Harbor Freight
   / Harbor Freight #21
i do a lot of light welding, such as cracks in lawnmower decks. i am by no means a professional welder but welding up these decks keeps them from cracking farther and if there is a small hole i weld a thin piece of metal over the hole. i use a 1/16 6013 rod and the hf rods are the cheapest i have found and they work fine.
   / Harbor Freight #22
If you have an inverter welder, the rod brand isn't the problem , It's the inverter welder.
If you want a good weld with any brand rod, Buy an transformer welder. Not an inverter.
I have this new everlast, and It's difficult to keep the rod lit, no matter the rod brand.
My old tombstone will out weld this everlast machine all day !
   / Harbor Freight #23
Man you should be having no issues with that welder. I would be talking to customer support. I own a Omnipro 220 from Harbor freight and have no issues with 7018, 6013,6011. Seems like those Everlast welders are multiple levels above the Omnipro in terms of functions, options and quality.
   / Harbor Freight #24
Bet they are both made in some Oriental sweatshop. I prefer a transformer welder myself unless it's a TIG machine.
   / Harbor Freight #25
Yeh, mines an inverter welder too, got no problems with them HF rods.
   / Harbor Freight #26
Most inverter stick welders worth their salt will have hot start and arc force adjustment. If a guy can't stick weld with those features I'd suggest Mig.
   / Harbor Freight #27
this everlast has hot start, but it's still difficult to keep the rod lit . If you get the rod just a little away from the work it goes out.
Never an issue with my transformer machine.
I would hate to be learning to weld on one of these machines. Heck, it makes me go nuts at times, and I've been welding since the 70's.. back then for a living .
   / Harbor Freight #29
Pretty well kept secret but HF solid wire is the same as Innerfil wire just different packing.
This wire?
I've settled on INE's flux core wire as best-available. I wonder if HF's flux core also comes from INE?
   / Harbor Freight #30
Another thing to consider with the inverter stick units is that if it's not designed to run 6010-6011 it simply won't do it.
2020 DRAGON ESP...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
ROLLING HAND CART & PUMP (A52708)
ROLLING HAND CART...
Electric Horseless Carriage (A57453)
Electric Horseless...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
Deere 35G (A53317)
Deere 35G (A53317)
