Harbor Freight
/ Harbor Freight #21
i do a lot of light welding, such as cracks in lawnmower decks. i am by no means a professional welder but welding up these decks keeps them from cracking farther and if there is a small hole i weld a thin piece of metal over the hole. i use a 1/16 6013 rod and the hf rods are the cheapest i have found and they work fine.
/ Harbor Freight #22
If you have an inverter welder, the rod brand isn't the problem , It's the inverter welder.
If you want a good weld with any brand rod, Buy an transformer welder. Not an inverter.
I have this new everlast, and It's difficult to keep the rod lit, no matter the rod brand.
My old tombstone will out weld this everlast machine all day !
/ Harbor Freight #23
Man you should be having no issues with that welder. I would be talking to customer support. I own a Omnipro 220 from Harbor freight and have no issues with 7018, 6013,6011. Seems like those Everlast welders are multiple levels above the Omnipro in terms of functions, options and quality.
/ Harbor Freight #24
Bet they are both made in some Oriental sweatshop. I prefer a transformer welder myself unless it's a TIG machine.
/ Harbor Freight #25
Yeh, mines an inverter welder too, got no problems with them HF rods.
/ Harbor Freight #26
Most inverter stick welders worth their salt will have hot start and arc force adjustment. If a guy can't stick weld with those features I'd suggest Mig.
/ Harbor Freight #27
this everlast has hot start, but it's still difficult to keep the rod lit . If you get the rod just a little away from the work it goes out.
Never an issue with my transformer machine.
I would hate to be learning to weld on one of these machines. Heck, it makes me go nuts at times, and I've been welding since the 70's.. back then for a living .
/ Harbor Freight #29
Pretty well kept secret but HF solid wire is the same as Innerfil wire just different packing.
This wire?
I've settled on INE's flux core wire as best-available. I wonder if HF's flux core also comes from INE?
/ Harbor Freight #30
Another thing to consider with the inverter stick units is that if it's not designed to run 6010-6011 it simply won't do it.
/ Harbor Freight #31
I bought 5# of rod from my local welding and gas supply shop (7018) was not impressed. I have to chunk off some shielding to continue a weld everytime i stop. They lay down nice bead, but hard to restrike. Went to homedepot and got 5 pounds of their 7018 Lincoln brand rod. No issue restriking theirs. Still lays a nice bead. I think im going to toss the other stuff. And i keep all my 7018 in a rod oven. I usually only use Lincoln rods. Never tries HF, but im scared off by most of their junk.
ive never used an inverter welder. I have a mig welder and a miller thunderbolt xl stick welder. I learned many years ago on an old Lincoln tombstone unit, and the miller is so much easier to use. Easy to fine tune the welds. Im thinking of getting a newer mig unit, but honestly just dont do much welding anymore that requires anything more than i have. last year i fabbed up 20 wrought iron fences for a friend. Man, the mig got a work out on that one. 77F7A4B2-B8D0-41FA-90B0-EAFB65C45E7A.jpeg
and then he wanted some artwork welded to the tops. So i had to make 20 panels 12” x 8’ to attach to tops.
my problem, while i enjoy doing these jobs, i get bored real fast. Kind of becomes a production line.
/ Harbor Freight #32
Yeh, I only ever stick welded with my inverter Amico welder, and mostly with them harbor fright rods. So now I know, I'm actually an awesome welder, all my problems are just the result of using the wrong equipment!
/ Harbor Freight #33
This wire?
YEP. I used to order 4 spools at a time direct until I found put HF was selling it. Don't use FC wires only solid so I cannot answer that question. Kind of wish I could get it in 50 pound spools but I cannot.
One thing I do it, I take an unsmoked filter cigarette filter and cut it off and put it on the wire in front of the pinch rolls. Keeps the wire clean. You can buy them pre made but why bother.
/ Harbor Freight #35
I use the weld-aid red and black pads and lube on my machines, keeps the liner clean. My favorite FCAW wire is .030 Forney. Forney flux core wire seems to run hot and fast.
/ Harbor Freight #36
Me too. But dry, to clean the wire as it comes off the spool.
I found Forney FC ok. It does seem hot.
And PNG's E71-T11 is the cheapest (Amazon, Ebay) FC wire I've found that works well. It's level-wound on the spool so it feeds flawlessly - in contrast to several varieties of generic cheap FC wire that came with the welder I bought used. It welds great.
Any T-11 wire is going to be similar to Lincoln's FC, a standard in the industry, since T-11 is an explicit standard.
Since -GS means 'whatever the manufacturer wanted to spec' I steer away from -GS except for INE's made in Italy INETUB BA71TGS, in my opinion the best FC wire I've found. Less spatter and smoke, feeds perfectly, it simply makes me a better welder.
Yesterday I put back in the remaining half of a roll of Blue Demon FC wire I had yanked out of the welder in frustration during a project, a while back. It had not fed smoothly enough starting from new, to make a consistent bead. After discarding many feet of wire I got down to mostly feeding ok, but not flawless like INE or PNG wire. I had bought that Blue Demon for my first MIG welder (HF MIG-180 bought used) and I remember now the bad feeding was a PIA that made learning that welder harder than it should have been. Not much smoke but a lot more spatter than anything else I've used. Not recommended.
Has anyone tried a direct A/B comparison of INE's FC wire vs HF's Vulcan FC? I see good reviews on HF and I've read that some think HF's is really INE. If HF's Vulcan is the same thing, good for HF!
/ Harbor Freight #37
Matter of fact my local welding store has been out of Lube-Matic welding pads for a few weeks. I emailed CRC who is the company producing the red and black cleaner and lube pads. They said they are out of material and have no idea when they will be able to start producing them again due to supply chain problems.
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
Kinze Planter Tire (A65640)
Kinze Planter Tire...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
