd be fine with more CM saws.
The one issue with my CM saws is that you need to idle the saw for 5 seconds or so before shutting it down. If you're cutting and just cut the ignition (like when you're backing away from a tree after making the felling cut) the computer will wind up setting the mixture too rich when you go to restart and it will act like you left the choke on too long. Opening the throttle leans out the mix and allows it to start.
/ Need advice on a larger chainsaw for an older guy. #325
thank for the explanation this clears the water a lot... everyone seems to be scared of this ''new tech'' probably just something to get used too ...
/ Need advice on a larger chainsaw for an older guy. #326
I’m supposed to pick up a new Stihl 261 CM tomorrow afternoon. I had been looking for one and they were nowhere to be found. Then I ran across two in the same day. The one I’m getting is $639. On sale.
/ Need advice on a larger chainsaw for an older guy. #327
Thats me, I never take anything to a shop, I fix all my own equipment. However, my MS391 won't even pull the chain so I dropped it off at the shop. I probably should have tackled it because it has been 5 days now... Twice I had it at the shop while it was under warranty for off idle bog, but they never did fix it. It is 3.5 years old now. I kinda suspect the coil, I have read they can be problematic.
I like the looks of the new MS400 but it is even more electronic. Also looking at a 590 Echo for half the money. They appear to be good saws.
/ Need advice on a larger chainsaw for an older guy. #328
I run a Husky 550xp and a 572xp. Love them both. 572 is amazing.
If I could only have one saw, it would be a 562xp
Older thread and older post but I'll echo this.
Im not up on current saws. And Im a dolmar guy. And I still like dolmar. But picked up a 562xp at an auction for $280 and it came with 4 good 20" bars and about 20 spare chains only used/sharpened once or twice each.
Even being a dolmar guy, its kinda my go-to mid sized saw. Good power to weight, its light and fast. It isnt a beast like my big dolmar, but isnt as heavy either.
So my advice to anyone looking for a mid-sized saw in the 60-70cc range....its hard to beat the 562xp
/ Need advice on a larger chainsaw for an older guy. #329
Unpopular opinion here, but I wouldn't take a Stihl product if you gave it to me for free. We've got a Stihl Farm Boss saw and a weed trimmer and a hedge trimmer/limb saw, all bought new a few years ago. The limb/hedge trimmer combo works fairly well most of the time, the chain saw and weed trimmer are complete trash. They are extremely difficult to start. The motors are very cold natured and run like crap. The saw in particular seems to require constant adjustment of the bar and chain and the design is a tooled design so eventually the set screws wear out and require replacement. Every time I have to use those Stihl tools I end up cussing. I hate them. Never again.
I've resorted to using the decades-old Dolmar saw whenever I have big jobs and my 24v electric Kobalt saw for medium or small jobs, and I guess I'm buying a new weed trimmer next spring. Stihl makes over-priced and over-hyped products. Sort of like GM trucks....objectively the worst on the market but still sell in quantity simply due to the name.
/ Need advice on a larger chainsaw for an older guy. #330
I've tried to like them. I've bought several Stihl products over the years. They were either lacking in performance or problematic. Got rid of all of them.
/ Need advice on a larger chainsaw for an older guy. #331
My husqvarna computer carbs have been great. They've needed nothing but chains,gas,and oil. I don't miss the old adjustable carbs at all.
/ Need advice on a larger chainsaw for an older guy. #332
I'm not aware of Husqvarna having anything fuel injected. They have auto tune which is a computer controlled carb. I've had no trouble with either of mine.
/ Need advice on a larger chainsaw for an older guy. #333
Did some more felling today. (Ice storm a month ago has left a good many topped pines). Saw still bogging some.
I’m not going to rush out and get a bigger saw but at this point it is officially on the wish list.
Haven't read all 34 pages of this topic but I just started using chainsaws (I have 3 now) for the first time since moving to the country.
All are 20" and the same brand (Echo). I don't cut near what you are cutting but one thing I've learned is to always keep the chain sharp and the chainsaw clean after every use.
If I hit dirt with the chain I switch to another chain saw.
Every time I use my chainsaw I know it is ready to go.
/ Need advice on a larger chainsaw for an older guy. #334
There’s a bit of a difference between a pro saw vs something like a wood boss ms 029/290. Their newer stuff has been pretty good the filters on the 500i still could be better but it does the job ok like the 562 do as well.
This gives you a rough idea of what I’ve ran and do still run for falling, the 500i is my primary falling saw anymore one for weight and two the way it handles. That 562 is a very early model and finally has been retired from falling duties to landing saw where I couldn’t get away from my guys even if I wanted they are a great little as well.
/ Need advice on a larger chainsaw for an older guy. #335
Having ran them hard since 2012 we’ve had very few issues but when the auto tune does act up it enough you’re normally done for the day such as a no start from heat.
/ Need advice on a larger chainsaw for an older guy. #336
I heard that was an issue early on but supposedly fixed with several updates. I've never had that issue with mine.
/ Need advice on a larger chainsaw for an older guy. #337
Only had it happen once it wasn’t even a warm day but it had been ran extremely hard for 5.5 hrs cutting large cedar and alder.
/ Need advice on a larger chainsaw for an older guy. #338
Ms261 and ms462 here. After using smaller saws for years, the first time the 462 was used on white oak I thought the tree was rotten. Nope, just very efficient and fast. It's a good combination. Lots of lightweight power for large wood, the other light and maneuverable for climbing around limbing and in brush. I work alone, would generally not ask for help, and "older" like the op. They are both a beast for their intended purpose. Very happy with the combination. But it's getting to the point where its the 462, all day, for almost everything. It's a very productive unit.
/ Need advice on a larger chainsaw for an older guy. #339
Skeans 1 - How do you like the Echo?
/ Need advice on a larger chainsaw for an older guy. #340
Funny but my '70s Stihl 031AV is my "nothing else is working right" go-to saw :p that SOB will always start and pull, though it's noisyAF and heavy
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2013 Peterbilt 365 IMT 40/275K6 9.5 Ton Knuckleboom Crane Truck (A60352)
2013 Peterbilt 365...
CFG QK16R (A60463)
CFG QK16R (A60463)
Tank Only (A59076)
Tank Only (A59076)
