New Metal shop
/ New Metal shop #1
woody
Central Alabama
Kubota B26, Kubota ZG222, Kubota L45, 1980 Ford 1700
I ordered a new metal shop building today, it is basically a glorified car port but it will serve to double the size of my existing shop and with a taller roof it will be better suited for my recent lift addition. It will have the square tubing wall studs and roofing metal walls, with the wall studs five feet apart what's the best way to run and secure the wiring to the plugs and light fixtures. I used pvc conduit in my other shop but I believe it would sag or droop between studs I may have to use EMT but I'm not good with the bending process.
/ New Metal shop #2
Can you make a wire chase to support the wires and cover them for protection? On my garage walls where I didn't want the wires behind the osb exterior walls, I just ran romex across the walls/studs. Then put a 2" x 2" under and above the wires and covered all of it with osb that I can remove and add another circuit if needed. Electrical inspector made no comment about it. Jon
/ New Metal shop
Thanks for the reply, I have been doing a little research and it is surprising how close metal EMT and PVC conduit are in price.
/ New Metal shop
If it was me, I would run a 2x6 along the wall and attack the grey pvc conduit to the 2x6.
…and run your airlines on the underside.
I been thinking a long those same lines. I dug out for the concrete yesterday and I am going to get some gravel and then call my concrete guys but I am already planning the inside of the building.
/ New Metal shop
Do you have a link to the kit?
No but it is just a basic garage type. building.jpg This is not it but it is similar
/ New Metal shop #9
Finished mine with 2x4's along walls on 24" centers and sheathing. All wiring is inside the studs.. ceiling isn't finished yet but wiring for lights is metal conduit.
/ New Metal shop #10
Had about a 20x20 3 sided carport added to my existing barn over the existing slab which used to be a green house. It's now my "wood working area" Ran steel conduit over osb, also ran a small piece of steel flex to the existing breaker box in existing barn they do make conduit benders, originally thought of running Romex inside using the ribs of the steel sheets as raceways thought about it went a different route, also thought about plastic conduit steel is better imo especially when it's exposed and probably code, ran 2x3s so the osb would end and start on something fastened osb with self tapping steel stud drywall screws, no problems for 4 yrs now.
/ New Metal shop
Jeff that is so close to what I have in mind, I was considering using EMT because it is metal and I think would be better but I have about 10 sticks of 1/2 inch PVC conduit laying behind my shop I can use instead of buying. I see you used some MC cable and some EMT I may use some PVC and some EMT will know more when I have the building up. Thanks for the pictures
/ New Metal shop
20221106_163627.jpg working on gravel and forms will have the concrete pad before long
/ New Metal shop #13
Yep, most of the boxes aluminum flex, and fittings I had left over from when I wired my pole barn up north had to buy a few emt sticks though, definitely not a good emt bender so I ran flex to the existing panel in my old barn, Another thing I considered when I used emt Is believe you don't have to run a separate ground wire back to the panel that's feeding your circuits just jumpers from the outlet to the outlet box provided your emt is properly grounded to the panel. Disclaimer "Im not a licensed electrician".
/ New Metal shop #15
Quick question are you planning to put sillseal in between the slab and baseplate? I had some lying around used it and glad I did as of now, really helps keep water out and bugs I presume. However I'm unsure if it will eventually rust and perforate the galvanized baseplate due to moisture being trapped? So far nothing.
/ New Metal shop
Jeff I told to run a bead of caulk before setting the building and I was going to ask here what type should I use for metal to concrete?
/ New Metal shop #17
If I didn't have left over sil seal lying around I probably would have used pl400 or a urethane based sealant/ caulk. But good question.
/ New Metal shop #18
I run a thick bead of PL 375 Construction Adhesive under my sill plates. It's like Liquid Nails, but better. I've used Silicone too, but I've seen ants get through the silicone, and I don't think silicone bonds to the concrete very well.
/ New Metal shop
I will look for some when I make a trip to town, Thanks
/ New Metal shop #20
i would not recommend using the conduit as the ground, if the conduit becomes non-continuous then the case of the equipment can then become energized and make you the ground. I am an electrical engineer PE
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
Palfinger ILP 3300 3,300lb Truck-Under Lift Gate (A68183)
Palfinger ILP 3300...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
QA Mini Plate (A64912)
2019 Yanmar ViO35 Midi Excavator (A66734)
2019 Yanmar ViO35...
